Front Brakes pads tight fit
Postby Maxximum_44 [OP] » April 10th 2012, 7:05pm
Hey guys, I changed the front pads on the 03' and had to knock out the old pads(pass. and driver) with a mallet to get them out. I used two C clamps on the dual piston calipers per FSM.
After greasing and lubing everything as recommended, I put everything back together. My concern is the pads I installed didn't exactly "slide" back and forth on the new guides smoothly. they're a bit tight.
Should I have grinded some material off the tabs or whatever so that they move freely? or do I want them to have a little resistance?
Image#6 and #5
03 - Astro - AWD - 4.36L V6 - Original - Motor/Trans-New Exhaust-
Maxximum_44
Years of Membership: Maxximum_44 has been a member for 9 full yearsMaxximum_44 has been a member for 9 full yearsMaxximum_44 has been a member for 9 full yearsMaxximum_44 has been a member for 9 full yearsMaxximum_44 has been a member for 9 full yearsMaxximum_44 has been a member for 9 full yearsMaxximum_44 has been a member for 9 full yearsMaxximum_44 has been a member for 9 full yearsMaxximum_44 has been a member for 9 full years
Topics: 12
Images: 9
Alias (AKA): Maxx
Extra Info: LT 4.3L V6 AWD
Re: Front Brakes pads tight fit
Postby Dirk » April 10th 2012, 7:22pm
They should be able to slide a little, did you clean the caliper bracket?
1985 Astro conversion, engine type N 4.3 4BBL
If you can't fix it with a hammer you've got an electrical problem!
Parts are cheap breakdowns expensive.
Don't worry about miles per gallon, worry about smiles per gallon!
Dirk
Firing on 8 Cylinders (L1)
Years of Membership: Dirk has been a member for 10 full yearsDirk has been a member for 10 full yearsDirk has been a member for 10 full yearsDirk has been a member for 10 full yearsDirk has been a member for 10 full yearsDirk has been a member for 10 full yearsDirk has been a member for 10 full yearsDirk has been a member for 10 full yearsDirk has been a member for 10 full yearsDirk has been a member for 10 full years
Images: 11
Extra Info: 4.3L 4BBL
Postby flores5996 » April 10th 2012, 7:31pm
make sure you clean the caliper bracket really good before you put hardware back on. that should solve your problem.
flores5996
Years of Membership: flores5996 has been a member for 9 full yearsflores5996 has been a member for 9 full yearsflores5996 has been a member for 9 full yearsflores5996 has been a member for 9 full yearsflores5996 has been a member for 9 full yearsflores5996 has been a member for 9 full yearsflores5996 has been a member for 9 full yearsflores5996 has been a member for 9 full yearsflores5996 has been a member for 9 full years
Extra Info: conversion 4.3
Postby Jasen » April 10th 2012, 7:59pm
As the others said, they should move freely, but I wouldn't go as far as a grinder. Propbably just need a good cleaning,scraping, scotch-brite padding.
I'm a Journeyman woodworker,
Every projects a journey man.
200k
Ultra gauge
Topics: 260
Images: 101
Postby Maxximum_44 [OP] » April 10th 2012, 8:25pm
I wire brushed them pretty good spayed brake cleaner and repeated. Didn't have this problem for the rear brakes when I did them last year.
Maxximum_44
Topics: 12
Images: 9
Alias (AKA): Maxx
Postby Lumpy » April 11th 2012, 6:29am
I'm not familiar with those newer disc brakes. What is the component labeled #4 in the diagram above?
Postby Maxximum_44 [OP] » April 11th 2012, 4:32pm
Sorrry lump. this is only my 3rd brake job(second on this truck) so im not sure what its called. its the steel part of the caliper where the the brakes and guild (rails?)sit on.
Image I have pic of them from the rears
Image The piston part sits over this stuff
Maxximum_44
Topics: 12
Images: 9
Alias (AKA): Maxx
Postby Maxximum_44 [OP] » April 11th 2012, 4:36pm
After looking at those old pics from last years job, I noticed why they fit easier. The mounting tabs on the rear brakes are different than the front brakes. Those rears just fell out. I had to pound the fronts out :think:
Maxximum_44
Topics: 12
Images: 9
Alias (AKA): Maxx
Postby Lumpy » April 12th 2012, 12:34am
That #4 piece looks interesting. In my 89 discs, I have the equivalent of #1 (the caliper) plus the piston, plus the two pads (and the long bolts. The pads just sit there. Some of them have a little simple clip thing but essentially they just fall out, as you describe for your rear brakes, when you pull the long bolts.
Disc brakes are cool. One of the easiest jobs I've ever learned how to do. Drums are a PITA. But discs are cool.
Postby Maxximum_44 [OP] » April 12th 2012, 4:09am
haha, never done drums. Hell, this is only my 3rd brake job. Disk swap was pretty straight forward (besides the snug fit up front).
Maxximum_44
Topics: 12
Images: 9
Alias (AKA): Maxx
Return to Brakes
It is currently January 19th 2021, 10:22am
Brakes Forum
sumtingbig
in Brakes
Date: Dec 12 '20
Time: 3:51pm
Attached by: icebrrg3rd
icebrrg3rd
in Brakes
Comments: 14
Date: Dec 10 '20
Time: 4:37am
icebrrg3rd
in Brakes
Comments: 14
Date: Dec 10 '20
Time: 12:28am
Dbleeger
in Brakes
Date: Dec 07 '20
Time: 12:12am
pmou
in Brakes
Date: Nov 04 '20
Time: 7:52pm
