Battery Tray - Replace/Upgrade?
Postby Raleigh [OP] » April 25th 2016, 12:19am
Hi, I've got a 2002 Astro AWD LS 4.3 and my battery tray is rusted out. Since i'll need to replace it, I'm a) wondering if anyone has any good recommendations for a replacement, and b) has anyone ever modified this space to capacitate a larger group battery?
If you've gotta replace, why not investigate upgrades, right?
RALEIGH, Grand Rapids, MI
-2002 Chevrolet Astro LS AWD 4.3 - April 2016-Current
-1993 Jeep Cherokee 4x4 4.0HO - 2014-2016 (Sold)
-1997 Jeep Cherokee 4x4 4.0 - 2012-2014 (Sold)
-1989 Volvo 740 Sedan 16v - Died
-1994 Volvo 850 Sedan 5cyl - Died
Raleigh
Years of Membership: Raleigh has been a member for 5 full yearsRaleigh has been a member for 5 full yearsRaleigh has been a member for 5 full yearsRaleigh has been a member for 5 full yearsRaleigh has been a member for 5 full years
Topics: 7
Images: 13
Van Model Year: 2002
Extra Info: LS 4.3L AWD
  • Should I replace my Power Steering Pump?
    by gman » December 9th 2020, 5:29am in Engines
    December 9th 2020, 1:21pm
  • What else should I replace during Timing Cover/Pan Gasket?
    by Eddy » February 27th 2021, 8:08pm in Engines
    Last post by zGerman View the latest post
    April 7th 2021, 2:51am
    77
    April 18th 2021, 2:53am
Re: Battery Tray - Replace/Upgrade?
Postby Lumpy » April 25th 2016, 2:44am
Raleigh wrote:
... has anyone ever modified this space to capacitate a larger group battery?
"Capacitate" - I like that!
In my van, the master cyl and related brake stuff is what limits the battery LENGTH. The fender well is what limits the HEIGHT. I could probably DEPTHITATE it by 3/4" or so. Top terminals instead of front side terminals would make that easier. It's pretty cramped getting to the side terminals in mine.
Postby plymouthcranbrook » April 25th 2016, 3:10am
This winter I temporarily put the battery from my 1980 Volare into my van so that I did not have to buy a new one for it until Spring. The battery from the Volare was just a little taller that the Astro battery but even so I had to remove the fuse box and turn the battery sideways to get it in. And it was a top post battery. The negative post was jammed into the underside of the fender. Had a hell of a time removing it last week when I bought a new one for the Astro.
Unless you can lower the new tray when you put in the replacement I can't see how a bigger one could be put in.
plymouthcranbrook
Years of Membership: plymouthcranbrook has been a member for 11 full yearsplymouthcranbrook has been a member for 11 full yearsplymouthcranbrook has been a member for 11 full yearsplymouthcranbrook has been a member for 11 full yearsplymouthcranbrook has been a member for 11 full yearsplymouthcranbrook has been a member for 11 full yearsplymouthcranbrook has been a member for 11 full yearsplymouthcranbrook has been a member for 11 full yearsplymouthcranbrook has been a member for 11 full yearsplymouthcranbrook has been a member for 11 full yearsplymouthcranbrook has been a member for 11 full years
Topics: 16
Extra Info: allwheel drive
Postby Raleigh [OP] » April 25th 2016, 3:16am
Haha "depthitate" - gotta add that to my vocabulary! But actually that sort of describes well what I half meant... So I see the restrictions top, left, and right - but I haven't taken it out yet, is there any give below it that can be used? There's a little room in front of it, but I haven't gone a measured batteries, so I don't know if that alone would help. Also, has anyone done a straight up relocation? If this is a huge pain in the **s then no need to deliberate, however it's a fun question. Back in my Jeep days people sometimes relocated the battery to it's own box somewhere (in-cabin, floor, etc.) in order to make room for things like on-borad air, CAI systems, etc.
Raleigh
Topics: 7
Images: 13
Postby Zebediah III » April 25th 2016, 3:43am
Stealership sells them, they were less than $40
Zebediah III
Images: 16
Extra Info: 383 Crate Motor
Postby Corsemoto » April 25th 2016, 6:13am
OE replacement battery trays are around $100 now so I'd check salvage yards for one that isn't rusted out to clean and paint/seal.
When I removed the rusty battery tray in my van I considered cleaning and soaking in Evapo-Rust (works really well), then painting or sealing with something like POR-15 but powdercoating was actually less costly and time consuming for me since I didn't have any POR-15 on hand. I wouldn't hesitate to do it this way if powdercoating wasn't an option.
I had it chemically dipped and powdercoated as it was cheap, no mess for me and quick turnaround. For a little extra protection, I sprayed the tray with several coats of Plasti Dip before reinstalling.
For the battery, there really isn't much extra room for a larger battery being wedged in the corner of the fender and the PCM mounted on the side. I installed a Diehard Platinum AGM 34/78 (Odyssey AGM) that I liked the specs/quality on and have been happy with it.
Corsemoto
Topics: 39
Images: 13
Extra Info: LT AWD
Postby Raleigh [OP] » April 25th 2016, 4:12pm
Nice job, Corsemoto! Nice battery, too - DieHards have a really good warranty right? I think I'll take your lead and take out my tray, see how bad the rust it, and fix it up if I can. I have a friend that can powder coat smaller items like that for not too much cost. I planned on getting a bunch of small pieces all at once to have him do. Nothing like a good powder coat to keep rust away!
Raleigh
Topics: 7
Images: 13
Postby Lumpy » April 25th 2016, 4:48pm
Dorman has a replacemtnt. I'm not sure if it's plastic or metal.
I made one out of 11ga steel -
Postby Raleigh [OP] » April 25th 2016, 8:14pm
Nice job, Lump - looks like you shaved a lot of weight off as well, I like that idea. :thumbup:
Raleigh
Topics: 7
Images: 13
Postby Corsemoto » April 25th 2016, 8:16pm
Nice tray. From researching a replacement for my van, Dorman doesn't offer a replacement battery tray for our vans (Gen I or II) that I've seen, only a hold down bracket. :shrug:
Corsemoto
Topics: 39
Images: 13
Extra Info: LT AWD
Postby Leeann_93 » April 26th 2016, 1:07am
I used loctite,rust,converter, dark-tinted primer and POR15 chassis coat black on mine.
From this
To this
Postby Raleigh [OP] » April 26th 2016, 5:00pm
Nice Leeann! That's about what mine looks like, maybe a little flakier.
Raleigh
Topics: 7
Images: 13
Postby Star Stuff » July 1st 2020, 5:18pm
Sorry for resurrecting this very old thread, but I'm pulling my rusty battery tray out right now and am having a problem. I have all the bolts removed, and the clip that holds it to the top of the computer box, yet it still seems to be attached somehow to the computer box at the bottom, but I can't see down there. How is it attached?
('99 Safari)
"I call him free who is led solely by reason" Baruch Spinoza
Star Stuff
Fueling (1/2 tank)
Fueling (1/2 tank)
Topics: 12
Postby Leeann_93 » July 1st 2020, 10:05pm
It's not. Pull the PCM straight up.
More pics here:
https://www.astrosafari.com/viewtopic.p ... &start=140
Postby AstroOafAdventurer » September 19th 2020, 12:02am
Did battery trays change around 2000?
Dorman makes a replacement for 2001 & up.
Looks different, anyone know if it'll work in a 97?
97 Astrofari Conversion Van 62k 64k miles, 65k miles
AstroOafAdventurer
Topics: 43
Alias (AKA): Thorsteenster
Extra Info: RWD GMC grille
Postby sfeaver » September 20th 2020, 2:09pm
The computer changed, so its mounting is a bit different.
sfeaver
Firing on 8 Cylinders (L1)
Topics: 29
Images: 22
Van Model Year: 2001
Extra Info: LT RWD 350ci V8
It is currently April 18th 2021, 2:53am
Comments: 13
Time: 9:03pm
Comments: 13
Date: Apr 16 '21
Time: 6:08pm
kvargas1356
Date: Apr 11 '21
Time: 10:20pm
Attached by: jfunkngroove
Comments: 17
Date: Apr 10 '21
Time: 10:38pm
Date: Apr 08 '21
Time: 8:52pm
Users browsing this forum: vinzcent and 11 guests
