ABS light on. ABS not working
Postby romeroom [OP] » April 20th 2009, 5:15pm
The ABS on my 95 AWD Astro has been on for nearly two years. I've not looked into it because I was told it would be an expensive repair--not being told what the repair was actually going to be.
Since I'm in this mode of being a do-it-yourself, I'd like to know what it would take for me to diagnose the problem. Any ideas would be great. I've looked through the forum and have not found specific diagnostic procedures. Thanks.,
'2002 Astro LS, AWD, 41k miles, "W" VIN
romeroom
Years of Membership: romeroom has been a member for 12 full yearsromeroom has been a member for 12 full yearsromeroom has been a member for 12 full yearsromeroom has been a member for 12 full yearsromeroom has been a member for 12 full yearsromeroom has been a member for 12 full yearsromeroom has been a member for 12 full yearsromeroom has been a member for 12 full yearsromeroom has been a member for 12 full yearsromeroom has been a member for 12 full yearsromeroom has been a member for 12 full yearsromeroom has been a member for 12 full years
Topics: 38
Van Model Year: 2002
Extra Info: AWD 76000 miles
  • 2000 Astro AWD abs light at startup.
    by asrooster8100 » February 21st 2021, 5:07pm in Brakes
    Last post by WimpTech View the latest post
    March 13th 2021, 8:40pm
  • Replaced all brake lines, removed ABS on a '91
    by icebrrg3rd » December 10th 2020, 12:43am in Brakes
    December 15th 2020, 2:35am
    54
    April 21st 2021, 12:23am
Re: ABS light on. ABS not working
Postby GaryZ » April 20th 2009, 6:28pm
It could be a wheel sensor. However, back in 2002 my '91 Safari ABS light came on and the local dealer told me the ABS computer was $900. He also said that this expensive part was why a lot of Astro/Safari vans were running around with this light on.
'98 Astro AWD, white with gray interior,
3.42:1 diffs, 235/70 x 15 tires,
195,000 miles on original engine and trans
'99 Kawasaki ZX11D
'85 Yamaha Venture Royale with 1300 engine & Vmax cams
GaryZ
Years of Membership: GaryZ has been a member for 12 full yearsGaryZ has been a member for 12 full yearsGaryZ has been a member for 12 full yearsGaryZ has been a member for 12 full yearsGaryZ has been a member for 12 full yearsGaryZ has been a member for 12 full yearsGaryZ has been a member for 12 full yearsGaryZ has been a member for 12 full yearsGaryZ has been a member for 12 full yearsGaryZ has been a member for 12 full yearsGaryZ has been a member for 12 full yearsGaryZ has been a member for 12 full years
Postby romeroom [OP] » April 20th 2009, 7:01pm
GaryZ wrote:It could be a wheel sensor. However, back in 2002 my '91 Safari ABS light came on and the local dealer told me the ABS computer was $900. He also said that this expensive part was why a lot of Astro/Safari vans were running around with this light on.
I have to assume that, even thought the dealer recognized it was a chronic problem and likely a design flaw, he did not offer to replace it at a discount, right?
I don't really feel like paying a dealer to tell me what is wrong, especially since the likely prohibitive nature of the repair will not outweigh the inconvenience of a non-working ABS system.
Any way to tell if it's the ABS computer without bringing it to the dealer?
romeroom
Topics: 38
Postby GaryZ » April 20th 2009, 7:46pm
romeroom wrote: I have to assume that, even thought the dealer recognized it was a chronic problem and likely a design flaw, he did not offer to replace it at a discount, right?
No discount was offered and I reached the same conclusion . . . Drive it as is.
I never did get around to doing any troubleshooting. Sold the van with the light on.
'99 Kawasaki ZX11D
GaryZ
Postby romeroom [OP] » April 20th 2009, 8:13pm
GaryZ wrote:
Thanks, GaryZ. I'll probably end up doing the same and just keep driving it as is--Unless I get some revelation that all I have to do is clean a sensor here and there...though I highly doubt it.
romeroom
Topics: 38
Postby spongebob218 » April 21st 2009, 2:23am
The ABS light has been on since I got it who knows how long before that. I really don't care, and just keep driving it as is. It behave like a normal, non ABS system, which is fine with me. I am led to believe however, that the light is an issue with the module/pump motor, as the light is on all the time and the system doesn't "self-check". If I'm correct, If it were a sensor issue the light would go off after startup and would come on after the module recognized a bad or missing speed signal.
You ain't nothin' unless you have green plugs.
spongebob218
Years of Membership: spongebob218 has been a member for 12 full yearsspongebob218 has been a member for 12 full yearsspongebob218 has been a member for 12 full yearsspongebob218 has been a member for 12 full yearsspongebob218 has been a member for 12 full yearsspongebob218 has been a member for 12 full yearsspongebob218 has been a member for 12 full yearsspongebob218 has been a member for 12 full yearsspongebob218 has been a member for 12 full yearsspongebob218 has been a member for 12 full yearsspongebob218 has been a member for 12 full yearsspongebob218 has been a member for 12 full years
Return to Brakes
It is currently April 21st 2021, 12:23am
Brakes Forum
Astroratsun
in Brakes
Date: Apr 11 '21
Time: 7:25am
Gwicz
in Brakes
Date: Mar 27 '21
Time: 1:06pm
MATT1488
in Brakes
Date: Feb 16 '21
Time: 10:18am
in Brakes
Date: Feb 10 '21
Time: 3:04am
in Brakes
Date: Feb 09 '21
Time: 9:55pm
cron
