Soft brake pedal
Soft brake pedal
Postby Dbleeger [OP] » December 7th 2020, 12:15am
My brake pedal is very soft and nearly goes to the floor before the brakes kick in. The brakes seem to work fine asides from that. My first thought was that I was low on brake fluid or I have air in my lines, so I checked the two reservoirs. The larger reservoir is filled and the smaller one is completely empty. I'll bleed the brakes next, but am hoping to get some input on this issue. I also traced the brake lines and didn't see any signs of leakage.
I'm not familiar with a dual reservoir master cylinder and am not sure if there should be any brake fluid in the smaller reservoir or what the purpose of the black liner is. What are your thoughts/explanations? I've attached a photo of the smaller reservoir.
Dbleeger
Topics: 5
Van Model Year: 1991
Extra Info: GT Tiger
  • brake pedal clip
    by keith92ext » January 8th 2021, 11:51pm in Brakes
    January 9th 2021, 3:46am
  • REAR DISC BRAKE KIT !!?? ( WEB SITE ) LINK
    by WRENCH-ED-NESS » November 4th 2020, 12:04am in Brakes
    November 16th 2020, 7:10pm
    81
    March 2nd 2021, 5:28pm
Re: Soft brake pedal
Postby chevymaher » December 7th 2020, 2:20am
There is your problem fill the smaller one. Check the rear brakes they probably worn out that is where the fluid went. Rubber seal keep air from getting in the system if you dont let it run dry.
Postby Old Barney » December 7th 2020, 2:24am
I'll try to explain: the black piece still in the reservoir has to be removed as the fluid is under that black piece still there. Just pull up and out with your fingers. When reinstalling the cover and the reservoir is full put the black piece back in the cover and reinstall the cover. This soft gasket keeps the fluid in when the wheel cylindersare being pulled back in releasing the brakes. and when the brakes are applied this black soft gasket is sucked into the reservoir slightly. I would guess it could be called a diaphragm.
Old Barney
Years of Membership: Old Barney has been a member for 6 full yearsOld Barney has been a member for 6 full yearsOld Barney has been a member for 6 full yearsOld Barney has been a member for 6 full yearsOld Barney has been a member for 6 full yearsOld Barney has been a member for 6 full years
Topics: 23
Images: 47
Alias (AKA): Barney
Extra Info: awd
Postby Rod's Trucks » December 7th 2020, 3:16am
IT also reduces the ability of the brake fluid to absorb moisture. Brake fluid is 'hydrscopic' ( I think I spelled that correctly).
That means it likes to absorb moisture. Additional moisture in the fluid reduces the boiling point, and helps promote corrosion in the piping and other components....bad juju!
That is one of the reasons to flush the brake system occasionally... to get rid of any moisture contaminated fluid.
Rod J
Rod's Trucks
Topics: 32
Images: 55
Alias (AKA): Rod and/or WE7X
Postby AstroWill » December 8th 2020, 5:40am
The fluid is below that rubber :)
Images: 472
Postby Dbleeger [OP] » December 8th 2020, 8:26pm
Got it! Thanks, everybody. Filled up the front reservoir and that fixed the issue. I haven't had a chance to look at the rear brake pads to see if they are worn out because of the weather, but I will once it clears up.
Dbleeger
Topics: 5
Postby AstroWill » December 15th 2020, 3:50am
Congrats! Glad you got it figured out.
Would love to see more of your Tiger :)
Images: 472
Return to Brakes
It is currently March 2nd 2021, 5:28pm
Brakes Forum
MATT1488
in Brakes
Date: Feb 16 '21
Time: 10:18am
in Brakes
Date: Feb 10 '21
Time: 3:04am
in Brakes
Date: Feb 09 '21
Time: 9:55pm
in Brakes
Date: Feb 04 '21
Time: 2:19am
MavMark
in Brakes
Date: Feb 03 '21
Time: 11:35pm
