2004 GMC Master Cylinder Resevoir ?
Postby bigdaddie [OP] » August 2nd 2012, 11:42pm
Hi Folks, i have enjoyed your forum for a while now, first time i have not found an answer to my question..........
I love these vehicles, i now own a 2004 GMC safari AWD, 147,000 miles, my first was a 1996 GMC AWD that was totaled by a little Ol' Lady rear-ending me, folded the van half way up the chassis......anyway....
I have a leak in my master cylinder reservoir, its actually loose, i can wiggle it a little, and i'm loosing fluid at the base where it mounts to the Master cylinder....
My question is, the reservoir sets into 2 rounds holes on the master cylinder, and 2 pins go through the master cylinder to hold the reservoir in place. I've tried pulling these out with plyers, and they don't move, i'm afraid to try and use a center punch, seems that would expand them to the point that i couldn't remove them..............
Any Help??
Thanks
bigdaddie
Years of Membership: bigdaddie has been a member for 8 full yearsbigdaddie has been a member for 8 full yearsbigdaddie has been a member for 8 full yearsbigdaddie has been a member for 8 full yearsbigdaddie has been a member for 8 full yearsbigdaddie has been a member for 8 full yearsbigdaddie has been a member for 8 full yearsbigdaddie has been a member for 8 full years
Alias (AKA): bigdaddie
  • '05 AWD New Master Cylinder?
    by Crombley » February 11th 2021, 8:08pm in Brakes
    February 12th 2021, 7:01pm
    31
    April 13th 2021, 5:15pm
Re: 2004 GMC Master Cylinder Resevoir ?
Postby Corsemoto » August 3rd 2012, 2:20pm
Find or modify a punch (or an actual roll pin punch) that just fits over the edge of the pin so it won't try and expand, penetrating oil may help loosen. Once removed, you may be able to match up the two o-rings that seal the reservoir to master cylinder. If you do, make sure to use o-rings suitable for brake fluid - EPDM (not Buna-N or Viton).
If not you can buy a new reservoir which comes with o-rings and retaining pins.
Corsemoto
Topics: 39
Images: 13
Extra Info: LT AWD
Postby bigdaddie [OP] » August 3rd 2012, 4:11pm
Corsemoto wrote:Find or modify a punch (or an actual roll pin punch) that just fits over the edge of the pin so it won't try and expand, penetrating oil may help loosen. Once removed, you may be able to match up the two o-rings that seal the reservoir to master cylinder. If you do, make sure to use o-rings suitable for brake fluid - EPDM (not Buna-N or Viton).
thanks, i will try the larger size punch, i have a set, just totally forgot about them.
I already purchased a new reservoir from RockAuto, comes with the new O rings and Pins.
Thanks for the help.
bigdaddie
Postby bigdaddie [OP] » August 3rd 2012, 10:23pm
Maybe i need to ask another question relating to this, at least it's still a brake problem,
I replaced the reservoir, thanks for the tip, it was fairly easy, i think the O ring on the from portion was what was bad, but i'm glad i replaced the entire reservoir.
But i still have a problem with my dash warning lights, The ABS and Brake warning lights come on after i apply pressure to the brakes a couple, maybe three times.
I thought the problem was the leaking reservoir, causing me to loose fluid and pressure to the system that was originally the reason for these warning lights, evidently not.
I also just replaced the front brake pads, not the rotors, they were still in good shape, but the pads were just about gone, especially on the inside pad.
Could this ABS warning light be caused from just dirt and dust from the old pads, or maybe a bad sensor??
If a bad sensor, how do you check the sensors to determine if one or both are bad??
bigdaddie
Postby chevymaher » August 3rd 2012, 11:56pm
Bleed the brakes maybe you got air in a line. That will do it.
Clean the sensors with brake cleaner. Metal shavings interfere with them and can cause it to.
I don't know if the newer vans have it or not, but a plug at the bottom of the fluid reservoir. Fluid level sensor. Dirty conection where it plugs in if it has one.
Topics: 91
Postby Corsemoto » August 4th 2012, 2:02am
Definitely start by bleeding brakes to make sure there isn't air but if both ABS and brake lights are on, it is sounds like it is ebcm related which is not uncommon.
Here is some more info on testing ebcm and related sensors:
http://www.modulemaster.com/store/instructions/ABS/Chevy-Truck_Astrovan_ABS.pdf
https://www.astrosafari.com/viewtopic.php?f=45&t=13496
Corsemoto
Topics: 39
Images: 13
Extra Info: LT AWD
Postby bigdaddie [OP] » August 4th 2012, 3:53pm
thanks for the information.
I hadn't driven the Van since i installed the new reservoir, so this morning i took it for about a 20 mile drive.
The Brake light and ABS light prior to today would not come on right away after starting the van, i would have to engage the brakes maybe 3 or 4 times, then the warning lights would come on.
This morning, as soon as i started the van, they were on. I turned the van off and restarted, still the same.
Prior to installing the new reservoir, my brakes were a little soft, i knew i was loosing pressure in the system because of the leak.
This morning, the Brakes are very firm, secure, no hesitation or softness to them what so ever.
I will first check the ABS wheel sensors, hopefully that is what the problem is, becuase of the firmness of the brakes, i don't think i have any air in the system.
thanks again for the help.
bigdaddie
Postby bigdaddie [OP] » August 4th 2012, 3:59pm
Corsemoto wrote:Definitely start by bleeding brakes to make sure there isn't air but if both ABS and brake lights are on, it is sounds like it is ebcm related which is not uncommon.
Corsemoto, i do have specific question concerning your info, the PDF file is great for removal and installation, but how would i test the unit that is on my van now?? :ty:
bigdaddie
Postby Corsemoto » August 4th 2012, 4:09pm
The second link above was incorrect, I updated it but there is more info in this thread:
Corsemoto
Topics: 39
Images: 13
Extra Info: LT AWD
Postby bigdaddie [OP] » August 4th 2012, 6:36pm
thank you, the in depth information provide on this site is unbeleivable, thanks again.
bigdaddie
Postby Corsemoto » August 5th 2012, 12:42pm
Sure thing, hope it helps.
It's best to be able to scan for ABS codes but most shops will charge for this. When I had mine scanned, it showed a code for a fault with ebcm (don't remember the exact code) but I still wanted to test and rule out other things first, like wheel speed sensors.
When I had my module repaired by Atlanta Speedometer Repair, they told me that when the ebcm fails it will usually have other failure codes stored for things like faulty wheel speed sensor but that doesn't necessarily mean that item is faulty. This was the case with mine, they noted all the stored codes in ebcm (including a wheel speed sensor fault) and told me this is fairly common. Installed repaired ebcm and everything worked great, no problems with sensors, etc.
Corsemoto
Topics: 39
Images: 13
Extra Info: LT AWD
Return to Brakes
It is currently April 13th 2021, 5:15pm
Brakes Forum
Astroratsun
in Brakes
Date: Apr 11 '21
Time: 7:25am
Gwicz
in Brakes
Date: Mar 27 '21
Time: 1:06pm
MATT1488
in Brakes
Date: Feb 16 '21
Time: 10:18am
in Brakes
Date: Feb 10 '21
Time: 3:04am
in Brakes
Date: Feb 09 '21
Time: 9:55pm
