brake issue
brake issue
Postby Ghetto Thrasher [OP] » December 13th 2010, 4:58am
Once in a while my brake pedal will rattle. This happens when I forget to wait til the anti-lock light turns on to make sure it works. But lately when my brakes rattle my car will start to steer to right by force. I know i'm having a brake problem but i need to know specifically what's going on.
Ghetto Thrasher
Years of Membership: Ghetto Thrasher has been a member for 10 full yearsGhetto Thrasher has been a member for 10 full yearsGhetto Thrasher has been a member for 10 full yearsGhetto Thrasher has been a member for 10 full yearsGhetto Thrasher has been a member for 10 full yearsGhetto Thrasher has been a member for 10 full yearsGhetto Thrasher has been a member for 10 full yearsGhetto Thrasher has been a member for 10 full yearsGhetto Thrasher has been a member for 10 full yearsGhetto Thrasher has been a member for 10 full years
Topics: 7
Alias (AKA): [email protected]
  • REAR DISC BRAKE KIT !!?? ( WEB SITE ) LINK
    by WRENCH-ED-NESS » November 4th 2020, 12:04am in Brakes
    November 16th 2020, 7:10pm
  • Brake proportioning valve how do you reset
    by Mpoynter » November 5th 2020, 7:19pm in Brakes
    November 6th 2020, 4:17pm
    52
    January 23rd 2021, 5:55pm
Re: brake issue
Postby RECox286 » December 13th 2010, 5:35am
Sounds scarey to me. Anything that goes bump in the night with the brake system is cause for immediate concern, much like a flickering "Bud low" light will cause great panic. Not having much luck with ABS myself,
(none of my trucks' ABS is still functional, and the fact that they are '93's) leaves you and me in the dust waiting on others to chime in. Good luck. At least I can bump you back to the top.
Bob
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Alias (AKA): Uncle Bob
Extra Info: RWD V6 [325K mi]
Re: brake issue
Postby gtkane » December 14th 2010, 4:37am
Your LF rotor is warped.
Constant pressure on the RF rotor vs 50%pressure on the LF=pull to the right when braking.
Replace both front rotors and make sure the lf caliper is not seized/binding(that would have caused the overheating/warpage in the first place.)
User album #4...check it out!
gtkane
Years of Membership: gtkane has been a member for 12 full yearsgtkane has been a member for 12 full yearsgtkane has been a member for 12 full yearsgtkane has been a member for 12 full yearsgtkane has been a member for 12 full yearsgtkane has been a member for 12 full yearsgtkane has been a member for 12 full yearsgtkane has been a member for 12 full yearsgtkane has been a member for 12 full yearsgtkane has been a member for 12 full yearsgtkane has been a member for 12 full yearsgtkane has been a member for 12 full years
Alias (AKA): Astruck
Extra Info: nasty 4.3
Re: brake issue
Postby paintdrying » December 14th 2010, 5:59am
I would agree with the other two posts. It is not a specific problem where one part can be replaced. I would recommend replacing the rubber lines as well. The safety factor concerns me, you can go to a brake shop that gives free inspections and find out if there is an immediate danger. I have had mixed luck going that route.
paintdrying
Topics: 94
Extra Info: 108 000
Return to Brakes
It is currently January 23rd 2021, 5:55pm
Brakes Forum
sumtingbig
in Brakes
Date: Dec 12 '20
Time: 3:51pm
Attached by: icebrrg3rd
icebrrg3rd
in Brakes
Comments: 14
Date: Dec 10 '20
Time: 4:37am
icebrrg3rd
in Brakes
Comments: 14
Date: Dec 10 '20
Time: 12:28am
Dbleeger
in Brakes
Date: Dec 07 '20
Time: 12:12am
pmou
in Brakes
Date: Nov 04 '20
Time: 7:52pm
