Parking break shoe permanently expanding??
Postby TooSteep [OP] » August 18th 2019, 3:23am
I changed my pads and rotors last week. First time I drove, after 20 minutes, I got a lot of heat, and a terrible burning smell and smoke from the driver side rear wheel.
Took the wheel off, and the rotor was stuck tight and wouldn't slip off - it seems the parking brake was firmly on. There was already a lot of discoloration on the rotor, and it smelled bad. The parking brake cable was seized, so I changed it, and the mechanism seemed to work properly with the new cable.
But today, after 20 minutes of driving, that wheel started to smell badly and overheat again. Is it possible that with all the heat generated the first time, when the cable was seized, that the parking brake shoe permanently expanded, or the new rotor expanded? Do I need to replace the parking brake shoe and a new rotor again?? Other ideas?
Thank you.
TooSteep
Years of Membership: TooSteep has been a member for 3 full yearsTooSteep has been a member for 3 full yearsTooSteep has been a member for 3 full years
Extra Info: 4.3L AWD
Re: Parking break shoe permanently expanding??
Postby Mmusicman » August 18th 2019, 1:57pm
Try "adjusting" the adjuster first... also make sure nothing else is sticking.
Firing on 6 Cylinders (L5)
Topics: 73
Images: 49
Postby paulo57509 » August 19th 2019, 10:08am
Mmusicman wrote:Try "adjusting" the adjuster first... also make sure nothing else is sticking.
This ^^^
paulo57509
Firing on 7 Cylinders (L1)
Topics: 24
Extra Info: RWD
Postby TooSteep [OP] » August 26th 2019, 12:41am
Thank you. I assume this is the problem.
TooSteep
Return to Brakes
It is currently November 29th 2020, 5:22pm
Brakes Forum
pmou
in Brakes
Date: Nov 04 '20
Time: 7:52pm
Rando
in Brakes
Date: Nov 03 '20
Time: 8:22pm
Attached by: Godron629
Godron629
in Brakes
Date: Sep 14 '20
Time: 4:12am
Sailing_Faith
in Brakes
Comments: 35
Date: Sep 06 '20
Time: 6:28pm
Sailing_Faith
in Brakes
Comments: 35
Date: Sep 03 '20
Time: 9:36pm
