rusted brake line
rusted brake line
Postby astro96007 [OP] » November 15th 2010, 12:21pm
hi everyone, returning member from the old forum. i tried searching but still not clear on the size of the brake line that run along the gas tank- 96 ,4.3, v6., to the union on the rear end. my line is rusty, any ideas to get the fitting out of the rubber hose on the rear?
astro96007
Years of Membership: astro96007 has been a member for 10 full yearsastro96007 has been a member for 10 full yearsastro96007 has been a member for 10 full yearsastro96007 has been a member for 10 full yearsastro96007 has been a member for 10 full yearsastro96007 has been a member for 10 full yearsastro96007 has been a member for 10 full yearsastro96007 has been a member for 10 full yearsastro96007 has been a member for 10 full yearsastro96007 has been a member for 10 full years
Extra Info: LT 4.3L V6 RWD
  • Opening rear brake line plastic brackets
    by Rsimon » March 7th 2021, 7:12pm in Brakes
    Last post by Rsimon View the latest post
  • REAR DISC BRAKE KIT !!?? ( WEB SITE ) LINK
    by WRENCH-ED-NESS » November 4th 2020, 12:04am in Brakes
    November 16th 2020, 7:10pm
    9
    77
    April 21st 2021, 11:40pm
Re: rusted brake line
Postby RECox286 » November 15th 2010, 2:05pm
3/16", double flair, steel pipe. I would break the pipe near the fitting and use a 3/8" 6 pt socket on the fitting, and any thing that will fit the brake hose as a back up wrench. Maybe vise grips. Try tightening just until it "breaks" then unwind. That should do it for you.
Bob
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Alias (AKA): Uncle Bob
Extra Info: RWD V6 [325K mi]
Postby timkb » November 15th 2010, 11:25pm
Just did this job last weekend. I don't know about the '96's but my '97 with ABS had 1/4" line going to the rear. I measured it using a vernier caliper. Dont forget to use PB Blaster on the fitting. Attached pic shows tools I found helpful. Flare nut wrench set and tubing bender both from Harbor Freight, less than $10 each. Pic also shows a tubing double flare kit from McMaster-Carr about $59. If you can get the tubing in appropriate lengths with the right ends you will not need to flare your own. I believe the 1/2" fittings require a 9/16" wrench.
If you can't get the fitting off the rubber hose, it looks like it is available from Rock Auto for about $10 or $12. I didn't need to purchase hose looked at the AutoZone web site and thought they had what I needed, PAX-472 and PAX-460. PolyArmour brake line in 1/4" diameter and 72 and 46 inch lengths. When I got to the store thay only had 72" lengths. I also bought 1/4" inverted flare unions, two to a pack.
Unfortunately when I got home I found the ends on the tubing were the wrong size, 7/16" instead of 1/2" that was on the vehicle. I cut the tubing and reused the 1/2" fittings and left the short 7/16" fittings on the tubing in order to screw into the union. I would recommend puchasing new 1/2" fittings, I didn't have a choice at the time.
Attached are 2 pics showing the length of tubing at the tank end. This required more tweeking once in place
Don't forget to use BP Blaster on the bleeder valves. I used a 6 point deep 5/16 socket to break them loose first then a 5/6" box during bleeding.
Good Luck!
timkb
Years of Membership: timkb has been a member for 12 full yearstimkb has been a member for 12 full yearstimkb has been a member for 12 full yearstimkb has been a member for 12 full yearstimkb has been a member for 12 full yearstimkb has been a member for 12 full yearstimkb has been a member for 12 full yearstimkb has been a member for 12 full yearstimkb has been a member for 12 full yearstimkb has been a member for 12 full yearstimkb has been a member for 12 full yearstimkb has been a member for 12 full years
Extra Info: LT AWD
Postby astro96007 [OP] » November 16th 2010, 12:38am
thanks alot for the replies, i am going to buy straight pieces from autozone 1/4 inch with the 1/2 fittings- thanks again
astro96007
Return to Brakes
It is currently April 21st 2021, 11:40pm
Brakes Forum
Astroratsun
in Brakes
Date: Apr 11 '21
Time: 7:25am
Gwicz
in Brakes
Date: Mar 27 '21
Time: 1:06pm
MATT1488
in Brakes
Date: Feb 16 '21
Time: 10:18am
in Brakes
Date: Feb 10 '21
Time: 3:04am
in Brakes
Date: Feb 09 '21
Time: 9:55pm
