98 Astro Van looses brakes when turning
Postby RaspRoc [OP] » June 22nd 2017, 1:01am
When I am turning right and braking at the same time my brake pedal won't depress allowing me to stop. Instead i feel a metallic rubbing sound with little thumps in it. So then there is panic and frantic pedal pushing which usually works. But only after pushing really hard. I might even jerk the steering wheel back to center a bit in an attempt to get the brakes going. It is very intermittent and there have been a few times where this would happen when not turning.
I replaced the power steering pump. It was then that I noticed the power steering reservoir is always empty. I fill it up and drive it for a bit and then check it later and it's empty. I can't find any leaks, but it does make the grindy whining noise when turning hard either direction. It's not difficult to steer.
So now I'm thinking it's the hydro booster. Any advice or solutions are welcome. I am also wondering if a hydro booster from a different model vehicle would work . I can't find a junker to pull a part off of.
Thanks ya'll.
RaspRoc
Years of Membership: RaspRoc has been a member for 3 full yearsRaspRoc has been a member for 3 full yearsRaspRoc has been a member for 3 full years
Re: 98 Astro Van looses brakes when turning
Postby zimp132 » June 22nd 2017, 3:15am
Sounds similar to an issue I've been researching a lot lately. I don't know this for a fact but read if you find fluid around firewall where hydroboost enters that is a good sign it is the issue. Not sure if this is inside the engine bay or cab side, but looking will be easier than replacing to start with.
zimp132
Years of Membership: zimp132 has been a member for 3 full yearszimp132 has been a member for 3 full yearszimp132 has been a member for 3 full years
Images: 4
Alias (AKA): Zach
Postby WimpTech » June 22nd 2017, 3:36am
Fluid is going somewhere. Did you check all your wheel cylinders? Pads could also be soaked.
Don't buy used brake parts dude, sheesh.
WimpTech
Firing on 4 Cylinders (L5)
Topics: 38
Images: 322
Alias (AKA): =Wimpy=
Extra Info: AWD 3+1 Lift
Postby Coaster » June 22nd 2017, 3:48am
ABS misfiring. front wheel sensor
I LIVE IN NORTH DAKOTA
Coaster
Years of Membership: Coaster has been a member for 8 full yearsCoaster has been a member for 8 full yearsCoaster has been a member for 8 full yearsCoaster has been a member for 8 full yearsCoaster has been a member for 8 full yearsCoaster has been a member for 8 full yearsCoaster has been a member for 8 full yearsCoaster has been a member for 8 full years
Topics: 114
Extra Info: 4.3 cargo 2wd
Postby RaspRoc [OP] » June 22nd 2017, 5:04am
I'll check it out. Thanks guys!
RaspRoc
Postby Leeann_93 » June 22nd 2017, 12:52pm
Coaster wrote:ABS misfiring. front wheel sensor
Yup, definitely.
Postby stanvalp » June 23rd 2017, 4:32am
check your wheel brgs
stanvalp
Years of Membership: stanvalp has been a member for 4 full yearsstanvalp has been a member for 4 full yearsstanvalp has been a member for 4 full yearsstanvalp has been a member for 4 full years
Return to Brakes
It is currently March 5th 2021, 1:48pm
Brakes Forum
MATT1488
in Brakes
Date: Feb 16 '21
Time: 10:18am
in Brakes
Date: Feb 10 '21
Time: 3:04am
in Brakes
Date: Feb 09 '21
Time: 9:55pm
in Brakes
Date: Feb 04 '21
Time: 2:19am
MavMark
in Brakes
Date: Feb 03 '21
Time: 11:35pm
