Return Hose from reservoir to pump
Postby gavio [OP] » May 15th 2020, 8:20pm
Well, I had to cut the hose to get it off so I could replace the pump, figuring no problem I will just grab a new one at the LAPS..... This is the large diameter low pressure hose that is held on with clamps....
So Oreilly lists the hose but the detailed description says it is 3/8 ID hose.... The Zone lists the part in their brand, but the details say it is 5/8 ID..... I measure the outlet on the pump and it looks like pretty close to half inch.... WTF?
Any of you who have replaced that hose, what did you use? And from where?
I don't live in town so it's a project to go get stuff, I'd like to know what I'm getting and if they have it before I go.....
Thanks for any help....
gavio
Topics: 77
Images: 4
  • cracked PS pump can
    by dit » June 26th 2020, 1:21am in Steering
    Last post by dit View the latest post
    June 26th 2020, 1:56am
    15
    September 24th 2020, 2:31am
Re: Return Hose from reservoir to pump
Postby AstroWill » May 15th 2020, 9:21pm
RA lists the ACdelco part as 5/8 ID https://www.rockauto.com/en/moreinfo.php?pk=983876
Basically 16mm or really, really, really close, really.
Is this what you were getting on Oreilly? https://www.oreillyauto.com/shop/b/susp ... rvoir+line
Let me go measure mine. BRB
Measured the top hose(to hydroboost), skinny part of the nipple on the reservoir at 10mm, so ~ 3/8
The bottom hose that goes to the pump, nipple measured at 15mm, so ~ 5/8.
Topics: 106
Images: 437
Postby gavio [OP] » May 15th 2020, 9:41pm
Now I'm just confused, the AC Delco listing says 5/8 (I'd missed that as I wanted to buy local so I can get er done), and I'd confused the listing on Oreilly with another, so the correct one there also shows 5/8..... The nipple on my pump is def bigger than 3/8.... I will have to measure again and see if I can make it look like 5/8....
There is a 3/8 hose on the side of the reservoir that goes to the hydroboost, but that isn't the one in question.....
gavio
Topics: 77
Images: 4
Postby AstroWill » May 15th 2020, 9:46pm
I was updating my post as you were replying, that nipple at the bottom(the one that goes down to the pump) measured at 15mm, so 5/8 for that hose.
Topics: 106
Images: 437
Postby gavio [OP] » May 15th 2020, 10:51pm
OK, cool, thank you for checking... I must have measured wrong.... I'm gonna order one and hopefully put it on tomorrow so I will now for sure then....
gavio
Topics: 77
Images: 4
Postby gavio [OP] » May 16th 2020, 12:43am
Now I feel a little ridiculous..... I measured again the nipple on the pump and it is sort of stepped, the end is about 1/2, while the main body is 5/8.... Should have looked more closely the first time....
Thanks for the help, Will....
gavio
Topics: 77
Images: 4
Postby markmitchmarkmitch is online! » May 16th 2020, 2:26am
They sell a filter that goes inline for the power steering to if your interested. I installed a filter and a cooler on mine just because I can lol.
https://www.speedwaymotors.com/Lares-29 ... jjEALw_wcB
https://autoplicity.com/328911-derale-c ... GEEALw_wcB
Firing on 4 Cylinders (L6)
Topics: 596
Images: 20
Extra Info: RS V8
Return to Steering
It is currently September 24th 2020, 2:31am
Steering Forum
Ken2.7
in Steering
Comments: 35
Date: Sep 17 '20
Time: 6:34pm
swedishian
in Steering
Date: May 24 '20
Time: 3:02am
Attached by: abelram57
abelram57
in Steering
Comments: 22
Date: Feb 18 '20
Time: 1:13am
Skipper_390
in Steering
Date: Nov 11 '19
Time: 3:10pm
qtband
in Steering
Date: Nov 09 '19
Time: 6:03pm
