Rear brake shoe question--kinda an emergency
Postby offctr [OP] » March 13th 2015, 3:26am
I had some noise issues with the rear brakes and after I got it all apart it turned out the parking brake shoe was off its clip and free to move about in the "drum" part of the clip is gone or the previous owner couldn't figure out how it worked and modified it ......anyway it cant go back like it was and the auto parts places are closed now --can I leave the shoe out overnite till the stores open in the am and I can get new parts --I was going to wire the two pistons in in the actuator till tomorrow with some safety wire just to secure them in place so they dont fall out.
offctr
Fueling (1/2 tank)
Fueling (1/2 tank)
Years of Membership: offctr has been a member for 6 full yearsoffctr has been a member for 6 full yearsoffctr has been a member for 6 full yearsoffctr has been a member for 6 full yearsoffctr has been a member for 6 full yearsoffctr has been a member for 6 full years
Topics: 9
  • REAR DISC BRAKE KIT !!?? ( WEB SITE ) LINK
    by WRENCH-ED-NESS » November 4th 2020, 12:04am in Brakes
    November 16th 2020, 7:10pm
  • 98 Safari AWD brake line replacing
    by disloyalpick » June 5th 2020, 10:55pm in Brakes
    Last post by disloyalpick View the latest post
    17
    December 4th 2020, 3:26pm
Re: Rear brake shoe question--kinda an emergency
Postby Astrofarian » March 13th 2015, 3:37am
Are you talking about the "pistons" (cups) in the wheel cylinders? Or is this a disc-brake rear end? Here or shop talk...someone can help you, I'm sure.
Astrofarian
Alias (AKA): M!ke
Extra Info: Someday......
Postby zzimmer3 » March 13th 2015, 3:55am
One completely redneck way is to crimp off the rubber hose to the rear brakes so they won't work and damage anything else. I've use a tiny set of vise grips on the rubber hose from the frame to the rear end when one of my brake lines broke (rusted more specifically) so I could drive home.
1994 2wd, 1998 2wd, 2000 awd, 2001 awd
zzimmer3
Years of Membership: zzimmer3 has been a member for 6 full yearszzimmer3 has been a member for 6 full yearszzimmer3 has been a member for 6 full yearszzimmer3 has been a member for 6 full yearszzimmer3 has been a member for 6 full yearszzimmer3 has been a member for 6 full years
Topics: 67
Images: 50
Alias (AKA): teddybear
Extra Info: LT AWD
Postby chevymaher » March 13th 2015, 4:22am
Don't wire the wheel cylinder bad idea. The hydraulic pressure will rip anything you put there apart. Then it will pump the rear brake fluid out.
Postby Astrofarian » March 13th 2015, 4:27am
chevymaher wrote:Don't wire the wheel cylinder bad idea. The hydraulic pressure will rip anything you put there apart. Then it will pump the rear brake fluid out.
:text-yeahthat:
Astrofarian
Alias (AKA): M!ke
Postby offctr [OP] » March 13th 2015, 5:50am
Not the wheel cylinder --this is a disc rear end the little pistons on the cam thinngy that amke the parking brake shoe spread.
The parking brake is strictly mechanical the regular rear brakes are hydraulic. Anyway I couldnt wait --didnt see what it would hurt overnite as long as I dont use the parking brake the two little pistons just ride the cam so I took em out --they come it the hardware kit anyway. Gonna get new shoes and hardware in the morning for the parking brake for now the rears have new rotors and pads and are working good. the e-brake design on the disc rears leaves a lot to be desired. I dont want to run without it normally but it looks like a PITA to keep working and adjusted.
offctr
Fueling (1/2 tank)
Fueling (1/2 tank)
Topics: 9
Postby offctr [OP] » March 22nd 2015, 3:11am
Soory to let this fester so long -long week at work-but it was fine leaving the parking brake parts out --they wernt doing anything anyway..I just wasnt sure 100% they would not cause some kind of problem with the regular brakes. Anyway the next day I got the new dust shields and parking brake shoes and hardware and got it all back together the right way. Like I said not the best design but I guess
worth it for the disc rear---it is much nicer than doing drum brakes thats for sure !
offctr
Fueling (1/2 tank)
Fueling (1/2 tank)
Topics: 9
Return to Brakes
It is currently December 4th 2020, 3:26pm
Brakes Forum
pmou
in Brakes
Date: Nov 04 '20
Time: 7:52pm
Rando
in Brakes
Date: Nov 03 '20
Time: 8:22pm
Attached by: Godron629
Godron629
in Brakes
Date: Sep 14 '20
Time: 4:12am
Sailing_Faith
in Brakes
Comments: 37
Date: Sep 06 '20
Time: 6:28pm
Sailing_Faith
in Brakes
Comments: 37
Date: Sep 03 '20
Time: 9:36pm
