A few brake tips.
A few brake tips.
Postby MrBob [OP] » May 9th 2014, 5:11am
Having twice replaced rotors and pads on my Astro I've made a few observations. The first is that you should allow extra time if you haven't done an Astro front brake job before because there are ferrules that the caliper bolts pass through and ferrule seals that will need replacing. This added about an hour to the job. When I inspected them during the second brake job they were fine and didn't need attention.
Secondly, when installing the calipers, spin on a lug nut to hold the rotor against the hub. This will make reinstalling the caliper much easier.
Thirdly, the torque values given for the lug nuts on the AWD models contribute to rotor warping, IMHO. I used my torque wrench to back off of the specs. 'When reinstalling the wheels I was careful to exactly center them with the lug nuts and the seat of my pants tells me the van feels smoother when going down the road.
I guess I'll be buying an extra set of jack stands because I'll be doing my own tire rotations from now on.
MrBob
Years of Membership: MrBob has been a member for 7 full yearsMrBob has been a member for 7 full yearsMrBob has been a member for 7 full yearsMrBob has been a member for 7 full yearsMrBob has been a member for 7 full yearsMrBob has been a member for 7 full yearsMrBob has been a member for 7 full years
Topics: 74
Alias (AKA): Mr. Bob
Van Model Year: 2002
Extra Info: AWD Cargo
  • 98 Safari AWD brake line replacing
    by disloyalpick » June 5th 2020, 10:55pm in Brakes
    Last post by disloyalpick View the latest post
  • Brake upgrade?
    by Bikley » June 15th 2020, 3:17pm in Brakes
    Last post by dcsleeperdcsleeper is online! View the latest post
    June 17th 2020, 7:36pm
    9
    88
    December 4th 2020, 5:42pm
Re: A few brake tips.
Postby RECox286 » May 10th 2014, 6:40pm
Check out HF's 6 ton stands. They are beefier, allow you to raise the truck highter if
you want to put it in the air, and the price is fair. I have 2 sets of the 6 ton stands
that I use constantly, and 2 sets of the 1-1/2 ton that don't leave the shop anymore.
Uncle Bob
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Alias (AKA): Uncle Bob
Extra Info: RWD V6 [325K mi]
Return to Brakes
It is currently December 4th 2020, 5:42pm
Brakes Forum
pmou
in Brakes
Date: Nov 04 '20
Time: 7:52pm
Rando
in Brakes
Date: Nov 03 '20
Time: 8:22pm
Attached by: Godron629
Godron629
in Brakes
Date: Sep 14 '20
Time: 4:12am
Sailing_Faith
in Brakes
Comments: 37
Date: Sep 06 '20
Time: 6:28pm
Sailing_Faith
in Brakes
Comments: 37
Date: Sep 03 '20
Time: 9:36pm
