Where does this cable mount attach?
Postby Rando [OP] » November 3rd 2020, 8:24pm
I was working on my rear suspension and detached the parking brake cable and managed to forget where it went. :oops: I tried bending it around and it didn't particularly want to attach to any of the bolts. Anyone have any insight?
Rando
Alias (AKA): Andrew
Re: Where does this cable mount attach?
Postby sixsix » November 4th 2020, 3:17pm
Pretty sure if you search for lower driver's side shock mount - you will see where it goes.
Don't quote me on that one... I'll go look...
Wow - harder to find than I thought - I also tried " astrosafari.com emergency brake line " in g00gull.
Got this - but the year change - careful - the rears are diff - Disc Brakes.
https://www.astrosafari.com/viewtopic.php?f=45&t=104194
I am fairly sure it goes on somewhere near that side's lower shock mount - bracket...
Good Luck!
And Pray For the USA and Trump!
Well, after all... what would Banacek say ?... Anyone that condones the actions of the American People during the Storming of the Capitol are as complicit as the Assholes themselves.
But no way does this let the Democrats or the MSM off the Hook.
Firing on 5 Cylinders (L5)
Topics: 38
Images: 1320
Postby Rod's Trucks » November 4th 2020, 5:25pm
That pic is of the passenger side of the axle assembly.
That bracket should have a hole in it that fits on the lower shock mounting bolt.
On my '98, it is on the inside end of that lower mounting bolt.
Rod J
Issaquah, WA
Rod's Trucks
Topics: 30
Images: 55
Alias (AKA): Rod and/or WE7X
Postby TBLBill » November 4th 2020, 7:16pm
Rod's Trucks wrote:That pic is of the passenger side of the axle assembly.
Rod J
Issaquah, WA
Same here, I just did shocks yesterday on my '99. It goes on the inboard side of the passenger side shock mount, on the outside of the mount so the bolt goes through it first and then through the mount/shock. There's a little tab on mine that holds the bracket in a specific position compared to the mount so it doesn't rotate.
EDIT: Based on the picture you'll also need to bring the cable from routing behind the shock to being in front. You'll have to pull the bottom bolt to put the bracket in place anyway.
TBLBill
Years of Membership: TBLBill has been a member for 2 full yearsTBLBill has been a member for 2 full years
Topics: 12
Images: 42
Extra Info: LS RWD
Postby pmou » November 4th 2020, 7:53pm
I guess this must be different on 2003s? here's mine:
drivers side (from front)
passenger (from rear)
pmou
Topics: 7
Alias (AKA): Paul
Extra Info: V6 AWD 3.73 no LSD
Postby Leeann_93 » November 4th 2020, 11:48pm
2003-2005 has rear disc, so that's different from his. He's got a '97.
Return to Brakes
It is currently January 21st 2021, 3:32pm
Brakes Forum
sumtingbig
in Brakes
Date: Dec 12 '20
Time: 3:51pm
Attached by: icebrrg3rd
icebrrg3rd
in Brakes
Comments: 14
Date: Dec 10 '20
Time: 4:37am
icebrrg3rd
in Brakes
Comments: 14
Date: Dec 10 '20
Time: 12:28am
Dbleeger
in Brakes
Date: Dec 07 '20
Time: 12:12am
pmou
in Brakes
Date: Nov 04 '20
Time: 7:52pm
