Brake line fitting size 2005 astro
Postby Raf123 [OP] » April 9th 2020, 2:27am
Hello everyone,
I did not find that information here so I hope someone will be able to help.
I am looking to buy flexi hoses for my van and read online that there are different thread sizes. I am guessing they are all SAE but I would like a confirmation prior to ordering.
3/8-24 for 3/16'' lines
7/16-24 for 1/4'' lines
Or
10 x 1.0mm for 3/16'' lines
12 x 1.0 mm for 1/4'' lines
I don't want to mix those up.
Thanks for your help
Raf123
Years of Membership: Raf123 has been a member for 2 full yearsRaf123 has been a member for 2 full years
Alias (AKA): Rafael
  • 98 Safari AWD brake line replacing
    by disloyalpick » June 5th 2020, 10:55pm in Brakes
    Last post by disloyalpick View the latest post
  • 1992 Astro AWD ABS & brake light issues
    by pozo izquierdo » June 20th 2020, 11:26am in Brakes
    Last post by doogaloo View the latest post
    June 20th 2020, 10:26pm
    7
    41
    September 19th 2020, 12:49pm
Re: Brake line fitting size 2005 astro
Postby WoodButcher » April 9th 2020, 2:53pm
SAE
The fittings on the ABS are the oddballs on our trucks. IIRC I had to reuse a couple. I cut those lines short and took them off w/ a six point deep well socket.
edit- I see you have an '05, mine are '93 '97 and '02. I shouldn't think they changed on the gen 3 but when I look at my tool box needing both SAE and Metric on the same truck you never know.
WoodButcher
Firing on 4 Cylinders (L6)
Years of Membership: WoodButcher has been a member for 9 full yearsWoodButcher has been a member for 9 full yearsWoodButcher has been a member for 9 full yearsWoodButcher has been a member for 9 full yearsWoodButcher has been a member for 9 full yearsWoodButcher has been a member for 9 full yearsWoodButcher has been a member for 9 full yearsWoodButcher has been a member for 9 full yearsWoodButcher has been a member for 9 full years
Topics: 30
Images: 509
Alias (AKA): Bruce
Extra Info: 5.7L RWD
Postby AstroWill » April 9th 2020, 6:57pm
Just order the proper hoses for your vehicle. If you are redoing the hard lines, you can reuse the fittings, or buy them new they are all available at LAPS or online. The ABS ones are an oddball like the WB said but they are available virtually everywhere. Oreilly as an example has them for ~$1.50 each.
Topics: 106
Images: 437
Postby Raf123 [OP] » April 14th 2020, 6:18pm
Alright, thanks so much guys! Hopefully I won't need to redo the hardlines as well.
Raf123
Alias (AKA): Rafael
Postby Leeann_93 » April 14th 2020, 11:10pm
Regular brake line nuts are 7/16-24
ABS nuts are ½-20
I got the ones I needed that same day at NAPA and bought multi-packs on Amazon.
Return to Brakes
It is currently September 19th 2020, 12:49pm
Brakes Forum
Attached by: Godron629
Godron629
in Brakes
Date: Sep 14 '20
Time: 4:12am
Sailing_Faith
in Brakes
Comments: 35
Date: Sep 06 '20
Time: 6:28pm
Sailing_Faith
in Brakes
Comments: 35
Date: Sep 03 '20
Time: 9:36pm
in Brakes
Comments: 86
Date: Sep 02 '20
Time: 4:18am
in Brakes
Comments: 86
Date: Sep 01 '20
Time: 10:15pm
