Rear brakes- Shearing the liner off the shoe
Postby TXMike [OP] » January 14th 2016, 7:51pm
I have a 2001 Astro with 300k miles. I recently purchased it for commercial use (newspaper delivery). One evening the passenger rear brake locked up. Upon inspection it had sheared the rivets holding the composite to the steel "shoe". The thickness of the material was comparable to the new parts I replaced it with. (I also replaced the drum.) So I blamed it on defective product. ..... Fast forward , less than 30 days later it has done it again same side -same symptoms. I checked the axle for bearing play and it seems to be within the norm.... Any advice?
TXMike
Years of Membership: TXMike has been a member for 4 full yearsTXMike has been a member for 4 full yearsTXMike has been a member for 4 full yearsTXMike has been a member for 4 full years
Van Model Year: 2001
Extra Info: LS 4.3
  • Rear Drum Brakes
    by [email protected] » May 18th 2020, 2:47pm in Brakes
    Last post by [email protected] View the latest post
    May 23rd 2020, 8:35pm
  • 2003 GMC Safari Brakes
    by MarquezErnest » May 15th 2020, 12:28am in Brakes
    Last post by petema View the latest post
    May 16th 2020, 8:45pm
    9
    24
    October 26th 2020, 5:43pm
Re: Rear brakes- Shearing the liner off the shoe
Postby chevymaher » January 14th 2016, 11:37pm
What brand brake shoes?
Wagner are the OE type and made a huge difference in mine. Most LAPS carry them but you got to order them. Because they are pushing their brand. And they are alot more expensive. But you get what you pay for especially in this case.
Return to Brakes
It is currently October 26th 2020, 5:43pm
Brakes Forum
Attached by: Godron629
Godron629
in Brakes
Date: Sep 14 '20
Time: 4:12am
Sailing_Faith
in Brakes
Comments: 35
Date: Sep 06 '20
Time: 6:28pm
Sailing_Faith
in Brakes
Comments: 35
Date: Sep 03 '20
Time: 9:36pm
in Brakes
Comments: 87
Date: Sep 02 '20
Time: 4:18am
in Brakes
Comments: 87
Date: Sep 01 '20
Time: 10:15pm
