brake resevoir diaphram
Postby octavecircle [OP] » August 2nd 2014, 5:44am
Well with my recent brake problem which seems to have rectified itself... :shrug: I checked my fluid today and found that one side of the diapham was sucked into the reservoir and has been distorted and one half is now bigger and is a pain to get it to fit right .
Ill post a pic tomorrow.. just wondering anyone else had this happen? Causes? :confused:
MMMM BEER
i really hate second shift
[img]24042[/img]
octavecircle
Years of Membership: octavecircle has been a member for 6 full yearsoctavecircle has been a member for 6 full yearsoctavecircle has been a member for 6 full yearsoctavecircle has been a member for 6 full yearsoctavecircle has been a member for 6 full yearsoctavecircle has been a member for 6 full years
Topics: 18
Images: 7
Alias (AKA): octave
Extra Info: 4.3l
  • REAR DISC BRAKE KIT !!?? ( WEB SITE ) LINK
    by WRENCH-ED-NESS » November 4th 2020, 12:04am in Brakes
    November 16th 2020, 7:10pm
  • Brake proportioning valve how do you reset
    by Mpoynter » November 5th 2020, 7:19pm in Brakes
    November 6th 2020, 4:17pm
    74
    March 2nd 2021, 5:47pm
Re: brake resevoir diaphram
Postby Astro Pop » August 2nd 2014, 6:10am
Is it swollen or just twisted? I have seen brake systems screwed up by someone adding incorrect fluid. If it's swollen you need to check the entire system. You'll possibly have rubber seals in calipers and cylinders swollen too.
Astro Pop
Topics: 41
Images: 9
Alias (AKA): Xfirepop
Van Model Year: 1996
Extra Info: AWD - 5 inch lift
Postby Lumpy » August 2nd 2014, 6:17am
Mine's always been that way. Diaphragm is distorted and sunken into the reservoir.
I suppose I should consider replacing it. But the van stops when I push on the "Don't Go" pedal.
Postby Astrofarian » August 2nd 2014, 1:35pm
octavecircle wrote:Well with my recent brake problem which seems to have rectified itself... :shrug: I checked my fluid today and found that one side of the diapham was sucked into the reservoir and has been distorted and one half is now bigger and is a pain to get it to fit right .
MMMM BEER
Doctor told me years ago that one was usually bigger...and one usually hung lower. Try BOXERS if you're still uncomfortable with this. Hope this helps...snicker. :2:
Astrofarian
Alias (AKA): M!ke
Extra Info: Someday......
Postby RECox286 » August 2nd 2014, 1:44pm
Heads up, FYI:
Whatever the brake system "rubber" components are actually made of, it seems that any other
fluid mixed into the DOT 3 brake fluid will cause those parts to swell. It is called contamination,
and gives immediate cause for concern. The only cure for swollen parts is the replacement of
them, and a flushing of the liquid in the system. Don't fool with suspect contamination, it can be
deadly. (I can't stress this too much.)
Uncle Bob
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Alias (AKA): Uncle Bob
Extra Info: RWD V6 [325K mi]
Return to Brakes
It is currently March 2nd 2021, 5:47pm
Brakes Forum
MATT1488
in Brakes
Date: Feb 16 '21
Time: 10:18am
in Brakes
Date: Feb 10 '21
Time: 3:04am
in Brakes
Date: Feb 09 '21
Time: 9:55pm
in Brakes
Date: Feb 04 '21
Time: 2:19am
MavMark
in Brakes
Date: Feb 03 '21
Time: 11:35pm
