Rear flex Brake hose
Postby Heavyopp [OP] » January 30th 2012, 4:34am
So I've installed S10 HD springs in the rear of my van lifting the rear by about 5 inches.
Now I need to Install a longer Flexible brake line from the chassis to the rear axle assembly.
I was thinking about using a stainless steel braided line but I can't seem to find the right one. The problem seems to be in the line sizing. I have a 1/4" line coming from the anti-lock brake mechanism. This line connects to the female, input side of the flex hose. At the other end of the hose is a "T" with 2 3/16" outputs going to each wheel cylinder.
Jegs has a line listed but it seems like it has a 3/16" female input on the chassis side.
http://www.jegs.com/i/JEGS-Performance-Products/555/635450/10002/-1?parentProductId=1682813
It's 16 inches long --which is what I want.
Anyone know where to source the proper line or what have you done to defeat the problem.
Thanks
Heavyopp
Fueling (7/8 tank)
Fueling (7/8 tank)
Years of Membership: Heavyopp has been a member for 9 full yearsHeavyopp has been a member for 9 full yearsHeavyopp has been a member for 9 full yearsHeavyopp has been a member for 9 full yearsHeavyopp has been a member for 9 full yearsHeavyopp has been a member for 9 full yearsHeavyopp has been a member for 9 full yearsHeavyopp has been a member for 9 full yearsHeavyopp has been a member for 9 full years
Images: 11
Extra Info: HD S10 rear springs
  • REAR DISC BRAKE KIT !!?? ( WEB SITE ) LINK
    by WRENCH-ED-NESS » November 4th 2020, 12:04am in Brakes
    November 16th 2020, 7:10pm
  • 98 Safari AWD brake line replacing
    by disloyalpick » June 5th 2020, 10:55pm in Brakes
    Last post by disloyalpick View the latest post
    44
    December 1st 2020, 12:43pm
Re: Rear flex Brake hose
Postby RECox286 » January 30th 2012, 5:06am
Can you find a fitting that would connect two hoses ? That might be the long and short solution to your problem.
Bob
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Alias (AKA): Uncle Bob
Extra Info: RWD V6 [325K mi]
Postby Heavyopp [OP] » January 30th 2012, 5:52am
I did look but can't seem to find such a fitting.
I could have the flare name wrong but it should be
27 degree inverted flare fittings going from a 1/4 inch tube female to a 3/16 tube male.
I'll try talking with jegs in the morning when they open.
There's gotta be a solution. I can't be the only 1 who wants to extend their brake line.
I could always move the mount for the line but I'd rather extend the line. I'd have to weld the mounting tab lower.
Heavyopp
Fueling (7/8 tank)
Fueling (7/8 tank)
Images: 11
Postby Lumpy » January 30th 2012, 5:59am
I simply extended the bracket. Used a piece of metal bracket that I had lying around that had 3/8 holes about every inch. Used simple 1/4-20 bolts. Used the same material for an extension for my diff air vent hose thingie.
Postby trapper20 » January 30th 2012, 6:00am
I just mounted it lower, I have an 8" lift and have had no problems. I will agree, a longer line would be ideal, but you can get enough just by lowering the bracket.
trapper20
Years of Membership: trapper20 has been a member for 9 full yearstrapper20 has been a member for 9 full yearstrapper20 has been a member for 9 full yearstrapper20 has been a member for 9 full yearstrapper20 has been a member for 9 full yearstrapper20 has been a member for 9 full yearstrapper20 has been a member for 9 full yearstrapper20 has been a member for 9 full yearstrapper20 has been a member for 9 full years
Topics: 25
Images: 3
Extra Info: Lifted 4x4 V8
Postby Heavyopp [OP] » January 30th 2012, 6:34am
It certainly would be easy enough to lower the bracket but... there's gotta be a better way.
I wonder if I could make a reducer fitting by welding 2 unions together. I think there are steel.
I have a Napa with a great selection of fittings right around the corner. I guess I'll have to stop in and see what I could do.
A welded, make shift reducer would be DOT approved -- Right?
Heavyopp
Fueling (7/8 tank)
Fueling (7/8 tank)
Images: 11
Postby 97cargocrawler » January 30th 2012, 8:56am
I saw this in another thread...not sure which one but you might want to check the part out and see if it will work for you:
97cargocrawler
Topics: 42
Alias (AKA): KING OF OVERKILL
Postby Heavyopp [OP] » January 30th 2012, 4:39pm
Napa 38624 --,Length:17.75",Type of Ends:7/16" - 24 Internal & 3/8" - 24.
That looks like it except its not stainless braided. I'll go see if my local Napa has it. $14.95 online.
Thanks
Heavyopp
Fueling (7/8 tank)
Fueling (7/8 tank)
Images: 11
Postby 97cargocrawler » January 30th 2012, 5:20pm
Stainless braided hose works but man does it look like chit after about a year when the fancy transparent plastic sheath turns an opaque yellowish tint. I spent a small fortune on stainless hoses for my front brakes and they look like absolute garbage 3 years later. Better to buy it without the clear plastic if you can. Some sell it without. Let us know what you find.
97cargocrawler
Topics: 42
Postby Heavyopp [OP] » January 30th 2012, 5:28pm
I wasn't really after the look but rather the squeeze factor of the stainless braid not allowing the hose to expand under pressure.
I just had a chat with Jegs -- no dice there.
I guess I could have it made but I'm just gonna run that line from Napa at $15.
It gives me the extension I want without having to move the bracket down.
Thanks for the part #
Heavyopp
Fueling (7/8 tank)
Fueling (7/8 tank)
Images: 11
Postby 97cargocrawler » January 31st 2012, 7:08am
I'm going to make my own braided lines. You can buy stainless braid and slide it over the fittings, then secure the ends somehow. I can get the braid for free, hence why I'm going that route. As long as the ends cannot move the center cannot bulge out.
97cargocrawler
Topics: 42
Postby Lumpy » January 31st 2012, 3:05pm
97cargocrawler wrote:I'm going to make my own braided lines. You can buy stainless braid and slide it over the fittings, then secure the ends somehow...
Heat shrink tubing is the method in the kit I have. The stainless steel braid is hard to cut because the wire is so tough. Aviation snips just bends the stuff. I have to use dikes and cut a couple of wires at a time till I get all the way through the entire piece of braid. Use your Craftsman dikes because it'll dull the blades and you'll want to exchange them for a new pair.
Postby Shad0wXCalibur » January 31st 2012, 10:32pm
My rear brake hose still has a safe amount of length left even with the S10 HD springs I installed so you should be fine :shrug: . Even if I jack up the van til the wheels come off the ground, the hose is nearly straight but not tight.
1987 Astro
2000 Safari
Shad0wXCalibur
Years of Membership: Shad0wXCalibur has been a member for 9 full yearsShad0wXCalibur has been a member for 9 full yearsShad0wXCalibur has been a member for 9 full yearsShad0wXCalibur has been a member for 9 full yearsShad0wXCalibur has been a member for 9 full yearsShad0wXCalibur has been a member for 9 full yearsShad0wXCalibur has been a member for 9 full yearsShad0wXCalibur has been a member for 9 full yearsShad0wXCalibur has been a member for 9 full years
Topics: 41
Extra Info: Lifted 2wd
Return to Brakes
It is currently December 1st 2020, 12:43pm
Brakes Forum
pmou
in Brakes
Date: Nov 04 '20
Time: 7:52pm
Rando
in Brakes
Date: Nov 03 '20
Time: 8:22pm
Attached by: Godron629
Godron629
in Brakes
Date: Sep 14 '20
Time: 4:12am
Sailing_Faith
in Brakes
Comments: 37
Date: Sep 06 '20
Time: 6:28pm
Sailing_Faith
in Brakes
Comments: 37
Date: Sep 03 '20
Time: 9:36pm
