no oil pressure on gauge
Postby paulbot [OP] » February 7th 2016, 8:06pm
So continuing on from my mishap yesterday (see https://www.astrosafari.com/viewtopic.php?f=43&t=10618&start=20 last post in that thread), when I lost all my oil from an oil cooler line coming off, I double clamped the barbed fittings on the Hayden oil cooler I installed a few weeks ago. Added 4 quarts of oil checked the level, and fired it up. Expected a few seconds on no oil pressure, but it went 30 seconds and still no oil pressure.
Checked the FSM and it seems there is a bypass valve in the block above the oil filter adapter, I'm assuming it's there for the oil filter being clogged, it will bypass it, but unsure. FSM shows oil pressure sending unit under the dog house, so it doesn't seem like I knocked it lose during the repair.
After mulling this over a bit, I guess I need to check the oil pressure sending unit, then I may unhook one of the oil cooler lines and see if there is any flow. Any ideas?
55273 2000 Safari Cargo RWD 235K
paulbot
Years of Membership: paulbot has been a member for 10 full yearspaulbot has been a member for 10 full yearspaulbot has been a member for 10 full yearspaulbot has been a member for 10 full yearspaulbot has been a member for 10 full yearspaulbot has been a member for 10 full yearspaulbot has been a member for 10 full yearspaulbot has been a member for 10 full yearspaulbot has been a member for 10 full yearspaulbot has been a member for 10 full years
Topics: 13
Images: 16
Extra Info: Cargo
  • Correct Oil Pressure Reading
    by Safarimeister » August 19th 2020, 12:42am in Engines
    Last post by Safarimeister View the latest post
    August 19th 2020, 1:11am
  • Oil Pressure Specs
    by AveryStella » December 20th 2020, 12:52am in Engines
    December 27th 2020, 1:57pm
    59
    January 22nd 2021, 5:52pm
Re: no oil pressure on gauge
Postby paulo57509 » February 7th 2016, 8:20pm
I would borrow/rent/buy a pressure test gauge and hook it up where the sending unit is and confirm oil pressure that way.
paulo57509
Firing on 7 Cylinders (L1)
Topics: 24
Extra Info: RWD
Postby paulbot [OP] » February 7th 2016, 10:27pm
Well false alarm. I dug through the shed found a old compression gauge, a 1/4 galvanized tee, and 2 pressure washer quick connects I made a pressure gauge out of. Of course as soon as I put it inline with the oil cooler lines and fired it up, I got pressure on my dash gauge and makeshift gauge. I guess it being dry it took a bit to reprime the oil pump. Still hear nothing out of the ordinary but will keep an eye out.
I did check out what the Hayden oil cooler line brand was, and it's Gates 8002361, quick search shows it's used for power steering return lines and transmission cooler lines. That number did not show up on Gates site search.
edite- here's a pic of the homemade gauge-
paulbot
Topics: 13
Images: 16
Extra Info: Cargo
It is currently January 22nd 2021, 5:52pm
Date: Jan 10 '21
Time: 7:37pm
roachmonroachmon is online!
Date: Jan 10 '21
Time: 4:04am
Date: Jan 09 '21
Time: 6:34am
OldSchoolNoe
Comments: 9
Date: Jan 01 '21
Time: 8:46pm
pmou
Comments: 71
Date: Dec 31 '20
Time: 4:12am
Users browsing this forum: Baidu [Spider] and 20 guests
