2000 safari awd
2000 safari awd
Postby Spacetruckin [OP] » May 24th 2021, 8:24pm
Just picked up this van, finding when I make a complete stop and let off the brakes the van doesn't creep forward like a typical automatic, previous owner said he did new pads and calipers, what could be causing that? Just nervous that the brakes are not letting off completely and i don't wanna eat thru pads/be fighting the brakes to drive??
Spacetruckin
Extra Info: Awd
  • 2000 Astro AWD abs light at startup.
    by asrooster8100 » February 21st 2021, 5:07pm in Brakes
    Last post by WimpTech View the latest post
    March 13th 2021, 8:40pm
  • '05 AWD New Master Cylinder?
    by Crombley » February 11th 2021, 8:08pm in Brakes
    February 12th 2021, 7:01pm
    30
    August 5th 2021, 3:06am
Re: 2000 safari awd
Postby tungtide » May 24th 2021, 9:17pm
Mine stay put also. Never thought it to be a problem.
Ken
tungtide
Topics: 36
Images: 22
Alias (AKA): tungtide
Van Model Year: 2002
Re: 2000 safari awd
Postby The Drummer » May 24th 2021, 10:51pm
Get it to a small incline in neutral ,if it aint moving you may have draging brakes ,clogues brake hoses ,e brake not releasing completely , also try and drive it slow for a bit and not use the brakes ,then carfuly touch the wheel,discs etc , dont burn your self , see if any of the wheels are hot compare to the other wheels , so if you have sticky brakes the wheel that does will be warm/hot compare to the others , you may also jack the van and manualy turn the wheels ,brake smell is also a way to know something s up .
''USE THE TORQUE LUKE ''
and beware of trees ,them nasty wooden things are evil .
The Drummer
Years of Membership: The Drummer has been a member for 9 full yearsThe Drummer has been a member for 9 full yearsThe Drummer has been a member for 9 full yearsThe Drummer has been a member for 9 full yearsThe Drummer has been a member for 9 full yearsThe Drummer has been a member for 9 full yearsThe Drummer has been a member for 9 full yearsThe Drummer has been a member for 9 full yearsThe Drummer has been a member for 9 full years
Topics: 16
Images: 49
Extra Info: SLT 4.3 AWD
Re: 2000 safari awd
Postby Mmusicman » May 25th 2021, 12:07am
If the brakes are sticking... the wheels will be extra hot.
Firing on 1 Cylinder (L6)
Years of Membership: Mmusicman has been a member for 8 full yearsMmusicman has been a member for 8 full yearsMmusicman has been a member for 8 full yearsMmusicman has been a member for 8 full yearsMmusicman has been a member for 8 full yearsMmusicman has been a member for 8 full yearsMmusicman has been a member for 8 full yearsMmusicman has been a member for 8 full years
Topics: 75
Images: 61
Re: 2000 safari awd
Postby Huckleberry » May 25th 2021, 12:34am
If you know brakes, get in there and make sure
the caliper pins are lubed with silicone grease.
The PO may not have known completely what he was doing.
If you don't know brakes, take it into somewhere
like Les Schwab that'll do a free brake assessment.
Let them know the situation so they'll check thoroughly.
Stopping is more important than going.
Huckleberry
Years of Membership: Huckleberry has been a member for 5 full yearsHuckleberry has been a member for 5 full yearsHuckleberry has been a member for 5 full yearsHuckleberry has been a member for 5 full yearsHuckleberry has been a member for 5 full years
Topics: 29
Extra Info: RWD
Re: 2000 safari awd
Postby Mmusicman » May 25th 2021, 1:02am
Huckleberry wrote:Stopping is more important than going.
Maybe where YOU live... :lol: :lol: :lol:
Topics: 75
Images: 61
Re: 2000 safari awd
Postby Huckleberry » May 25th 2021, 2:11am
True dat!
I go up and down hills a lot,
and there's not very many carjackings. :D
Huckleberry
Topics: 29
Extra Info: RWD
Return to Brakes
It is currently August 5th 2021, 3:06am
Brakes Forum
Danno95
in Brakes
Date: Jul 18 '21
Time: 3:09am
Danno95
in Brakes
Date: Jul 17 '21
Time: 11:08pm
Attached by: Tegnus
Tegnus
in Brakes
Date: Jun 21 '21
Time: 11:04pm
Ray M
in Brakes
Date: Jun 04 '21
Time: 12:48pm
Kiwishes
in Brakes
Date: May 19 '21
Time: 8:42pm
