Brake Pads
Brake Pads
Postby dobaroy [OP] » April 5th 2014, 12:42am
Our '03 Safari AWD is going through a lot of pads on the passenger rear wheel. The last set of pads only went about 7,000 miles and they were completely worn out. They were ATE pads. Any idea what the problem would be? Also the rotors and calipers were replaced about 18 months ago.
dobaroy
Years of Membership: dobaroy has been a member for 8 full yearsdobaroy has been a member for 8 full yearsdobaroy has been a member for 8 full yearsdobaroy has been a member for 8 full yearsdobaroy has been a member for 8 full yearsdobaroy has been a member for 8 full yearsdobaroy has been a member for 8 full yearsdobaroy has been a member for 8 full years
Topics: 12
Extra Info: 4.3 AWD
  • Grooves in routers & pads
    by Astroratsun » April 11th 2021, 7:27am in Brakes
    April 11th 2021, 7:27pm
  • REAR DISC BRAKE KIT !!?? ( WEB SITE ) LINK
    by WRENCH-ED-NESS » November 4th 2020, 12:04am in Brakes
    November 16th 2020, 7:10pm
    82
    April 14th 2021, 9:51pm
Re: Brake Pads
Postby crusader1xxx » April 5th 2014, 12:45am
It sounds like the caliper is sticking...even though they were replaced, something might not be right. the other thing could be an emergency brake cable sticking on that one side...I would check those first...
crusader1xxx
Years of Membership: crusader1xxx has been a member for 7 full yearscrusader1xxx has been a member for 7 full yearscrusader1xxx has been a member for 7 full yearscrusader1xxx has been a member for 7 full yearscrusader1xxx has been a member for 7 full yearscrusader1xxx has been a member for 7 full yearscrusader1xxx has been a member for 7 full years
Topics: 25
Images: 16
Alias (AKA): Andy
Extra Info: RwD
Re: Brake Pads
Postby Corsemoto » April 5th 2014, 1:17am
Sticking caliper piston/slider pins or kinked/blocked/deteriorated brake line not allowing piston to retract. Rubber brake lines are over ten years old now so worthwhile to replace anyway.
'03-'05 have a drum/shoe type parking brake mechanism that operates inside the rear rotor hat so that wouldn't affect the pad wear in caliper.
FWIW, Hawk LTS pads are excellent - great braking performance, no fade and last forever. I'd run some cheap pads on the rear until I was sure the problem was sorted though.
Corsemoto
Topics: 39
Images: 13
Extra Info: LT AWD
Re: Brake Pads
Postby thegreenmachine » April 5th 2014, 1:18am
I have the same problem with the same side. I rotate the pads whenever I need to to keep the wear even.
Take the inner pad and replace it the outer and vice versa.
Sent from AutoGuide.com App
"that looks legit"
95 AWD Safari money pit
thegreenmachine
Firing on 6 Cylinders (L2)
Years of Membership: thegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full years
Topics: 62
Alias (AKA): Shane a lane
Re: Brake Pads
Postby RECox286 » April 5th 2014, 3:51am
I would change out the dragging caliper. Remans are (????) at the least.
Uncle Bob
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Alias (AKA): Uncle Bob
Extra Info: RWD V6 [325K mi]
Re: Brake Pads
Postby Astrofarian » April 5th 2014, 4:22pm
SOMETHING has to be sticking on that corner...do you feel a pull of any sort when driving or braking? Probably not anything wrong with your choice of pads....look at the hardware at that wheel & clean/lube everything you can. :2:
Astrofarian
Alias (AKA): M!ke
Extra Info: Someday......
Re: Brake Pads
Postby dobaroy [OP] » April 5th 2014, 4:40pm
Thanks for the replies. First of all I was glad to hear we can eliminate the e-brake. The brake lines have been replaced (except for the rubber ones). We will likely try to replace the caliper and see how we make out with that. Yes, we have a cheap set of NAPA pads on it right now and when we replace the caliper we will see how we make out then, else we will have to do like greenmachine and rotate the pads.
dobaroy
Topics: 12
Extra Info: 4.3 AWD
Re: Brake Pads
Postby Leeann_93 » April 12th 2014, 3:27am
The rubber brake lines are the suspect lines - they disintegrate on the inside first, putting a million tiny rubber BBs into the system. Fluid is easily forced out to the caliper but can't drain back out, since there's no pressure forcing it.
Return to Brakes
It is currently April 14th 2021, 9:51pm
Brakes Forum
Astroratsun
in Brakes
Date: Apr 11 '21
Time: 7:25am
Gwicz
in Brakes
Date: Mar 27 '21
Time: 1:06pm
MATT1488
in Brakes
Date: Feb 16 '21
Time: 10:18am
in Brakes
Date: Feb 10 '21
Time: 3:04am
in Brakes
Date: Feb 09 '21
Time: 9:55pm
