Parking brake e-brake Emergency brake pedal stuck
Postby zerotool [OP] » November 17th 2018, 5:35am
After parking for 2 weeks and i may have had the parking brake on, i pulled the parking brake release lever and the pedal that was in the up position ,went further up 2". I backed up thinking the parking brake was off,then shifted to Drive and the van would not drive forward. I guess the parking brake was on, even though the pedal was at the top. I tried to push the pedal down to put on the E-brake and the pedal was stuck in the up position. So i cut the front brake cable to release the E-brakes. Any idea what went wrong to cause the E-brakes to freeze up? Now i need to wait a few days for the new ACDelco cable. And when i install it , it might still be the state it was in , E-brake still on and pedal at top and not pushing down or only 2" up when release is pulled.
zerotool
Years of Membership: zerotool has been a member for 7 full yearszerotool has been a member for 7 full yearszerotool has been a member for 7 full yearszerotool has been a member for 7 full yearszerotool has been a member for 7 full yearszerotool has been a member for 7 full yearszerotool has been a member for 7 full years
Topics: 25
Images: 12
Alias (AKA): DFW
Extra Info: 184000mi RWD cargo
  • Soft brake pedal
    by Dbleeger » December 7th 2020, 12:15am in Brakes
    December 15th 2020, 3:50am
  • brake pedal clip
    by keith92ext » January 8th 2021, 11:51pm in Brakes
    January 9th 2021, 3:46am
    62
    April 13th 2021, 11:56pm
Re: Parking brake e-brake Emergency brake pedal stuck
Postby Astro Pop » November 17th 2018, 6:24am
What happens if you get down by the fuel tank and yank on the Pbrake cable down there? Any play? If it's still tight going to the back you might be able to loosen the cable. A pair of visegrips for the cable and 1/2" wrench for the adjuster nut. If it's still tight down there then you have to pull drums and see what's going on inside.I hope cutting the cable wasn't a bad move.
Astro Pop
Years of Membership: Astro Pop has been a member for 9 full yearsAstro Pop has been a member for 9 full yearsAstro Pop has been a member for 9 full yearsAstro Pop has been a member for 9 full yearsAstro Pop has been a member for 9 full yearsAstro Pop has been a member for 9 full yearsAstro Pop has been a member for 9 full yearsAstro Pop has been a member for 9 full yearsAstro Pop has been a member for 9 full years
Topics: 41
Images: 9
Alias (AKA): Xfirepop
Van Model Year: 1996
Extra Info: AWD - 5 inch lift
Postby zerotool [OP] » November 18th 2018, 10:08pm
Found the problem ! the mechanic did the Fuel Pump replacement and tightened the driver side tank bolt. he did not see he pinched the parking brake cable while tightening the tank strap bolt. That caused the Parking Brake to engage and immovable PB pedal. We cut the front cable to move the truck out of the street and should have checked the cable near the tank strap bolt. We could have loosened the tank bolt and straightened out the kinked up cable. Though it might be damaged beyond repair anyway. He will likely fix the mistake soon. Things to look out for when replacing the fuel pump. Also i found out the tank at the top a least is metal not plastic.
i already un pinched the cable and straightened it out.
zerotool
Topics: 25
Images: 12
Alias (AKA): DFW
Postby sixsixsixsix is online! » November 18th 2018, 11:26pm
Such fun posts!!
Mike
I Love Peaches also & Wolverines and Gophers
Topics: 39
Images: 1342
Postby AstroWill » November 19th 2018, 12:29am
Wow, I don't know how that could have been missed.
Your tank is steel, they didn't move to plastic tanks until the following year.
Images: 473
Postby zerotool [OP] » November 19th 2018, 1:22am
No jack stands,so he was cramped and tired from working.
The shop that i first went to when i bought the '99 Astro said it had a plastic tank.
zerotool
Topics: 25
Images: 12
Alias (AKA): DFW
Postby AstroWill » November 19th 2018, 2:44am
I hope he is fixing/replacing that cable on his dime.
Images: 473
Postby zerotool [OP] » November 19th 2018, 5:59am
He said he would install the new front Parking Brake cable when i get it ,for free. I undid the tank strap bolt and straightened the rear cable. Fine fellow, i will employ him in the future.
zerotool
Topics: 25
Images: 12
Alias (AKA): DFW
Postby dramey » November 19th 2018, 11:09am
Since the parking brake cable was damaged by your "fine fellow" mechanic, he should pay for the cable and install it for free. I don't think I would trust a mechanic that doesn't even have jack stands.
dramey
Firing on 7 Cylinders (L1)
Extra Info: AWD Cargo Van
Postby Leeann_93 » November 20th 2018, 12:16am
Um, why in the hell didn't a 'mechanic' have jack stands???
Postby zerotool [OP] » November 20th 2018, 4:30pm
He has stands, no need. now , no more tank dropping.
zerotool
Topics: 25
Images: 12
Alias (AKA): DFW
Postby dramey » November 20th 2018, 8:51pm
I am confused. First you say
zerotool wrote:No jack stands,so he was cramped and tired from working.
and then you say
zerotool wrote:He has stands, no need. now , no more tank dropping.
dramey
Postby TurnNburn » November 20th 2018, 9:16pm
pretty wild he was able to get the tank strap tight like that. Did that thing even move with the cable crammed like that? If it did before, you likely burnt your brakes, and the seals in the wheel cylinders.
TurnNburn
Green Status (L4)
Green Status (L4)
Alias (AKA): iGoogle
Like I said...
Postby sixsixsixsix is online! » November 21st 2018, 2:45am
sixsix wrote:Such fun posts!!
Mike
Topics: 39
Images: 1342
Postby zerotool [OP] » November 21st 2018, 3:49am
The mobile mech had jackstands. He did not use his jack stands. No it would not move forward an inch. only reverse a few yards. Odd, when the front cable was cut, the van was driven forward into a parking place even tho the rear cable was still crimped. Always use snap ring pliers when replacing a fuel pump.
zerotool
Topics: 25
Images: 12
Alias (AKA): DFW
Postby AstroWill » November 22nd 2018, 3:07am
Definitely cray cray.
Makes me laugh every time I see it. Can I use this image on other sites?
Almost reminds me of the 'mechanic' that did this and somehow thought that it was acceptable.
https://www.astrosafari.com/viewtopic.p ... 7#p1117706
Images: 473
Return to Brakes
It is currently April 13th 2021, 11:56pm
Brakes Forum
Astroratsun
in Brakes
Date: Apr 11 '21
Time: 7:25am
Gwicz
in Brakes
Date: Mar 27 '21
Time: 1:06pm
MATT1488
in Brakes
Date: Feb 16 '21
Time: 10:18am
in Brakes
Date: Feb 10 '21
Time: 3:04am
in Brakes
Date: Feb 09 '21
Time: 9:55pm
