by webcat » March 16th 2009, 4:40am
by CDGsafari98 » March 18th 2009, 3:25am
by d0n » October 24th 2009, 2:37pm
by timelessbeing » October 25th 2009, 9:18pm
by gwd » October 26th 2009, 1:33am
by timelessbeing » October 26th 2009, 2:22am
by d0n » November 2nd 2009, 1:53pm
timelessbeing wrote:You can replace the sensor as many times as you want and it won't fix the problem.
You have to clean the reluctor ring, and then test the sensor reading to make sure it's within spec. Or replace the whole hub.
by timelessbeing » November 2nd 2009, 6:29pm
by Bis » May 25th 2011, 9:45pm
gwd wrote:My ABS also failed. I changed my sensors but it also got worse. I believe my ABS computer under the driver seat underneath the van is defective. I have a link which I am going to try.
http://modulemaster.com/en/index.php
They fix the the computer for the ABS systems.
by Bis » September 15th 2011, 1:29pm
thyubernoob wrote:When I would get to around 8 or 9 mph when braking, the ABS would act strange and not brake correctly, almost rear ended someone .
by Phantom » September 15th 2011, 1:46pm
by Bis » September 16th 2011, 1:27am
Phantom wrote:Since the ABS is a computer interactive device , to get a full diagnosis of the ABS functionality , a OBD2 ABS diagnostic program will need to be run to determine the full status of operation , it can be as simple as a code that has been logged and need to be cleared , but a diag program has to be run to see it as it is an independent system that ties into the OBD , I have some pdf files on it , I'll try to dig them up for more info
If you have worries you can pull the ABS fuse which will disable ABS and revert back to only your regular braking system until you find a more permanent answer/solution
by WoodButcher » September 17th 2011, 2:28am
Bis wrote:If I experience it once more I will have to do that. Can't trust it.
by Phantom » September 17th 2011, 3:26am
WoodButcher wrote:ABS is good for the person who is likely to panic and put their foot to the floor.
by Bis » September 19th 2011, 10:16am
Bis wrote:thyubernoob wrote:When I would get to around 8 or 9 mph when braking, the ABS would act strange and not brake correctly, almost rear ended someone .
I was about to post a whole new thread about this, but then saw this and thought I'd try to get some feedback from you guys.
When I purchased the van a few months back the ABS/Brake lights would come on when the car vibrated. A mechanic tried pretty much everything to try to stop the problem but the problem with the lights on the dashboard still occurred.
At the same time I noticed that from time to time the brakes would "lose power" (the pedal would sink slightly and no braking would take place, almost causing an accident at the same spot on the road several times). I realized that every time the brakes "failed" I was going over a railroad track and braking at the same time. To this day I am not sure why that happened, but one thing I did find was the cause of the lights on my dashboard coming on: I did more research and found out that it is a common problem for the ABS module to go bad. At the same time I thought that maybe the ABS module was causing the brakes to act up when I went over the tracks for whatever reason. Needless to say I sent the module to get fixed, by the time I got to putting it back on the car 2 months had gone by and I had forgotten about the braking problem that would take place by the RR Tracks. That is until this week when the ABS module finally went back on!
The lights on my dashboard don't come on anymore, so that is fixed, but the BRAKING problem re-appeared once again (one time only). Am I to think that the ABS system is failing somehow? Even after a new module and a full brake inspection took place? The sensors were cleaned and everything...!!!
I am dumbfounded and worried. Winter is coming and I have heard some horror stories about Astro/Safari ABS brakes. I am scared the brake problem will happen at higher speeds or in a critical moment.
Any feedback is appreciated.
by chevymaher » September 19th 2011, 12:19pm
by Bis » September 19th 2011, 8:00pm
by Phantom » September 19th 2011, 8:12pm
by Bis » September 19th 2011, 8:34pm
Thanks for your concern.... For your records, there's a known problem with the ABS system on the Astro/Safari vans. There's an official TSB but NO recall. Still amazes me why no formal recall. For details....
Bottom line is... Defector sensor (which needs to be replaced) or the existing sensor is too "rusted up" to work properly...
.... Basically, dirty sensor mounting surfaces cause the signal to drop out at low speeds, which fools the ABS system into thinking that it is experiencing an ABS event when it's not.
Antilock Brake (ABS) Activation At Low Speeds (Clean Wheel Speed Sensor
Mounting Surface) #02-05-25-006A - (11/26/2002)
Mounting Surface)
1999-2000 Cadillac Escalade
1995-1999 Chevrolet Silverado (Old Style)
1995-2000 Chevrolet Suburban, Tahoe (Old Style)
1995-2003 Chevrolet Astro Van, Blazer, S10
1995-1999 GMC Sierra (Old Style)
1995-2000 GMC Yukon, Yukon XL (Old Style)
1995-2001 GMC Envoy, Jimmy
1995-2003 GMC Safari Van, Sonoma
1995-2001 Oldsmobile Bravada
This bulletin is being revised to change model information. Please discard
Corporate Bulletin Number 02-05-25-006 (Section 05 -- Brakes).
Condition
Some customers may comment on ABS activation at low speeds, usually below 8
km/h (5 mph). Upon investigation, the technician will find no DTCs set.
Cause
The cause of this condition may be an increased air gap between the wheel
speed sensor and the hub reluctor ring due to rust and debris built up on
the sensor mounting surface.
Correction
Measure AC voltage and clean wheel speed sensor mounting surfaces.
1.. Raise the vehicle on a hoist.
2.. Disconnect both the front wheel speed sensor harness connectors.
3.. Place a DVM across the terminals of each sensor connector.
4.. Rotate the wheel with hand speed and measure the ACmV's. The reading
should be at least 350 ACmV's.
5.. If the reading is between 200 and 350 ACmV's, remove the wheel,
caliper and rotor in order to gain access to the speed sensor.
6.. Remove the wheel speed sensor and plug the hole to prevent debris from
falling into the hub during service.
7.. Clean the speed sensor mounting surface on the hub to remove rust and
corrosion.
Important
Make sure that the sensor sits flat on the hub. If the sensor flange is
distorted, replace the sensor.
8.. Apply a thin layer of bearing grease to the hub surface prior to
sensor installation.
9.. Install either the original sensor or a new one in the hub and secure
the sensor. Ensure that the sensor is seated flush against the hub.
10.. Install the rotor, the caliper and the wheel.
11.. Place the DVM across the sensor terminals and recheck the voltage
while rotating the wheel by hand. The voltage should now read at least 350
ACmV's.
It is currently April 20th 2021, 6:05pm
Brakes Forum |
Moderator: chevy57bert |
Previous topic Next topic |
Sponsors |
