2000 Astro AWD abs light at startup.
Postby asrooster8100 [OP] » February 21st 2021, 5:07pm
When the van is first started the abs light comes on immediately. When you begin to drive the brake light also comes on. I also have no speedometer when this is happening. When the temp outside gets above 50 degrees everything seems to be working fine. Also, when I try and pull abs codes I get a link state error so I can not get the codes from the abs.
I have pulled the abs module and resoldered connections but am still getting the same symptoms. Any ideas would be much appreciated!
asrooster8100
Years of Membership: asrooster8100 has been a member for 3 full yearsasrooster8100 has been a member for 3 full yearsasrooster8100 has been a member for 3 full years
Extra Info: Overland 4
  • AWD Abs Module
    by Mberry0614 » December 14th 2020, 9:26pm in Brakes
    Last post by Mberry0614 View the latest post
    December 15th 2020, 7:36pm
  • Blank off ABS port to f/r/h caliper to get 01 AWD van home
    by Astrojohn » February 18th 2021, 7:07am in Brakes
    Last post by Astrojohn View the latest post
    February 19th 2021, 8:02am
    44
    March 6th 2021, 12:25pm
Re: 2000 Astro AWD abs light at startup.
Postby asrooster8100 [OP] » February 23rd 2021, 1:56pm
Any thoughts or suggestions would be much appreciated.
Thanks
asrooster8100
Postby WimpTech » February 23rd 2021, 4:47pm
What are you using to read codes? Typically you would need a TECH2 or similar to look at BCM codes like that.
It sounds to me like a flakey wheel speed sensor; is it AWD?
WimpTech
Firing on 4 Cylinders (L5)
Topics: 38
Images: 322
Alias (AKA): =Wimpy=
Extra Info: AWD 3+1 Lift
Postby asrooster8100 [OP] » February 23rd 2021, 5:56pm
I am using a harbor freight scanner that reads abs codes. I do not have any issues getting codes from my other 2000 astro. I feel the abs system is not getting power. I tested for power at the abs module and I am getting 12v at the 2 pin connector with the heavy gauge red and black wires, but I think this only powers the motor but I am not sure as I do not have the wiring diagrams for the van. It is AWD with the np233 transfer case conversion.
Thanks
asrooster8100
Postby AstroWill » February 23rd 2021, 6:34pm
So, lets get you the wiring diagrams first. The GM techline eSI is the digital factory service manual. It will have all of the diagrams and repair instructions for your van(see links in sig).
I also have a page there about setting up virtualbox. Other than downloading the .ova and virtualbox, should take less than 10min to get set up.
If the module isn't responding, it's an issue with the power/ground or communication wiring or the module itself.
The speedometer issue could be a few things, when it goes out do you still get a reading from the OBD2 for speed?
Images: 472
Postby asrooster8100 [OP] » February 23rd 2021, 11:03pm
I am having issues downloading the files.
I am not getting speed reading from the obd2 as well. The weirdest thing is that if the temp outside is above 50 degrees everything works perfect. I am suspecting bad solder connections in the pcm but am trying to eliminate as much as possible before going that far.
Thanks
asrooster8100
Postby Sparkydog » February 23rd 2021, 11:30pm
I believe the ABS light and brake light on together is the classic symptom of ABS module solder joints with cracks. And when temp changes the joint "heals". I did the DIY solder joint repair and it's been good ever since.
Sparkydog
Years of Membership: Sparkydog has been a member for 1 full year
Topics: 12
Postby asrooster8100 [OP] » February 23rd 2021, 11:43pm
I have already performed the solder repair on the ABS module with go luck. It also doesn't explain no speedo and shifting issues.
Thanks
asrooster8100
Postby Leeann_93 » February 24th 2021, 12:38am
No speedo and shifting issues point to a bad ground to me.
Postby asrooster8100 [OP] » February 24th 2021, 12:54am
I am thinking possibly ground as well. I am just hoping to get a hold of some diagrams so I can start to troubleshoot this thing.
asrooster8100
Postby AstroWill » February 24th 2021, 2:13am
A bad speed sensor/connector/wiring can also cause shifting issues.
asrooster8100 wrote:When the van is first started the abs light comes on immediately. When you begin to drive the brake light also comes on.
That is common with virtually all ABS issues on vans that have dynamic rear proportioning as it requires the ABS to be functional.
Images: 472
Return to Brakes
It is currently March 6th 2021, 12:25pm
Brakes Forum
MATT1488
in Brakes
Date: Feb 16 '21
Time: 10:18am
in Brakes
Date: Feb 10 '21
Time: 3:04am
in Brakes
Date: Feb 09 '21
Time: 9:55pm
in Brakes
Date: Feb 04 '21
Time: 2:19am
MavMark
in Brakes
Date: Feb 03 '21
Time: 11:35pm
