No power steering or brakes after new pump and hydroboost?!?
Postby troy1123 [OP] » April 20th 2020, 2:29pm
Feel like I am going insane over here trying to fix this thing. I am spending way more time and money trying to fix the power steering system than I did doing my v8 swap!! So here's what happened
-Van had no power steering at low speed, especially when the brakes were pressed.
troy1123
Years of Membership: troy1123 has been a member for 1 full year
Alias (AKA): Troy
Extra Info: 5.7 Vortec V8 Swap
  • no brakes, e-brake light on, losing fluid
    by Mberry0614 » February 13th 2021, 9:52pm in Brakes
    February 14th 2021, 4:49pm
  • What is estimated cost to replace brakes?
    by Gabor Latte » September 13th 2020, 10:23pm in Brakes
    Last post by M_a_t_t View the latest post
    September 18th 2020, 6:48am
    February 27th 2021, 1:44pm
Re: No power steering or brakes after new pump and hydroboos
Postby TBLBill » April 20th 2020, 2:40pm
Does the pump whine? Did you prime the pump when you installed it? How did you bleed the system? Since those parts are new you probably just have air in the system.
TBLBill
Years of Membership: TBLBill has been a member for 3 full yearsTBLBill has been a member for 3 full yearsTBLBill has been a member for 3 full years
Topics: 12
Images: 42
Extra Info: LS RWD
Postby troy1123 [OP] » April 20th 2020, 6:34pm
oops i did not mean to post this. I will answer your questions on my other post. its the most recent one in the brakes section. sorry
troy1123
Alias (AKA): Troy
Return to Brakes
It is currently February 27th 2021, 1:44pm
Brakes Forum
MATT1488
in Brakes
Date: Feb 16 '21
Time: 10:18am
in Brakes
Date: Feb 10 '21
Time: 3:04am
in Brakes
Date: Feb 09 '21
Time: 9:55pm
in Brakes
Date: Feb 04 '21
Time: 2:19am
MavMark
in Brakes
Date: Feb 03 '21
Time: 11:35pm
