PS Pump Swap Reservoir?
Postby Rando [OP] » October 3rd 2020, 12:57am
Hi all,
I'm losing my @#%@#$ mind trying to replace my power steering pump and would appreciate any help! I have a 1997 AWD Astro.
I got the PS Pump out, but the replacement I got came with a "reservoir" that's that doesn't match mine -- CARDONE 208753
https://www.rockauto.com/en/moreinfo.php?pk=30252&jsn=3
No problem I figured.. I'll just pop my current leaking pump out of the current reservoir (is that what it's called?) and pop the new pump in there... it seems like that's what you'd do if you got one from NAPA, etc anyway.
Well.. I can't figure out how to get it out! I've included a picture of the back of the PS pumps.. does anyone know which bolts/nuts need to be removed? I can't tell if some of the bolts are welded to the reservoir because they aren't budging!
Any and all advice appreciated! Thanks in advance everyone!
Rando
Alias (AKA): Andrew
  • Power steering broken after reservoir swap
    by chrissommer1995 » October 20th 2020, 7:23pm in Steering
    October 21st 2020, 7:03pm
  • cracked PS pump can
    by dit » June 26th 2020, 1:21am in Steering
    Last post by dit View the latest post
    June 26th 2020, 1:56am
    November 24th 2020, 11:04am
Re: PS Pump Swap Reservoir?
Postby M_a_t_t » October 3rd 2020, 1:27am
Is there an issue with using the new pump as is? It looks like it has both fittings you need. My replacement pump had the bolt holes too, but since my van didn't use them I had to plug them with those bolts, which I thought was intended since my old pump was setup exactly the same way.
Also they usually offer both with reservoir and without at your LAPS. When I was still at Autozone I always recommended with reservoir for our style of pump.
I believe it is a press fit on, but have never messed with one. That's just what I've heard.
1973 Fiat 124 Special
1975 Honda Civic CVCC 4spd
1981 Kawasaki KZ750E
1981 Kawasaki KZ650 CSR
1983 Kawasaki KZ1100-A3
1986 Nissan 300zx Turbo 5 spd
1995 Chevy Astro RWD
1995 Mercury Tracer
2004 Chevy Astro AWD
2017 Kawasaki VersysX 300
M_a_t_t
Topics: 27
Images: 96
Extra Info: cl rwd
Postby Rando [OP] » October 3rd 2020, 2:17am
Thanks for the info Matt!
The reservoir that came with my replacement pump is an entirely different shape... kind of a tear drop/cam/elongated oval shape whereas the one I pulled from my van is a circle.
I was looking at pumps on napa and autozone, but based on the online photos, it appears I'll still need to swap out some stuff. I believe that middle extrusion part is the power dependant steering.. I think. Maybe I'm just not cranking on the parts hard enough, but want to make sure before I break something!
I'm honestly a bit confused by the whole set up and could use some guidance. I've been going through the manual and can't seem to find what I'm looking for either.
Rando
Alias (AKA): Andrew
Postby CopperFiremistCopperFiremist is online! » October 3rd 2020, 3:22am
Pullin The Pass
Firing on 1 Cylinder (L2)
Topics: 24
Images: 6
Alias (AKA): B
Extra Info: LS Swap
Postby Rando [OP] » October 3rd 2020, 3:27am
Ah, perfect. I did a bunch of searching around the forum.. not sure how I missed it.
Thank you so much!
Rando
Alias (AKA): Andrew
Postby CopperFiremistCopperFiremist is online! » October 3rd 2020, 3:48am
No problem
Pullin The Pass
Topics: 24
Images: 6
Alias (AKA): B
Extra Info: LS Swap
Return to Steering
It is currently November 24th 2020, 11:04am
Steering Forum
in Steering
Date: Nov 07 '20
Time: 4:46am
in Steering
Date: Oct 21 '20
Time: 7:55pm
Attached by: snailsafari
snailsafari
in Steering
Date: Oct 15 '20
Time: 9:52pm
SainT
in Steering
Date: Oct 14 '20
Time: 7:14am
Rando
in Steering
Date: Oct 03 '20
Time: 12:57am
