’04 Astro RWD in the rust belt that is Cape Cod. My current goal is to fix my brakes. Finally acquired most of the tools necessary (including the elusive T55 this afternoon, which was missing from amongst all the others I’ve gotten here and there) and got the garage cleared out so I can work inside on a level surface. I suspect sticking caliper sliders are causing my issue, which is occurring at stopping speeds (stop signs, red lights, etc.) where brakes grab and pull to the right with a vibration/stuttering kind of sound (difficult to describe). If I pump the brake pedal rapidly the symptoms disappear (which is why I think it’s a caliper slider). I’m guessing it’s the left caliper that’s the culprit because it’s pulling to the right. At highway speeds no issues, except recently the pedal went much further down while braking one day and now, although I do have braking, it takes a bit more effort and there’s not a lot of room for the pedal to depress further (which is why I fixed my E-brake, at least for the time being - another story...).
Examining my front rotors the edges are so pitted (even when I used a wire brush/angle grinder down to bare metal) I couldn’t see any markings for minimum thickness. Can anyone tell me where I can find that information or what the acceptable minimum rotor thickness should be? These are the vented kind of rotors. The pads appear to be fairly new with decent hardware. Flex hoses and solid lines also appear to be in good shape except left side where the solid line nut is rusted away but connection still feels solid. There may be some fluid leaking there but I can’t tell yet - it’s too wet out and I have to dry everything up really well (put some air/heat on it) so I can detect any leaking. That fluid leak could explain brake pedal going down further recently. Reservoir was full last time I checked but I’ll have to look again in the morning. I thought the fluid looked OK but of course it could have absorbed water since it was added (no service records sucks). I thought the lines were steel but now I’m not sure - in some dry places up higher they turn to a verdigris green color but everywhere else they’re black.
Any info or thoughts appreciated on my brakes. (I know I’ve got to get back and followup with a couple of previous posts re: tools and wandering issue - my busiest time of year has finally come to an end so I have some breathing room and can catch up.)
I’ll check back first thing Sunday morning. Thanks folks!
