2002 spider removal, need some info from the brain trust
Postby Davo2530 [OP] » February 3rd 2016, 2:38am
I am in the process of replacing the spider in my 2002 Astro. I have the upper plenum unbolted and am ready to attempt to remove it from the engine bay. First issue I have encountered is the Trans tube goes across the plenum in the center of the engine bay. It is not fastened and I can not determine just where it is supposed to be attached. Do I have to remove this from the tranny to get the plenum out? The 2 bolts that go through the throttle body and into the lower intake are obvious but where is the remaining bolts holding the throttle body I can see the long stud that held the air intake but it does not have a bolt head that I can see, does it hold the throttle body on. and how does it come out, if so? I wish who ever created this mess was close enough to take out my frustration on. I found RTV in the fuel line connectors and there is no cover on the fuel injector plug. Half the bolts are missing to things that are holding brackets and wiring harness clips. Dipstick tube is loose as is trans tube, would like to know where they are supposed to be fastened. Coil bracket was loose. Just a half assed job by either PO or some don't give a damn mechanic. :screaming: :banghead: :shrug: any help would be greatly appreciated and some pictures of where everything is supposed to be would be wonderful.
Davo2530
Years of Membership: Davo2530 has been a member for 5 full yearsDavo2530 has been a member for 5 full yearsDavo2530 has been a member for 5 full yearsDavo2530 has been a member for 5 full yearsDavo2530 has been a member for 5 full years
Topics: 20
Alias (AKA): Dave
Van Model Year: 2002
Extra Info: 186kmiles
  • How HIGH for subframe and engine removal?
    by Rod's Trucks » December 2nd 2020, 5:00am in Engines
    December 3rd 2020, 6:11am
  • 2003 alternator bracket removal
    by PinVanMan » March 21st 2021, 1:32am in Engines
    Last post by stent View the latest post
    April 6th 2021, 9:08pm
    April 14th 2021, 2:30am
Re: 2002 spider removal, need some info from the brain trust
Postby Leeann_93 » February 4th 2016, 2:13am
See the bolt on the left side, barely lit? That's the bolt that holds the dipstick tube to the throttle bracket:
And you see here the bolt that holds the two dipstick tubes together:
The last dipstick tube bolt is on the tranny itself; it's the passenger side top bolt from the tranny to the engine.
I think, even without removing the dipstick tube from the transmission, you should be able to swing it enough out of the way to remove the plenum.
Postby Davo2530 [OP] » February 4th 2016, 2:54am
Thank you yet again Leeann, I could not visualize how those were connected or to what, everything is either loose or missing and since I don't have Volume 1 I have no point of reference. I have purchased another set of FSM and am anxiously awaiting their arrival, hopefully I won't get ripped off again. I could not believe the RTV in the fuel line fitting instead of the proper O rings. What were they thinking?
Davo2530
Topics: 20
Alias (AKA): Dave
Postby Leeann_93 » February 4th 2016, 2:58am
RTV? Seriously?
Postby Davo2530 [OP] » February 4th 2016, 3:37am
I am surprised it ran at all actually considering all the crap I have found so far. I this van could have I bet it would have run away from home for the abuse and mistreatment it got. I hope the rain is finally over so I can get back to it tomorrow. I will keep you posted how things go.
Davo2530
Topics: 20
Alias (AKA): Dave
Postby Davo2530 [OP] » February 5th 2016, 8:19pm
OK, upper plenum is off, spider is out of the bracket, but now the injectors won't come out of the manifold. I really don't want to break anything off that will require removing the lower if it is not necessary, so some one wish to tell me what the trick is? These are the new style injectors so no squeeze clips. That would be to easy!!!
Davo2530
Topics: 20
Alias (AKA): Dave
Postby CopperFiremistCopperFiremist is online! » February 5th 2016, 8:39pm
soak with some WD40 or what not. Take pair of pliers and work them back and forth. All the gooey build up is causing you problems.
Pullin The Pass
Firing on 1 Cylinder (L2)
Years of Membership: CopperFiremist has been a member for 6 full yearsCopperFiremist has been a member for 6 full yearsCopperFiremist has been a member for 6 full yearsCopperFiremist has been a member for 6 full yearsCopperFiremist has been a member for 6 full yearsCopperFiremist has been a member for 6 full years
Topics: 25
Images: 6
Alias (AKA): B
Extra Info: LS Swap
Postby Davo2530 [OP] » February 5th 2016, 8:46pm
Thanks for the response, looked in toolbox and found bentnose pliers,worked great no broken injectors, intake is surprisingly clean inside like this might have been done recently
Davo2530
Topics: 20
Alias (AKA): Dave
Postby Davo2530 [OP] » February 5th 2016, 11:30pm
Is the torque for the throttle body the same as the upper plenum? I am referring to the third bolt that attaches the throttle body to the plenum.
Davo2530
Topics: 20
Alias (AKA): Dave
Postby sadglad » February 6th 2016, 1:25am
Not sure if this is what you are looking for.
sadglad
Years of Membership: sadglad has been a member for 9 full yearssadglad has been a member for 9 full yearssadglad has been a member for 9 full yearssadglad has been a member for 9 full yearssadglad has been a member for 9 full yearssadglad has been a member for 9 full yearssadglad has been a member for 9 full yearssadglad has been a member for 9 full yearssadglad has been a member for 9 full years
Topics: 22
Images: 15
Extra Info: 2002 AWD Cargo
Postby Davo2530 [OP] » February 6th 2016, 1:32am
Yup that is exactly what I needed to know, I thought it might be but since it was into the plastic plenum I wanted to be sure, thanks for the reply.
Davo2530
Topics: 20
Alias (AKA): Dave
It is currently April 14th 2021, 2:30am
kvargas1356
Date: Apr 11 '21
Time: 10:20pm
Attached by: jfunkngroove
jfunkngroove
Comments: 17
Date: Apr 10 '21
Time: 10:38pm
Date: Apr 08 '21
Time: 8:52pm
jfunkngroove
Comments: 17
Date: Apr 08 '21
Time: 1:55am
Date: Mar 22 '21
Time: 2:11pm
Users browsing this forum: Google [Bot] and 25 guests
