Power Steering fluid Qwestion??
Postby tollbooth [OP] » September 5th 2011, 2:04pm
My auto parts store person said to use Dextron tranny fluid in my PS system. 2001 Safari. I know the guys here will know whats best for it. Help me before a woman behind a part counter ruins my van!
Thanks
Tollbooth
tollbooth
Years of Membership: tollbooth has been a member for 8 full yearstollbooth has been a member for 8 full yearstollbooth has been a member for 8 full yearstollbooth has been a member for 8 full yearstollbooth has been a member for 8 full yearstollbooth has been a member for 8 full yearstollbooth has been a member for 8 full yearstollbooth has been a member for 8 full years
Extra Info: 2wdr
  • No power steering/brakes
    by equitube » February 13th 2020, 9:35am in Steering
    April 28th 2020, 8:02pm
  • Air being sucked into power steering.
    by abelram57 » February 15th 2020, 10:51pm in Steering
    March 6th 2020, 6:43pm
    39
    August 12th 2020, 5:02am
Re: Power Steering fluid Qwestion??
Postby chevymaher » September 5th 2011, 2:18pm
This is what I use.I have no problems.I had a leak in a seal and this stuff does work.Fix it later syndrome.I have heard you can use tranny fluid and know people who do with no problems.For me it cheap enough just use the right stuff designed for it.Its different for a reason I am sure.And I dont really feel like doing a scientific paper to prove anything.Sorry had to add that disclaimer alot of drama lately.
Postby redfury » September 5th 2011, 2:38pm
Tranny fluid is hydraulic fluid, so yes it can be used since the power steering system is another hydraulic system in your van. Due to hydroboost brakes, I'm not entirely sure of the ramifications of using regular power steering fluid over dex/merc in it. I flushed my system and put power steering fluid in it, but my van has a whining PS pump and a noisy hydroboost, so take that how you want to.
redfury
Firing on 8 Cylinders (L3)
Topics: 53
Images: 13
Extra Info: LT 5.7L 4wd
Postby Lumpy » September 5th 2011, 4:41pm
I use Lucas. I was having a bit of leakage with my old pump/gearbox. Lucas
slowed or stopped it till I could eventually replace the parts.
Postby chevymaher » September 5th 2011, 5:07pm
redfury wrote:Tranny fluid is hydraulic fluid, so yes it can be used since the power steering system is another hydraulic system in your van. Due to hydroboost brakes, I'm not entirely sure of the ramifications of using regular power steering fluid over dex/merc in it. I flushed my system and put power steering fluid in it, but my van has a whining PS pump and a noisy hydroboost, so take that how you want to.
When mine started leaking I had no clue what to use due to it being hydroboost.I ask at work,Parts places,Generally no one I ask was sure what was really supposed to go in there.Anyway this stuff works no leaks now and no squealing.I been using it about a year now.Or shall I say I stopped using it because it quit leaking now.
Postby Phantom » September 5th 2011, 5:52pm
tollbooth wrote:My auto parts store person said to use Dextron tranny fluid in my PS system. 2001 Safari. I know the guys here will know whats best for it. Help me before a woman behind a part counter ruins my van!
Thanks
Tollbooth
That was common for many years to use tranny fluid in power steering systems,
but nowadays you would be better to use actual power steering fluid because these systems now have some changes in their design and you are better off using a fluid designed for modern day systems
I started using valvoline SYN Power power steering fluid and it is quieter and operates more smoothly ,, :D
Phantom
Firing on 7 Cylinders (L4)
Postby RECox286 » September 5th 2011, 6:05pm
Look in your owners' manual. You will find a list of fluids, that are GM recommended, to use in your particular truck. It has been my experience that (most) counter people at the LAPS are tuned in enough that you can
usually trust their recommendations. However, there are no stupid questions here, well, possibly only the ones that go unasked.
Good qwestion ! Some good answers.
Bob
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Alias (AKA): Uncle Bob
Extra Info: RWD V6 [325K mi]
Postby tollbooth [OP] » September 5th 2011, 11:02pm
Do you guys think I should flush it? There is a mix in it now!
tollbooth
Extra Info: 2wdr
Postby Phantom » September 5th 2011, 11:30pm
tollbooth wrote:Do you guys think I should flush it? There is a mix in it now!
I would just to be sure there is no problem later down the road , as you would not know if it caused a problem , The mixture of fluids can cause deterioration to the seals and may cause the pump to leak , I would flush it just to be sure that it was fresh fluid and the proper fluid , it promotes a longer healthier life for the parts and system as a whole :)
Phantom
Postby RECox286 » September 7th 2011, 12:23am
X2. Flush and refill is a recommended maintenance item for any component that has a fluid, lives in a nasty envoirnment and creates heat. Especially so if there is known contamination.
Bob
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Postby tollbooth [OP] » September 7th 2011, 4:56am
Did the flush and ran 3 qt's before it was clean. Suprised to see that the darkest fluid came out after the brake pedal was released. Moving the steering stop to stop produced half as dirty old fluid. Hope this helps others. thanks, Tollbooth . PS great site!!!!
tollbooth
Extra Info: 2wdr
Return to Steering
It is currently August 12th 2020, 5:02am
Steering Forum
swedishian
in Steering
Comments: 0
Date: May 24 '20
Time: 3:02am
Attached by: abelram57
abelram57
in Steering
Comments: 22
Date: Feb 18 '20
Time: 1:13am
Skipper_390
in Steering
Date: Nov 11 '19
Time: 3:10pm
qtband
in Steering
Date: Nov 09 '19
Time: 6:03pm
Attached by: AstroFanCZ
AstroFanCZ
in Steering
Comments: 0
Date: Nov 04 '19
Time: 7:01pm
