Anybody have any suggestions?
Ed
by osb316 [OP] » September 1st 2008, 4:20pm
by turnitup » September 8th 2008, 3:49am
by Hank » January 26th 2009, 3:41am
by lowrentride » September 28th 2009, 8:40am
by sandstorm » October 12th 2009, 1:50am
by nehopsa » October 31st 2010, 8:59pm
by nehopsa » October 31st 2010, 10:42pm
by Hank » November 1st 2010, 2:21pm
by astroturf » November 1st 2010, 4:50pm
by Hank » November 1st 2010, 7:31pm
by astroturf » November 1st 2010, 9:11pm
by nehopsa » August 19th 2011, 1:47am
by Leeann_93
» August 19th 2011, 10:11pm
by Hank » August 20th 2011, 1:40am
by cowboydan » October 13th 2011, 2:18pm
nehopsa wrote:Has there been resolution to the vibration problem at 65-70 mph problem in Astros ? I have 2001 AWD with 112 k on it. Since I changed the shocks some four months ago vibration appeared but changing back to OEM dealer specs today solved nothing. I may be light on trigger by considering junking the car but what I am fearing is a story like this one I am pasting here (which I could not find resolved):
START OF QUOTATION:
"It has a vibration between 65 and 70 mph. The vibration has gotten worse over the last 6 months so I suspect that something is wearing out in the drive train. I had my mechanic check it and he balanced wheels and said that one tire took a lot of weight to balance but it did balance. Then I had him replace U-joints when that did not work. Then had him replace shocks. When that did not work mechanic said maybe rear wheel not fitting tightly to brake drum so replaced the drum. When that did not fix it I took van to Chevy Dealer. They said the tires were lousy and replaced tires. When that did not fix it they said the drive shaft must have been bent when mechanic changed U-joints so they replaced it. When that did not work they changed front brake rotors. (One rotor had bad spot on it so it needed changing.) The vibration persisted. Dealer took off my Yakima roof rack and put OEM shocks on the front and that did not fix it. Last time we test drove it we did so with chief tech and GM rep. Yup, vibration still there. The dealer says they have checked bearings, have put different wheels on the front, put vibration monitors on it and they still cannot figure out what the problem is. They really are trying to figure it out but still the vibration persists.
They have had the van on the lift several times and cannot see the vibration when the van is running on the lift at speed.
The dealer says that they also have a second Astro van with similar problem." END OF QUOTATION
This other guy did everything imaginable. Among other he also changed the shocks (so that it was not that stupid after all). I definitely do not want to end up spinning around this issue. Has anybody found anything that could be done to avoid a horror of the above? To me the surest way out is ...junk the car if there is something like this to deal with.
Of course, before the shocks I did balance the tires (and of course, nothing happened). CV joints that [http://www.ehow.com/about_5612890_chevy-astro-van-problems.html ] mentions as a known issue that can cause exactly the vibrations I report were replaced in March (before the problem started) with new ones. Could I have gotten through Advance Auto Parts really junky CV joints that would go after only two months to start the reported vibration issue??? U-joints are new too..(Moogs).The bearings have been also recently switched for Timkens. ...
Any thoughts anybody? Appreciated.
by mechwarrior75 » December 23rd 2016, 4:28pm
It is currently March 9th 2021, 2:29am
Steering Forum |
Moderator: chevy57bert |
Previous topic Next topic |
Sponsors |
