Ceramic pad reviews; Wagner / Bosch / AC Delco
Postby Sailing_Faith [OP] » November 8th 2018, 6:29pm
I drive Delilah over twisty mountain roads daily and as such she gets new pads pretty regularly.... I drive HWW 1, steep dropoffs with lots of plunges to certain death if you mess up... that kind of thing.
I know that I could get a little shorter stopping distance With organic pads, but have been running ceramics for the last two changes.
Wagner “quiet stop” ceramics have worked well, a bit longer distance and frankly they could be dangerous if driven by someone who is not used to downshifting going over the mountain... that said, they have worked ok for me but I remember noticing the difference when I switched to them.
I just ordered the AC Delco Ceramics, and will report when I put them on soon. According to the reviews I read they may have a bit more bite then the wagners (?).
Looking at the Bosch pads people seem to like them (tells me nothing)....
Has anyone here run all three? Maybe something different and exotic that they really like?
Sailing_Faith
Images: 5
Alias (AKA): s/v Faith
Extra Info: SLT 4.3l RWD G80
Re: Ceramic pad reviews; Wagner / Bosch / AC Delco
Postby WimpTech » November 8th 2018, 6:57pm
Yes... semi-metallic pads per OEM instruction. Coupled with heavy duty thick rotors (not garbage chinese born aftermarket stock rotors), should stop on a dime and give you at LEAST 3 cents change. How's the rears look?
WimpTech
Firing on 3 Cylinders (L5)
Years of Membership: WimpTech has been a member for 4 full yearsWimpTech has been a member for 4 full yearsWimpTech has been a member for 4 full yearsWimpTech has been a member for 4 full years
Topics: 38
Images: 322
Alias (AKA): =Wimpy=
Extra Info: AWD 3+1 Lift
Postby TurnNburn » November 8th 2018, 7:06pm
I use ceramics on mine. definitely longer cold stopping distance which requires a little bit more pedal effort. But once warmed up, I like them. I also live in the mountains with passes that climb and drop over upwards of 4k feet. So brakes are important. They are not noisy and don't dust out that much if that matters to you.
TurnNburn
Green Status (L4)
Green Status (L4)
Alias (AKA): iGoogle
Postby CopperFiremistCopperFiremist is online! » November 8th 2018, 7:20pm
In my experience the ceramics can't handle the weight of these Vans, IIRC they came from the factory with semi metallic. I just recently just switched back to ACdelco semi metallic and they seem to grab a better.
Pullin The Pass
Firing on 1 Cylinder (L2)
Topics: 24
Images: 6
Alias (AKA): B
Extra Info: LS Swap
Postby Leeann_93 » November 9th 2018, 1:27am
Gen 3 vans came with ceramic pads.
I have NAPA Adaptive One pads and Ultra Premium rotors on my Jeep and really like them. Stopping distance is very good, even when towing, and they're lower dusting.
I have NAPA Premium pads on my Astro (the rotors were still good); when next I need to replace them, I'll get Adaptive One pads and NAPA Ultra Premium rotors just like the Jeep.
https://www.napabrakes.com/products/bra ... aptive-one
Postby Sailing_Faith [OP] » December 17th 2018, 8:11pm
I like the idea behind the NAPA Adaptive one pads, it looks like AC Delco is offering the same thing now...
AC Delco advantage pads description
From the picture, they sure look like metallic pads though...
https://www.amazon.com/gp/product/B010GL0BZ6
I’ll give my review soon.
Sailing_Faith
Images: 5
Postby Sailing_Faith [OP] » December 17th 2018, 9:11pm
Went upstairs and they had arrived, here is a closeup if the surface... can see some metallic material but it appears to be mostly ceramic and binder.
Close up of pad
Sailing_Faith
Images: 5
Postby Sailing_Faith [OP] » December 24th 2018, 6:32am
The last set of pads I had were Wagner “ThermoQuiet” QC52 Ceramics. I installed them Sept of 2017. I noticed That I needed a slightly heavier foot to stop, but they were quiet and produced almost no dust.
Here they are after 11,522 miles;
Just a little left before the wear indicator....
Some minor cracks, but very even wear;
Some cracks...
It is interesting that they show more metallic particles....
More metal....
These replaced Wagner “ThermoQuiet” Semi-Metalic pads (MX-52’s)..... I got almost 20k out of them, but almost half of that was my round the country trip.... almost 10k of hwy driving.
I’ll update this later with more feedback on the new AC Delco Pads....
Sailing_Faith
Images: 5
Postby Sailing_Faith [OP] » December 24th 2018, 7:09am
TurnNburn wrote:I use ceramics on mine. definitely longer cold stopping distance which requires a little bit more pedal effort. But once warmed up, I like them. I also live in the mountains with passes that climb and drop over upwards of 4k feet. So brakes are important. They are not noisy and don't dust out that much if that matters to you.
Do you recall which pads you went with? I would really like to hear about experience with different brands.... :thumbup:
Sailing_Faith
Images: 5
Postby Ken2.7 » December 24th 2018, 8:11pm
In an effort to keep this page going I will add that I put AC Delco Advantage Ceramic front brake pads on my Tiger 30K miles ago and they still look great and have created no dust but I plan to change them out because I think it takes too much pressure to make a stop and I will be switching to semi metallic pads. The Tiger weighs 6,000 pounds so I realize it needs good brakes. They have worked great in my mountain driving but quick stops in a city aren't so good; I leave lots of room between me and the guy in front. I saw a good bumper sticker today that said "Warning, watch out for the guy that's behind me."
Ken2.7
Years of Membership: Ken2.7 has been a member for 7 full yearsKen2.7 has been a member for 7 full yearsKen2.7 has been a member for 7 full yearsKen2.7 has been a member for 7 full yearsKen2.7 has been a member for 7 full yearsKen2.7 has been a member for 7 full yearsKen2.7 has been a member for 7 full years
Topics: 32
Alias (AKA): Ken
Extra Info: AWD Provan Tiger GT
Postby Corsemoto » December 25th 2018, 2:54pm
I've said it a bunch of times on here but Hawk LTS (ferro-carbon), great stopping power, feel, zero fade, don't overheat, very kind to rotors, they dust but I care about braking performance not how much they dust.
Corsemoto
Topics: 39
Images: 13
Extra Info: LT AWD
Postby Sailing_Faith [OP] » December 26th 2018, 7:14am
Corsemoto wrote:I've said it a bunch of times on here but Hawk LTS (ferro-carbon), great stopping power, feel, zero fade, don't overheat, very kind to rotors, they dust but I care about braking performance not how much they dust.
Glad to hear it, what pads were you replacing when you installed them? Did they replace another set of ceramic pads?
These are the ones you are talking about right? Hawk Performance HB103F.590 HPS Performance Ceramic Brake Pad https://www.amazon.com/dp/B000CO65VC
Sailing_Faith
Images: 5
Postby Mmusicman » December 26th 2018, 4:07pm
Interesting discussion... regarding the tradeoffs between the longevity, durability, and low dusting of the high-tech ceramics vs the traditional rotor eating braking power of the semi-metalics. Lately I've been using ceramics.
Firing on 6 Cylinders (L5)
Topics: 73
Images: 49
Postby Sailing_Faith [OP] » December 26th 2018, 6:43pm
Mmusicman wrote:Interesting discussion... regarding the tradeoffs between the longevity, durability, and low dusting of the high-tech ceramics vs the traditional rotor eating braking power of the semi-metalics. Lately I've been using ceramics.
Which ceramics are you running, and how happy have you been with them? I would imagine you have an ideal platform to test them with those big ole tires you turn...
Sailing_Faith
Images: 5
Postby Corsemoto » December 26th 2018, 8:51pm
When I bought my 2004 awd with 35k I switched to from OE pads to Hawk LTS on OE rotors and have since replaced those with the same - Hawk LTS and new OE rotors.
LTS not HPS, though I do also run Hawk HPS 5.0 on my Subaru with DBA 4K slotted front rotors and OE rear rotors that replaced Akebono ProACT ceramic pads and Raybestos rotors that suffered from warpage and pad material deposits causing shimmy and vibration.
Mine is 2004 so different part numbers for pads and I don’t trust Amazon so would verify part numbers for your model on the Hawk website: https://www.hawkperformance.com/parts-lookup
Definitely always best to have a “clean” rotor surface when switching to new pads and follow the bedding in procedure.
Corsemoto
Topics: 39
Images: 13
Extra Info: LT AWD
Postby WimpTech » January 4th 2019, 6:03pm
OK... here is my now revised opinion...
I recently bought drilled/ slotted rotors for the StormDrain and they came with ceramics... so I figured i'd try them out.
3500 miles later I can say my braking (GEN2) is (kinda) on-par with my old GEN3. Yes, big positive change. Of course the first few cold stops really suck, but the rest are amaze-bawls.
WimpTech stands corrected. Thanks for the link and 411 TnB... you nailed it as per usual.
https://www.amazon.com/gp/product/B07BV ... UTF8&psc=1
WimpTech
Topics: 38
Images: 322
Postby Corsemoto » January 4th 2019, 6:34pm
There's no way a Gen2 will have comparable brakes to a Gen3 unless your Gen3 brake system was trash. Let us know how they hold up. :2: :lol:
Corsemoto
Topics: 39
Images: 13
Extra Info: LT AWD
Postby TurnNburn » January 4th 2019, 7:16pm
sorry I didn't reply, but wimp nailed the fallow up nicely with the setup I got off of amazon. Really cheap, so I did my research. Overall this company has good reviews. So far I am pleased with them with around 5k miles on them.
TurnNburn
Green Status (L4)
Green Status (L4)
Postby WimpTech » January 4th 2019, 8:40pm
OK maybe not ON PAR... but kinda! Updated above.
WimpTech
Topics: 38
Images: 322
Postby Corsemoto » January 5th 2019, 1:42am
Fair 'nuff Wimpy! Any improvement is good, be interesting to see how the rotors and pads do long term for sure. :thumbup:
Corsemoto
Topics: 39
Images: 13
Extra Info: LT AWD
Return to Brakes
It is currently December 4th 2020, 4:11pm
Brakes Forum
pmou
in Brakes
Date: Nov 04 '20
Time: 7:52pm
Rando
in Brakes
Date: Nov 03 '20
Time: 8:22pm
Attached by: Godron629
Godron629
in Brakes
Date: Sep 14 '20
Time: 4:12am
Sailing_Faith
in Brakes
Comments: 37
Date: Sep 06 '20
Time: 6:28pm
Sailing_Faith
in Brakes
Comments: 37
Date: Sep 03 '20
Time: 9:36pm
