egr valve
egr valve
Postby justinf89 [OP] » October 28th 2010, 8:25pm
Where is the egr valve located? I cant find it anywhere without taking everything apart
justinf89
Years of Membership: justinf89 has been a member for 10 full yearsjustinf89 has been a member for 10 full yearsjustinf89 has been a member for 10 full yearsjustinf89 has been a member for 10 full yearsjustinf89 has been a member for 10 full yearsjustinf89 has been a member for 10 full yearsjustinf89 has been a member for 10 full yearsjustinf89 has been a member for 10 full yearsjustinf89 has been a member for 10 full yearsjustinf89 has been a member for 10 full years
Topics: 37
Extra Info: RWD
  • valve rocker stud, bolt.
    by djpigs » September 11th 2020, 4:02am in Engines
    September 11th 2020, 5:53am
  • Coolant in lifter valve valley!
    by roachmon » January 9th 2021, 6:48am in Engines
    Last post by AstroOafAdventurer View the latest post
    January 12th 2021, 10:48pm
    76
    March 7th 2021, 6:30pm
Re: egr valve
Postby Phantom » October 28th 2010, 9:15pm
Phantom
Firing on 7 Cylinders (L4)
Re: egr valve
Postby astroturf » October 28th 2010, 10:09pm
Justin,
As a fellow owner of a Gen 2.5. I can tell you that my 05 Astro does not have an EGR Valve.
What kind of issues are you having?
Thanks, Jim
astroturf
Topics: 112
Extra Info: 2wd Passenger
Re: egr valve
Postby justinf89 [OP] » October 28th 2010, 10:45pm
astroturf wrote:Justin,
Thanks, Jim
pretty rough idle, sounds like a miss but no misfire codes. a little hesitation on acceleration and sometimes, the hesitation is so bad that it takes a couple of seconds of complete bogging to get going. I'm really just picking at straws. Runs perfect at driving speeds, just at idle is the problem.
justinf89
Topics: 37
Extra Info: RWD
Re: egr valve
Postby Phantom » October 28th 2010, 11:09pm
How long has it been since you replaced the distributor cap and rotor? Your symptoms are common when they go bad , sometimes it is vents clogged on the distrib housing , and could be signs of a camshaft sensor weakening , mine went bad and it did not immediately throw a code , it finally did after a couple months , read this tech bulletin from GM about dist vents clogged, If you replace the cap & rotor be sure to use high quality parts , the cheap ones fail in a few months or less, brass terminals preferred.
GM_TSB_03_06_04_041A.pdf
Tech Service Bulletin
(29.76 KiB) Downloaded 121 times
Phantom
Re: egr valve
Postby justinf89 [OP] » October 29th 2010, 2:59am
Actually I replaced them in the past couple thousand miles but I never saw those vents. Maybe they were so clogged they blended in. Ill take a look tomorrow. I suppose they're required to be clean.for correct operation? Thanks for the help.
Edit: that tab says 01-03 models. Maybe they fixed it with my 04?
justinf89
Topics: 37
Extra Info: RWD
Re: egr valve
Postby astroturf » October 29th 2010, 3:07am
Justin,
I pulled the screens on my 05 on the last rotor change.
Jim
astroturf
Topics: 112
Re: egr valve
Postby justinf89 [OP] » October 29th 2010, 2:16pm
Fair enough. Ill check it out later today.
justinf89
Topics: 37
Extra Info: RWD
Re: egr valve
Postby astroturf » October 29th 2010, 2:54pm
Justin,
I feel your pain.
I am currently conducting a test... Here is a clue: 88861011
A little insider info, It seems to be working. Look for a write up on Monday/Tuesday evening.
Jim
astroturf
Topics: 112
Re: egr valve
Postby justinf89 [OP] » October 30th 2010, 9:26pm
Ok, I took the screens out today, and I didn't realize they were that small. They were both clean but the inside of the cap had dust and dirt all in it. The contact posts on the cap had very mild white corrosion that I could wipe off with my finger, and were good and round. I put it all back and it didn't sound any different. I'll have to wait until the motor cools down to really tell, probably in the morning. True cold starts are the worst.
OT: can't wait to hear how that fuel system cleaner worked out for you astroturf
justinf89
Topics: 37
Extra Info: RWD
Re: egr valve
Postby astroturf » October 30th 2010, 9:37pm
Justin,
The GM Part Number is... 88861011.
I would go out and buy 2 bottles now while it is still available. 3 if you absolutely want to kill it.
Smooth, Smooth, Smooth idle.
I'm Lovin It.
Jim
astroturf
Topics: 112
Re: egr valve
Postby justinf89 [OP] » November 1st 2010, 8:18pm
well cleaning the cap didn't do anything. I'm going to take the plugs out next to re-gap. it's been about 20k miles.
justinf89
Topics: 37
Extra Info: RWD
It is currently March 7th 2021, 6:30pm
AppaTheAirBison
Time: 8:54pm
Attached by: MHM
MHM
Comments: 22
Date: Mar 02 '21
Time: 2:20pm
Attached by: MHM
MHM
Comments: 22
Date: Mar 01 '21
Time: 7:27pm
Ken2.7
Date: Feb 24 '21
Time: 2:02am
Date: Feb 23 '21
Time: 8:38pm
Users browsing this forum: 95SafariRunner95SafariRunner is online!, Google [Bot] and 22 guests
