98 how do i flush cooling system
Postby vastronaunt [OP] » March 9th 2016, 4:57pm
As ordered per lumps. Need to flush cooling system. Can you tell me the exact procedures or lead me to a reference. i did searching but no pearls seem to show up
vastronaunt
Years of Membership: vastronaunt has been a member for 5 full yearsvastronaunt has been a member for 5 full yearsvastronaunt has been a member for 5 full yearsvastronaunt has been a member for 5 full yearsvastronaunt has been a member for 5 full years
Topics: 9
Extra Info: my vans dieing
Re: 98 how do i flush cooling system
Postby RECox286 » March 9th 2016, 6:41pm
It is like doing the dishes; scrape the goo off the plates, apply soap, agitate, drain, rinse, dry, and re-stack them for reuse.
You have to be familiar with the system; what the different parts do, how they do it, and why. Any sort of technical material
such as what is available at your LAPS will be better than the information you have at the moment. Start by getting as much
knowledge as you can. When I searched "flush cooling system" there were immediately more than 10 full pages of posts, I
would look over whatever is available on forum. Next, search the topic on U-Tube, I'll bet there are plenty of videos on the
subject.
In condensed form and FYI, here are the steps:
Obtain a flushing agent and a flush kit from your LAPS.
Drain out all the coolant, including the radiator and the block (there are plugs on both sides, and I usually have to poke into the holes).
Remove T-stat then reinstall water outlet housing and install block plugs.
Add flushing agent and top off with water (follow directions on flushing agent container).
Drain out ALL flushing mixture and flush with steady stream of garden hose water until clear while running engine. (don't rush !)
Drain all liquids (not forgetting about block plugs).
Install block plugs, new T-stat and service system with 50/50 mixture of GREEN anti-freeze and DISTILLED water.
Don't be in a rush. It usually takes me a good half day or more to do a proper job of it.
NOTE: You may find you will have to use the flushing agent more than once, be prepared !
Good hunting
Uncle Bob
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Alias (AKA): Uncle Bob
Extra Info: RWD V6 [325K mi]
Postby Astro Pop » March 9th 2016, 8:38pm
Don't forget that the secondary purpose of engine oil is to cool. Think VW pancake engines & Harley Davidson engines. So for maximum engine efficiency FLUSH & change the oil regularly.
Good video on how to flush the radiator:.
https://www.youtube.com/watch?v=s--5ft5YiHg
Also some tech info on types of flushing.
http://www.sancarlosradiator.com/VoltageDrop/flush.htm
I used the three day flush (abbreviated to 36 hrs) and my cooling system looks factory fresh. But it's tricky to setup and requires an external pump. I happened to have an old fountain pump available. Now even with a new t-stat I can't get the temp over 170 degrees.
Astro Pop
Topics: 41
Images: 9
Alias (AKA): Xfirepop
Van Model Year: 1996
Extra Info: AWD - 5 inch lift
Postby Lumpy » March 10th 2016, 6:35pm
Open drain cock on bottom of radiator. Place big drain pan under there. Antifreeze is toxic to animals and it attracts them. Don't let it just drain on the ground or it will kill your dogs and cats.
Open radiator cap, radiator will now slowly empty through drain cock.
Disconnect upper and lower radiator hoses. Take them to LAPS and ask for replacements.
Disconnect hot water neck on engine. Take thermostat to LAPS and ask for a new one. They're five bucks. Gasket is another dollar.
Place garden hose in any opening - hose, radiator top or bottom, other hoses, eng block, anywhere and everywhere. Let the hose run on gentle for as long as it takes to get clear water flowing out.
Turn heater controls to HEAT and continue to flush.
Disconnect smaller water hoses that enter heater box, passenger side of the firewall - 2 hoses, upper and lower. Let gentle garden hose flow through both directions there as well. The sealant around those hoses where they enter the van is likely old and not sealing perfectly. Consider adding to or replacing the goo that seals there. Factory is the asphalt like stuff. You can use that or RTV rubber.
Flush, flush, flush. Then button it all up with new thermostat installed the right way up. Add 50/50 green coolant and clean water. Some use purified water. I don't. Run engine till it warms up. Keep an eye on the overflow reservoir. As the system "burps" air it will need more water/coolant. The mix doesn't have to be 50/50 to the nth degree. A little coolant, a little water, like that. In hot weather, the only thing coolant does is lubricate and add a little rust resistance. In freezing weather, coolant (anti-freeze) helps keep the water from freezing.
Check the coolant level every couple hours or few miles for the first couple days. It will continue to burp air and need more fluid.
Don't take the main radiator cap off while the system is hot. "You'll put yer eye out".
No critical torques. No special tools. Probably not even any jacking. Just dispose of the drained stuff responsibly. LAPS will take it for disposal or recycle or whatever they do with it.
It is currently February 26th 2021, 7:10pm
Ken2.7
Date: Feb 24 '21
Time: 2:02am
Date: Feb 23 '21
Time: 8:38pm
Date: Feb 23 '21
Time: 8:41pm
Attached by: WinnieVan
WinnieVan
Date: Feb 23 '21
Time: 8:07am
Ken2.7
Date: Feb 22 '21
Time: 11:43pm
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 32 guests
