'92 Astro ABS. Little backstory; van sat in a carport for 8 years, I replaced all ignition and fuel components, and got it back on the road. I replaced the tires with 215 (stock was 205, but 215 was an option from the factory). It drove and stopped fine until a wheel cylinder went out.
My passenger rear wheel cylinder went out, and both the Brake and ABS warning lights came on. After replacing the wheel cylinder, adjusting the adjuster, and bleeding the brakes, the Brake and ABS lights are still on.
I've tried jabbing the brakes both in drive and reverse, I've bled them again, AND I've tried "resetting" the proportioning valve (described here viewtopic.php?f=45&t=80537&p=761945&hilit=reset+brake+light#p761337).
it brakes perfectly fine. I've checked both the ALDL and ABS computer codes using the paper clip method (my OBDI scanner isn't communicating with it for some reason). The ABS computer flashed code 2 and code 6, but I'm not sure what to do from there.
