Just some Hydro boost info
Postby 4POINT3GMC [OP] » January 29th 2015, 8:06pm
I heard this from a GM mechanic that:
1.Raising the RPM above 2500
2.Turning the steering wheel all the way left or right.
3. Stabbing the brakes
Are all normal during driving situations, but if the three are combined it will snap the power steering shaft every time.
Mine snapped during an impromptu "donut" in the snow....instantly no brakes, no power steering.
Lesson learned... :banghead:
February 9th 2010, 6:17pm
4POINT3GMC
Years of Membership: 4POINT3GMC has been a member for 10 full years4POINT3GMC has been a member for 10 full years4POINT3GMC has been a member for 10 full years4POINT3GMC has been a member for 10 full years4POINT3GMC has been a member for 10 full years4POINT3GMC has been a member for 10 full years4POINT3GMC has been a member for 10 full years4POINT3GMC has been a member for 10 full years4POINT3GMC has been a member for 10 full years4POINT3GMC has been a member for 10 full years
Alias (AKA): 4POINT3GMC
Extra Info: Explorer Convers
  • Hydro or ?
    by tungtide » October 4th 2020, 4:11pm in Brakes
    Last post by tungtide View the latest post
    October 4th 2020, 10:09pm
    46
    December 1st 2020, 12:39am
Re: Just some Hydro boost info
Postby Meterpig » January 30th 2015, 1:03am
So, I don't completely understand hydroboost. And...why would it "snap" the shaft? What shaft?
Meterpig
Firing on 5 Cylinders (L2)
Years of Membership: Meterpig has been a member for 5 full yearsMeterpig has been a member for 5 full yearsMeterpig has been a member for 5 full yearsMeterpig has been a member for 5 full yearsMeterpig has been a member for 5 full years
Topics: 63
Alias (AKA): meterpig
Van Model Year: 2002
Extra Info: Not a minivan
Postby chevymaher » January 30th 2015, 1:32am
Shaft on the power steering pump.
Postby akforceten » January 30th 2015, 2:24am
yep just like this
98638 100250
akforceten
Years of Membership: akforceten has been a member for 10 full yearsakforceten has been a member for 10 full yearsakforceten has been a member for 10 full yearsakforceten has been a member for 10 full yearsakforceten has been a member for 10 full yearsakforceten has been a member for 10 full yearsakforceten has been a member for 10 full yearsakforceten has been a member for 10 full yearsakforceten has been a member for 10 full yearsakforceten has been a member for 10 full years
Topics: 32
Images: 128
Alias (AKA): akforceten
Extra Info: SLE 4x4 7 inch lift
Postby Coaster » January 30th 2015, 2:32am
i dont like my hydroboost setup. i find it quite lacking and trouble prone. i dont find it any better than the old style of vacuum brakes and normal power steering.
i do not see the advantage in it.
I LIVE IN NORTH DAKOTA
Coaster
Topics: 113
Extra Info: 4.3 cargo 2wd
Postby RECox286 » January 30th 2015, 8:39pm
Advantage ? Is there enough room under the bonnet as it is ?
Yes, the shaft will snap when the three conditions are met...
My 93 has 325k mi on the original hydroboost, and it still works
just like the day I bought it back in 94 with 25k mi, thank you.
I'll bet very few people experience the need to ...
Uncle Bob
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Alias (AKA): Uncle Bob
Extra Info: RWD V6 [325K mi]
Postby 4POINT3GMC [OP] » January 31st 2015, 5:33am
yep I believe that's the reason for it, as real estate is at a premium under the hood. I just live without doing donuts any more in that car...when mine broke the serpentine belt actually held the spinning shaft and pulley in the normal place so it was a bit confusing to track down.... :confused:
4POINT3GMC
Postby thegreenmachine » February 1st 2015, 8:06pm
My 95 had a snapped shaft when I bought it.
Got it for super cheap because of it.
But yes, try not to drive in such a way that you snap the shaft like that. I believe silverbullett broke his doing the exact same thing.
But chances are the shaft was already cracked.
"that looks legit"
95 AWD Safari money pit
thegreenmachine
Firing on 6 Cylinders (L2)
Years of Membership: thegreenmachine has been a member for 10 full yearsthegreenmachine has been a member for 10 full yearsthegreenmachine has been a member for 10 full yearsthegreenmachine has been a member for 10 full yearsthegreenmachine has been a member for 10 full yearsthegreenmachine has been a member for 10 full yearsthegreenmachine has been a member for 10 full yearsthegreenmachine has been a member for 10 full yearsthegreenmachine has been a member for 10 full yearsthegreenmachine has been a member for 10 full years
Topics: 62
Alias (AKA): Shane a lane
Postby Lumpy » February 2nd 2015, 12:22am
SHAFT!
Right on!
Return to Brakes
It is currently December 1st 2020, 12:39am
Brakes Forum
pmou
in Brakes
Date: Nov 04 '20
Time: 7:52pm
Rando
in Brakes
Date: Nov 03 '20
Time: 8:22pm
Attached by: Godron629
Godron629
in Brakes
Date: Sep 14 '20
Time: 4:12am
Sailing_Faith
in Brakes
Comments: 37
Date: Sep 06 '20
Time: 6:28pm
Sailing_Faith
in Brakes
Comments: 37
Date: Sep 03 '20
Time: 9:36pm
Users browsing this forum: Google [Bot] and 3 guests
