van shakes when braking
Postby alacran1 [OP] » August 23rd 2014, 3:58am
It shakes a lot when i hit the brakes and it feels like pulses but my steering wheel does not move at all. My dad says its the master cylinder but i have my doubts. Any suggestions? rear drums?
alacran1
Years of Membership: alacran1 has been a member for 6 full yearsalacran1 has been a member for 6 full yearsalacran1 has been a member for 6 full yearsalacran1 has been a member for 6 full yearsalacran1 has been a member for 6 full yearsalacran1 has been a member for 6 full years
Topics: 5
Extra Info: 4.3 v6 vortex
Re: van shakes when braking
Postby chevymaher » August 23rd 2014, 4:00am
Better brake pads and shoes. Inspect them are they glazed and cracked?
Postby alacran1 [OP] » August 23rd 2014, 4:05am
It does not shake fast or pulses. It shakes and pulses kinda slowly but the whole van jerks around.
alacran1
Topics: 5
Postby Astrofarian » August 23rd 2014, 4:26am
Seizing caliper, warped rotor(s), wheel bearing, rear brake adjuster(s)....check all those yet?
Astrofarian
Alias (AKA): M!ke
Extra Info: Someday......
Postby LAZ 1 » August 24th 2014, 4:55pm
Try the simplest fix FIRST.
RE-torque your wheel lug nuts to 100 lbs.
I swapped over to a set of freshly BALANCED rims and tires on my 98 Safari AWD. It drove perfectly for about 500 kms but then vibrated exactly like you describe. I had to re-torque the chrome steel wheels (three times) before they settled down. The lug nuts loosened up enough to give a vibration ( just like a wheel out of balance ) and it was especially noticeable during braking.
A bent rim might be another thing to look for.
Good luck
LAZ 1
LAZ 1
Years of Membership: LAZ 1 has been a member for 6 full yearsLAZ 1 has been a member for 6 full yearsLAZ 1 has been a member for 6 full yearsLAZ 1 has been a member for 6 full yearsLAZ 1 has been a member for 6 full yearsLAZ 1 has been a member for 6 full years
Topics: 48
Postby Lord_Nalcomis » March 9th 2015, 2:16pm
Are you sure that's not the ABS you're feeling? It pulses through the pedal and steering wheel when it activates.
It can be kinda scary it you've never felt it before. First time it happened in my '12 Nissan, I pee'd a little.
Lord_Nalcomis
Years of Membership: Lord_Nalcomis has been a member for 5 full yearsLord_Nalcomis has been a member for 5 full yearsLord_Nalcomis has been a member for 5 full yearsLord_Nalcomis has been a member for 5 full yearsLord_Nalcomis has been a member for 5 full years
Van Model Year: 2002
Extra Info: Cargo
Postby rev_les » March 9th 2015, 4:30pm
Wait till the ABS on the Astro just goes away and leaves you rolling like yer on ice, You'll need the pee to rinse out the brown stain!!
It's why many of us disable it. It's dangerous when it gets like that. It's kind of an old post, hopefully the OP has it sorted out by now. ( It is nice when people post the fix to the problem....HINT HINT :)
NRA Lifetime Member
2'nd amendment supporter
'13 Jeep Patriot
'87 Monte Carlo SS
'79 Avco 32' RV
rev_les
Firing on 2 Cylinders (L3)
Topics: 39
Alias (AKA): Les
Extra Info: LS 4.3 RWD
Postby Lord_Nalcomis » March 9th 2015, 6:26pm
I see. I was wondering why anyone in their right mind would want to disable ABS. Thanks for the heads up.
Lord_Nalcomis
Extra Info: Cargo
Postby Mmusicman » March 9th 2015, 7:39pm
If it's not a rapid high speed ABS pulse in the pedal, then it's warped rotors. The ABS pulse remains at a constant frequency pulse, whereas the warped rotor shake will vary with speed.
Firing on 6 Cylinders (L5)
Topics: 73
Images: 49
Postby Roger Ramjet » March 9th 2015, 10:48pm
I took my old 97 in to a shop for the same thing .. I thought either sticy caliper or warped rotor ........ turns out one of my idler arms was about ready to fall off . I'm glad they caught that one . On severe braking you would feel the whole van bouncing around but for some reason it didn't affect the steering wheel as much as you would think . I had them replace both idler arms the shaking went away
1997 Astro Van
Roger Ramjet
Years of Membership: Roger Ramjet has been a member for 7 full yearsRoger Ramjet has been a member for 7 full yearsRoger Ramjet has been a member for 7 full yearsRoger Ramjet has been a member for 7 full yearsRoger Ramjet has been a member for 7 full yearsRoger Ramjet has been a member for 7 full yearsRoger Ramjet has been a member for 7 full years
Topics: 9
Images: 11
Alias (AKA): Roger Ramjet
Extra Info: 2WD 4.3
Postby Meterpig » March 10th 2015, 2:10am
I have the same sort of issue. If I don't drive it for a few days after putting it away "wet", it seems to shimmy a bit for the first few stops then goes away for the duration of the drive. I chalk it up to dirt and dust. I bought Akebono pads which are softer than others and believe them to to contribute. Every other part of the steering has been checked and rechecked.
Meterpig
Firing on 5 Cylinders (L2)
Years of Membership: Meterpig has been a member for 5 full yearsMeterpig has been a member for 5 full yearsMeterpig has been a member for 5 full yearsMeterpig has been a member for 5 full yearsMeterpig has been a member for 5 full years
Topics: 63
Alias (AKA): meterpig
Extra Info: Not a minivan
Postby Godron629 » September 14th 2020, 4:08am
My van shook/pulsed under braking. I thought it was the rear brakes (disc) because it didn't pull L|R under breaking and sounded like the rear (empty cargo makes a lot of noise). Did the front discs/pads - went for a drive, bam, no shake. Replaced the rears when I got back because that was the plan anyways.
Pads weren't particularly bad, it sat for a while before I bought it- maybe corroded, maybe warped, really can't say...not a problem any more :chevy:
(holy crap I didn't mean to necro this thread I got played by "Random sidebar threads" :whack:, sorry)
Godron629
Extra Info: Cargo 4.3L V6 RWD
Return to Brakes
It is currently December 4th 2020, 3:49pm
Brakes Forum
pmou
in Brakes
Date: Nov 04 '20
Time: 7:52pm
Rando
in Brakes
Date: Nov 03 '20
Time: 8:22pm
Attached by: Godron629
Godron629
in Brakes
Date: Sep 14 '20
Time: 4:12am
Sailing_Faith
in Brakes
Comments: 37
Date: Sep 06 '20
Time: 6:28pm
Sailing_Faith
in Brakes
Comments: 37
Date: Sep 03 '20
Time: 9:36pm
