by Bread Van [OP] » March 29th 2010, 5:38pm
by Bread Van [OP] » March 29th 2010, 5:45pm
by unrreal » March 29th 2010, 9:16pm
Bread Van wrote:PS, when I had the codes scanned at Autozone they told me that they couldn't scan the braking system. Is this true, or was the guy just lazy?
He also wouldn't let me clear my emissions faults...which every other guy has allowed...so long as he doesn't do it.
by Bread Van [OP] » March 29th 2010, 9:43pm
unrreal wrote:* and for your second it is autozones company policy to check lights only not clear them but some people don't care and erase them anyway (this is what i used to do) when i worked there
by Astroplane » March 30th 2010, 9:00am
Bread Van wrote:Any obvious locations I should be investigating.
by Bread Van [OP] » April 5th 2010, 4:29am
by Astroplane » April 5th 2010, 5:20am
Bread Van wrote:I have noticed that the ABS system works proper before the lights come on...once the lights are on, no ABS.
by Bread Van [OP] » April 5th 2010, 4:29pm
by Corsemoto » April 5th 2010, 5:45pm
by Astroplane » April 6th 2010, 7:53am
Bread Van wrote:So wear indicators not sensors.
by Bread Van [OP] » April 7th 2010, 3:09am
Astroplane wrote:Bread Van wrote:So wear indicators not sensors.
The wear indicators are typically part of the brake pad. Your van has left and right front wheel speed sensors.
by Astroplane » April 7th 2010, 3:50am
by Bread Van [OP] » April 7th 2010, 4:04am
Astroplane wrote:Nope, BMW did not make your Astro van.
by Astroplane » April 7th 2010, 6:14am
by Bread Van [OP] » April 7th 2010, 2:15pm
Astroplane wrote:Which pads are you looking at on rock? I'm only seeing the 'sensory lock' pads. I was thinking that is a trade name for how the friction material is attached to the pad backing. Not sure.
by Bis » May 25th 2011, 8:24pm
Bread Van wrote:Most times when I start my van the ABS light and brake light come on, then go off, as they should.
However within a short distance both will come on at the same time. I have seen this happen enough to realize that is always happens after going over a bump. Once the lights come on, they stay on.
I figured I had a front wheel sensor issue, but this is making me think I might just have a bad connection somewhere.
Any obvious locations I should be investigating. Any help is appreciated.
by scaneagle62 » December 19th 2011, 5:53pm
by Corsemoto » December 20th 2011, 5:44pm
by Bis » December 25th 2011, 5:23am
by Rolling_Rock » August 23rd 2012, 12:09am
Bis wrote:I solved my problem (posted a few posts up on this thread).
THE PROBLEM: Bad ABS Module. Apparently a usual problem with Chevy's of my year late 90's/early 2000's.
THE SOLUTION: Send it for repair. Go on eBay and find these guys: http://www.autoecu.com/ They charge about $50 less on eBay!!! I don't know why.
If you don't want to spend the money on repairing it you can disable it by disconnecting it. Your brakes will work but your ABS won't.
Unfortunately I spent tons of money of ABS sensors and such, which made no difference. For $50 + shipping one way you get a LIFETIME WARRANTY on your ABS Module. Get it checked!
It is currently March 7th 2021, 10:11am
Brakes Forum |
Moderator: chevy57bert |
Previous topic Next topic |
Sponsors |
