1993 Astro oil change
Postby Wil [OP] » September 22nd 2010, 6:03pm
Hi,
I am just about to change the oil on my Astro for the first time. Are most people putting the vehicle on ramps for this or can you change the oil by just crawling under it as is? I could just see if I can squeeze under there, but that would be too easy!
Thanks,
Wil
Wil
Years of Membership: Wil has been a member for 10 full yearsWil has been a member for 10 full yearsWil has been a member for 10 full yearsWil has been a member for 10 full yearsWil has been a member for 10 full yearsWil has been a member for 10 full yearsWil has been a member for 10 full yearsWil has been a member for 10 full yearsWil has been a member for 10 full yearsWil has been a member for 10 full years
Topics: 9
Extra Info: 4.3 EXT RWD
  • Replacing engine sump/oil pan
    by Wokka » October 18th 2020, 8:41pm in Engines
    October 19th 2020, 2:16pm
  • Small oil leak near drain plug
    by Eddy » December 11th 2020, 11:25pm in Engines
    Last post by Eddy View the latest post
    December 11th 2020, 11:54pm
    April 12th 2021, 8:20am
Re: 1993 Astro oil change
Postby Phantom » September 22nd 2010, 6:13pm
:) That would depend on if the ground is level and you can squeeze under it , the average build guy can probably squeeze in there , if not you can use wheel chocks and a jack stand
Phantom
Firing on 7 Cylinders (L4)
Postby mkj54 » September 22nd 2010, 6:31pm
They love it when you grease'em too.
mkj54
Fueling (7/8 tank)
Fueling (7/8 tank)
Years of Membership: mkj54 has been a member for 10 full yearsmkj54 has been a member for 10 full yearsmkj54 has been a member for 10 full yearsmkj54 has been a member for 10 full yearsmkj54 has been a member for 10 full yearsmkj54 has been a member for 10 full yearsmkj54 has been a member for 10 full yearsmkj54 has been a member for 10 full yearsmkj54 has been a member for 10 full yearsmkj54 has been a member for 10 full years
Postby jeff's93astro » September 22nd 2010, 6:43pm
i crawl under mine with it on all 4 and i can change the oil and spark plugs without ramps i'm 6.1" and 220lbs
95 Astro 5.3L RWD 3/3 drop
03 Suburban 5.3L 2wd 3/5 drop
jeff's93astro
Topics: 55
Images: 19
Extra Info: CS 4.3L V6 RWD
Postby RECox286 » September 22nd 2010, 7:24pm
That's (one reason) why I love my truck. Cars with 4" clearance...you can have em. Raining? no problem, just crawl in and go to work!
Keep on Truck'n
Bob
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Alias (AKA): Uncle Bob
Extra Info: RWD V6 [325K mi]
Postby Leeann_93 » September 22nd 2010, 10:30pm
You can crawl under and change it - it's a wonderful thing ;)
Postby rev_les » September 22nd 2010, 10:37pm
It's a bit tight, I prefer to jack it up and put it on a stand on the drivers side to get a few more inches. As stated previously, it's also a great time to take the grease gun to the zerk fittings :mrgreen:
NRA Lifetime Member
2'nd amendment supporter
'13 Jeep Patriot
'87 Monte Carlo SS
'79 Avco 32' RV
rev_les
Firing on 2 Cylinders (L3)
Years of Membership: rev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full years
Topics: 39
Alias (AKA): Les
Extra Info: LS 4.3 RWD
It is currently April 12th 2021, 8:20am
kvargas1356
Time: 10:20pm
Attached by: jfunkngroove
jfunkngroove
Comments: 17
Date: Apr 10 '21
Time: 10:38pm
Date: Apr 08 '21
Time: 8:52pm
jfunkngroove
Comments: 17
Date: Apr 08 '21
Time: 1:55am
Date: Mar 22 '21
Time: 2:11pm
