Vibrating brakes
Vibrating brakes
Postby grueng [OP] » May 27th 2019, 9:48am
1992 2WD Astro LT Starcraft:
When braking cold there is almost no vibration, but when brakes are getting hotter the vibration in car and steering wheel can be huge. After driving for a while without braking is OK again.
And we are not talking about much braking before this happens.
Brake disk and pads where changed some years ago because of the same problem.
Since there is no vibration when cold i suppose it has to be the disc.
Or anyone have other suggestions?
Grunde
grueng
Years of Membership: grueng has been a member for 1 full year
Alias (AKA): Grunde
Extra Info: LT 4.3 RWD Starcraft
Re: Vibrating brakes
Postby jeff's93astro » May 27th 2019, 2:55pm
At the very least you have warped rotors on the front because of the vibration in the wheel. And since I can't drive it lol. I can't tell you if the "shake" is also coming from the front rotors so you possibly have warped drums also
95 Astro 5.3L RWD 3/3 drop
03 Suburban 5.3L 2wd 3/5 drop
jeff's93astro
Topics: 55
Images: 19
Extra Info: CS 4.3L V6 RWD
Postby grueng [OP] » May 27th 2019, 9:33pm
New test drive today. No vibrating when cold, but only a few hard stops it start to vibrate. You feel it in the entire car.
I think it is strange that they should start to vibrate with only little heat / normal braking.
I also braked more to get the discs really hot. Stopped and jacked the car up at the front. The wheels are turning free and the pads are just touching even all the way around.
Grunde
grueng
Alias (AKA): Grunde
Postby fabinator » May 30th 2019, 8:52am
warped rotors will cause vibration whether or not the brakes are applied, just worse when applied. The rotors were probably contaminated with some oily crap, or the brakes were overheated then sat for awhile, causing a hard spot with different friction properties. turning the rotors may help, but you may need new ones if the hard spot goes deep enough.
fabinator
Years of Membership: fabinator has been a member for 2 full yearsfabinator has been a member for 2 full years
Topics: 9
Extra Info: LT EXT AWD
Return to Brakes
It is currently April 11th 2021, 11:59am
Brakes Forum
Astroratsun
in Brakes
Comments: 0
Date: Today
Time: 7:25am
Gwicz
in Brakes
Date: Mar 27 '21
Time: 1:06pm
MATT1488
in Brakes
Date: Feb 16 '21
Time: 10:18am
in Brakes
Date: Feb 10 '21
Time: 3:04am
in Brakes
Date: Feb 09 '21
Time: 9:55pm
Users browsing this forum: ScorpioScorpio is online! and 9 guests
