ABS light and Brake light go on - 2002 Astro AWD
Postby romeroom [OP] » April 19th 2017, 1:20am
Yesterday the van's ABS light and red Break dash light have started to come on
Here are some details:
1. The go on, not necessarily during the braking procedure; just going down the road will trigger it.
2. After van sits for a while, the lights are off during start-up and going down the road.
3. I performed some hard sudden braking while the ABS/Brake dash lights were off and it did not reproduce the problem.
4. The reservoir is full. However, I noticed the brake fluid is extremely dark. (139k miles on the van.)
Any suggestions were to begin?
'2002 Astro LS, AWD, 41k miles, "W" VIN
romeroom
Years of Membership: romeroom has been a member for 11 full yearsromeroom has been a member for 11 full yearsromeroom has been a member for 11 full yearsromeroom has been a member for 11 full yearsromeroom has been a member for 11 full yearsromeroom has been a member for 11 full yearsromeroom has been a member for 11 full yearsromeroom has been a member for 11 full yearsromeroom has been a member for 11 full yearsromeroom has been a member for 11 full yearsromeroom has been a member for 11 full years
Topics: 38
Van Model Year: 2002
Extra Info: AWD 76000 miles
  • 2000 Astro AWD abs light at startup.
    by asrooster8100 » February 21st 2021, 5:07pm in Brakes
    February 24th 2021, 2:13am
  • Replaced all brake lines, removed ABS on a '91
    by icebrrg3rd » December 10th 2020, 12:43am in Brakes
    December 15th 2020, 2:35am
    20
    March 5th 2021, 2:51pm
Re: ABS light and Brake light go on - 2002 Astro AWD
Postby akforceten » April 19th 2017, 1:26am
98638 100250
akforceten
Years of Membership: akforceten has been a member for 10 full yearsakforceten has been a member for 10 full yearsakforceten has been a member for 10 full yearsakforceten has been a member for 10 full yearsakforceten has been a member for 10 full yearsakforceten has been a member for 10 full yearsakforceten has been a member for 10 full yearsakforceten has been a member for 10 full yearsakforceten has been a member for 10 full yearsakforceten has been a member for 10 full years
Topics: 32
Images: 128
Alias (AKA): akforceten
Extra Info: SLE 4x4 7 inch lift
Postby WimpTech » April 19th 2017, 3:00pm
Yeah, that.
Remember to...
1] replace the bolts once they're off.
2] use flux when soldering joints
3] clean with alcohol when done
4] use electronic safe sealant on the gasket
WimpTech
Firing on 4 Cylinders (L5)
Topics: 38
Images: 322
Alias (AKA): =Wimpy=
Extra Info: AWD 3+1 Lift
Return to Brakes
It is currently March 5th 2021, 2:51pm
Brakes Forum
MATT1488
in Brakes
Date: Feb 16 '21
Time: 10:18am
in Brakes
Date: Feb 10 '21
Time: 3:04am
in Brakes
Date: Feb 09 '21
Time: 9:55pm
in Brakes
Date: Feb 04 '21
Time: 2:19am
MavMark
in Brakes
Date: Feb 03 '21
Time: 11:35pm
