Brake light diagnosis?
Postby ktthecarguy [OP] » September 15th 2011, 8:37am
Hi there,
My brake light has been on since I bought the van (1992 Safari Xt) and I was wondering if there is a way to diagnose why it is on? So far, I have been able to diagnose the ABS light; it says I need a new sensor for the right rear wheel, and the main valve body is bad (I don't think I will be tackling that one!) so the ABS light stays on.
I have replaced most of the hardware for the regular brake system; new front calipers, new rotors, new rubber hoses, new steel brake lines, new pads, new pins, in the rear resurfaced the drums, replaced one piston, new shoes, and new hardware kit. After bleeding and adjusting the brakes, they feel great, and stop very well.
If the ABS light is on all the time, does that also turn on the brake light? Is there any such thing as brake codes, like the engine and ABS codes?
ktthecarguy
Years of Membership: ktthecarguy has been a member for 10 full yearsktthecarguy has been a member for 10 full yearsktthecarguy has been a member for 10 full yearsktthecarguy has been a member for 10 full yearsktthecarguy has been a member for 10 full yearsktthecarguy has been a member for 10 full yearsktthecarguy has been a member for 10 full yearsktthecarguy has been a member for 10 full yearsktthecarguy has been a member for 10 full yearsktthecarguy has been a member for 10 full years
Alias (AKA): KT
Extra Info: old Swayback
  • 1992 Astro AWD ABS & brake light issues
    by pozo izquierdo » June 20th 2020, 11:26am in Brakes
    Last post by doogaloo View the latest post
    June 20th 2020, 10:26pm
  • The easiest ABS light fix ever!
    by pozo izquierdo » June 28th 2020, 6:40pm in Brakes
    Last post by pozo izquierdo View the latest post
    97
    November 29th 2020, 8:54pm
Re: Brake light diagnosis?
Postby chevymaher » September 15th 2011, 12:29pm
I am not sure about our vans but.I know from having to deal with it, Chrysler does have brake codes.and the light wont go off till you re-set it. Your ABS light you just take out the bulb in the dash.the brake light I would check to see if the emergency brake up all the way,or if its switch working.Someone here will know if there a brake code for our vans.
Postby ktthecarguy [OP] » September 15th 2011, 12:52pm
Thanks Chevymaher, I forgot about the emer brake; i never messed with it. I will check it out today.
ktthecarguy
Alias (AKA): KT
Postby redfury » September 15th 2011, 7:25pm
The other cause for the brake Light would be the proportioning valve. If it is off kilter it will turn on the light. However, if your brakes appear to work properly then its likely the ebrake switch.
redfury
Firing on 8 Cylinders (L3)
Topics: 53
Images: 13
Extra Info: LT 5.7L 4wd
Postby ktthecarguy [OP] » September 20th 2011, 5:52am
redfury wrote:The other cause for the brake Light would be the proportioning valve. If it is off kilter it will turn on the light. However, if your brakes appear to work properly then its likely the ebrake switch.
Thanks for the tip. I did check the switch on the proportioning valve, and put some dielectric grease on the connection. Is there a way to disable the e-brake switch? It looks like the previous owner disconnected the whole system, and I just want to turn off the light, not fix the whole thing.
ktthecarguy
Alias (AKA): KT
Postby redfury » September 20th 2011, 5:58am
Sure, the E brake switch is a simple switch, it either needs to stay open or stay grounded in order to keep from triggering the light.
redfury
Topics: 53
Images: 13
Postby ktthecarguy [OP] » September 22nd 2011, 12:43pm
Well, I played around with it for a while, then gave up. The parking brake cable is disconnected (by PO), and so is the release handle. The switch may be bad; it's got some rust on it. But since the parking brake system isn't working, and the regular brake system is, I put a piece of black electrical tape over the light and called it quits.
Problem finally solved.
ktthecarguy
Alias (AKA): KT
Postby chevymaher » September 22nd 2011, 1:41pm
ktthecarguy wrote:Well, I played around with it for a while, then gave up. The parking brake cable is disconnected (by PO), and so is the release handle. The switch may be bad; it's got some rust on it. But since the parking brake system isn't working, and the regular brake system is, I put a piece of black electrical tape over the light and called it quits.
Ah the old black tape on the light trick.Mine dont work either.I lent my van to someone a long time ago.and it came back broken.He ran over a log with it and messed it up.My issue with a brake light is they usually dont warn you about anything till the pedal hits the floor and you have no brakes.As your whizzing up to a pack of stopped cars,a tree so forth.Would it not be more appropriate if it said something along the lines of,Kiss your @ss goodbye. :rofl: :rofl: :rofl: :auto-crash:
Postby ktthecarguy [OP] » September 23rd 2011, 12:02pm
LOL yes, like the service engine light... should be renamed, "Your engine just died 2 miles ago... sorry I didn't warn you sooner!"
But that would be harder to fit on one little light.
ktthecarguy
Alias (AKA): KT
Postby Jasen » September 23rd 2011, 5:04pm
ktthecarguy wrote: service engine light
That's a typo non of the Mrg ever corrected, it's the S.O.L. light :mrgreen:
I'm a Journeyman woodworker,
Every projects a journey man.
200k
Ultra gauge
Topics: 260
Images: 101
Postby Shad0wXCalibur » September 27th 2011, 5:19am
I'm not sure why but I had a 94 S10 that always had the brake light on. Brakes always worked fine. I was doing some brake work one day and decided to bleed all the old fluid out with new clear fluid and after that, the light went off. I couldn't explain it other than it somehow knew that brake fluid was rotten or had a small air bubble JUST in the right place? No idea. But replacing the fluid turned it off.
1987 Astro
2000 Safari
Shad0wXCalibur
Years of Membership: Shad0wXCalibur has been a member for 9 full yearsShad0wXCalibur has been a member for 9 full yearsShad0wXCalibur has been a member for 9 full yearsShad0wXCalibur has been a member for 9 full yearsShad0wXCalibur has been a member for 9 full yearsShad0wXCalibur has been a member for 9 full yearsShad0wXCalibur has been a member for 9 full yearsShad0wXCalibur has been a member for 9 full yearsShad0wXCalibur has been a member for 9 full years
Topics: 41
Extra Info: Lifted 2wd
Return to Brakes
It is currently November 29th 2020, 8:54pm
Brakes Forum
pmou
in Brakes
Date: Nov 04 '20
Time: 7:52pm
Rando
in Brakes
Date: Nov 03 '20
Time: 8:22pm
Attached by: Godron629
Godron629
in Brakes
Date: Sep 14 '20
Time: 4:12am
Sailing_Faith
in Brakes
Comments: 37
Date: Sep 06 '20
Time: 6:28pm
Sailing_Faith
in Brakes
Comments: 37
Date: Sep 03 '20
Time: 9:36pm
