Shifting from reverse into drive causing steering issues
Postby Fenster [OP] » July 5th 2018, 7:39pm
Hi All,
I'm wondering if anyone might know what's happening here. From time to time, when I'm trying to park my safari or reverse it out of a spot, the steering seems to lock on me. It gets extremely stiff and difficult to turn the wheel. This can last for up to a couple of hours afterwards. If I've got my foot on the gas and giving it some power, the steering tends to loosen up again but once I'm going slow, it goes back to being stiff again. I think it might be when I shift from reverse into drive and press on the gas before it completely shifts into gear. Would this affect the steering? If so, what's the fix for it?
Fenster
Years of Membership: Fenster has been a member for 3 full yearsFenster has been a member for 3 full yearsFenster has been a member for 3 full years
Extra Info: 2WD
  • New steering gear & steering wheel feedback
    by Safarimeister » January 18th 2021, 4:21am in Steering
    Last post by Safarimeister View the latest post
  • Power Steering Pump Replacement
    by WakkoWarner » October 27th 2020, 11:44pm in Steering
    Last post by stent View the latest post
    November 9th 2020, 5:07pm
    41
    April 21st 2021, 9:56am
Re: Shifting from reverse into drive causing steering issues
Postby akforceten » July 5th 2018, 7:50pm
if the steering is getting stiff check the power steering fluid or maybe your PS pump is bad
98638 100250
akforceten
Years of Membership: akforceten has been a member for 11 full yearsakforceten has been a member for 11 full yearsakforceten has been a member for 11 full yearsakforceten has been a member for 11 full yearsakforceten has been a member for 11 full yearsakforceten has been a member for 11 full yearsakforceten has been a member for 11 full yearsakforceten has been a member for 11 full yearsakforceten has been a member for 11 full yearsakforceten has been a member for 11 full yearsakforceten has been a member for 11 full years
Topics: 32
Images: 128
Alias (AKA): akforceten
Extra Info: SLE 4x4 7 inch lift
Postby Fenster [OP] » July 5th 2018, 9:00pm
This doesn't feel like it's getting stiff though. It feels more like it's almost completely jammed. Only happens when I'm coming out of or into a parking situation where reversing and driving are involved. Do you think that would be a power steering issue rather than a transmission issue?
I've checked and changed the power steering fluid.
Fenster
Extra Info: 2WD
Postby TurnNburn » July 5th 2018, 9:39pm
almost certainly a PS issue, and not a trans issue. when the pump goes out and doesn't create pressure, there is no assistance. and with this wonky steering setup these vans have, it becomes very hard to steer. if power assistance comes back with RPMs then its definitely a pump issue.
My vote is the PS shaft sheared off inside the pump
TurnNburn
Green Status (L4)
Green Status (L4)
Alias (AKA): iGoogle
Postby Coaster » July 5th 2018, 10:36pm
with the sheared shaft the steering never comes back though. my bet is a failed pressure regulator and its a coincidence it happenes when it does. low speed idle and shifting the engine around on likely shot motor mounts moves something in the pump and shuts off the flow in the regulator
I LIVE IN NORTH DAKOTA
Coaster
Years of Membership: Coaster has been a member for 8 full yearsCoaster has been a member for 8 full yearsCoaster has been a member for 8 full yearsCoaster has been a member for 8 full yearsCoaster has been a member for 8 full yearsCoaster has been a member for 8 full yearsCoaster has been a member for 8 full yearsCoaster has been a member for 8 full years
Topics: 114
Extra Info: 4.3 cargo 2wd
Postby TurnNburn » July 5th 2018, 10:43pm
he says that if he gives it gas that it does come back a little bit
And it will only do that for so long. eventually the 2 pieces of the shaft will be smooth enough not to catch each other any more. My last van had that problem. Even with rpms it would not work at all. imagine my surprise when I went to pull the shaft, the pulley came off, with the shaft attached to it still.
TurnNburn
Green Status (L4)
Green Status (L4)
Postby Coaster » July 5th 2018, 10:53pm
when mine broke it went TING and no steery brakey
Coaster
Topics: 114
Postby TurnNburn » July 5th 2018, 11:09pm
hmmm yeah, perhaps your right. I think either way your pulling the pump off and taking a look.
TurnNburn
Green Status (L4)
Green Status (L4)
Postby akforceten » July 5th 2018, 11:13pm
mine never made any noise when it broke everything just got real hard lol
98638 100250
akforceten
Topics: 32
Images: 128
Postby Fenster [OP] » July 5th 2018, 11:22pm
Yeah, it might be time to take it to the mechanic and ask him/her to take a look at it. It's been going on a while now and it's pretty scary when it happens as I can't steer the car properly for a while until it goes back to normal.
Fenster
Extra Info: 2WD
Postby multimoto » July 5th 2018, 11:48pm
how have you ruled out a belt problem? perhaps is getting a drip of some type of fliud thats built up in a spot that reversing casued that spot to drip right onto the pully groove and then after a while the belt smears it into nothing and then it grips again.
belts can slip without making any noises too so it may not even be a contaminant on the pulley.
Edit: also, is it happening when only @ full lock? Ive noticed odd behavior on some PS pumps @ full lock only.
'87 GMC Safari Explorer
multimoto
Years of Membership: multimoto has been a member for 3 full yearsmultimoto has been a member for 3 full yearsmultimoto has been a member for 3 full years
Topics: 12
Images: 369
Van Model Year: 1987
Extra Info: Explorer
Postby Big_kid » July 6th 2018, 3:22am
Get under it and see if anything is interfering with the drag link/look for rubbing/clean spots/interference. When it locks up, safely put the front up on stands and see if you can determine where the problem lies.
Topics: 185
Images: 344
Extra Info: 2WD 5.7 V8
Postby Fenster [OP] » July 6th 2018, 3:51pm
multimoto wrote:how have you ruled out a belt problem? perhaps is getting a drip of some type of fliud thats built up in a spot that reversing casued that spot to drip right onto the pully groove and then after a while the belt smears it into nothing and then it grips again.
I'm not sure if it's happening at full lock. I wouldn't be surprised because as I said, it only tends to happen when I'm parking the vehicle which is when it would be in a full lock.
Fenster
Extra Info: 2WD
Postby Fenster [OP] » July 12th 2018, 5:20am
Thanks to everyone who helped out. I just wanted to update y'all since you took the time to reply. I took it to our mechanic. He told us that there's a leak in the hose of the power steering. Hoping it's a simple enough fix. Thanks again everybody.
Fenster
Extra Info: 2WD
Postby Big_kid » July 12th 2018, 2:22pm
Thank you for the update!
Topics: 185
Images: 344
Return to Steering
It is currently April 21st 2021, 9:56am
Steering Forum
Attached by: icebrrg3rd
icebrrg3rd
in Steering
Date: Apr 13 '21
Time: 3:42pm
ASTROMATT0630
in Steering
Date: Apr 06 '21
Time: 10:53am
in Steering
Comments: 31
Date: Feb 20 '21
Time: 12:26am
arian
in Steering
Comments: 31
Date: Feb 11 '21
Time: 6:47am
arian
in Steering
Comments: 31
Date: Jan 28 '21
Time: 6:03am
