Top bolt on the hub - how do you get access?
Postby bunce1260 [OP] » September 6th 2015, 8:46pm
I can't get a socket securely on to that top bolt, let alone worrying about torqueing it or heating it. How do I get at it?
(Questions about torqueing and heating it to follow.)
bunce1260
Years of Membership: bunce1260 has been a member for 6 full yearsbunce1260 has been a member for 6 full yearsbunce1260 has been a member for 6 full yearsbunce1260 has been a member for 6 full yearsbunce1260 has been a member for 6 full yearsbunce1260 has been a member for 6 full years
Topics: 73
Re: Top bolt on the hub - how do you get access?
Postby Lumpy » September 6th 2015, 8:54pm
What's a "Hub"?
Postby bunce1260 [OP] » September 6th 2015, 9:00pm
I really wish I didn't know.
bunce1260
Topics: 73
Postby Corsemoto » September 6th 2015, 9:10pm
I don't remember having that problem when I replaced mine. Longer/shorter socket, extension, etc?
Corsemoto
Topics: 39
Images: 13
Extra Info: LT AWD
Postby bunce1260 [OP] » September 6th 2015, 10:12pm
The other shot - I was looking at how to get the bolts undone in case I need to put a new hub on. I can get the socket on, but no clearance to get anything else on their.
I jacked up the suspension to try and change some angles but the whole van seemed to raise ??? :confused:
Sorry, this stupid chromebook flips the photo 90 degrees anticlockwise despite everything being normal on my miniscule hard drive.
bunce1260
Topics: 73
Postby chevymaher » September 6th 2015, 10:31pm
Emergency run to harbor freight for a set of swivel sockets.
Topics: 91
Postby Leeann_93 » September 6th 2015, 10:38pm
From the back????
On my '99, '00 and '02 they're bolted from the front.
Postby Lumpy » September 6th 2015, 11:28pm
So I'm guessing "Hub" is some kind of Gen II component.
Seems well in hand. By your leave, sir.
Postby Leeann_93 » September 6th 2015, 11:35pm
It's an AWD component. Fron wheel bearing/hub assemblies.
Postby ceedj » September 12th 2015, 3:20pm
Mine were from the front, but I wound up taking the whole knuckle off with hub attached after popping the ball joints, caliper, and tie rod end. I removed the axle nut (and washer! I got everything back together and noticed a big heavy washer. Whoops.) first, and once the other stuff was disconnected, the whole thing slid off the half shaft. Careful with the abs sensor wire!
2000 GMC Safari AWD, SLE, 140,000 miles
ceedj
Fueling (1/2 tank)
Fueling (1/2 tank)
Years of Membership: ceedj has been a member for 5 full yearsceedj has been a member for 5 full yearsceedj has been a member for 5 full yearsceedj has been a member for 5 full yearsceedj has been a member for 5 full years
Topics: 12
Alias (AKA): CJ
Extra Info: SLE 4.3L V6 AWD
Postby thegreenmachine » September 13th 2015, 6:12pm
I used a shallow socket with a swivel and an extension.
Or a swivel socket can't remember.
"that looks legit"
95 AWD Safari money pit
thegreenmachine
Firing on 6 Cylinders (L2)
Years of Membership: thegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full years
Topics: 62
Alias (AKA): Shane a lane
Return to Brakes
It is currently April 14th 2021, 11:30pm
Brakes Forum
Astroratsun
in Brakes
Date: Apr 11 '21
Time: 7:25am
Gwicz
in Brakes
Date: Mar 27 '21
Time: 1:06pm
MATT1488
in Brakes
Date: Feb 16 '21
Time: 10:18am
in Brakes
Date: Feb 10 '21
Time: 3:04am
in Brakes
Date: Feb 09 '21
Time: 9:55pm
