Power Steering Pump Replacement
Postby WakkoWarner [OP] » October 27th 2020, 11:44pm
Decicded to change the power steering pump out today, now that the weather is nice again (it started leaking about 6 months after I installed a new steering gear, new hydro-boost unit, and new pressure/return hoses). The fluid that came ouf of the hoses/lines was extremely clean. So, I just installed the new pump, added some fluid, primed the pump, added some more fluid, bled the system, then away I went. It is working fine and no noises (the old one would make some noise when under stress - not a whine, but a sound you could definitely hear) - the new one is quiet.
The biggest problem is getting the fan/clutch assembly removed. I ended up renting a tool from Autozone that did the job, but I would really like to have the correct tool(s) on hand. Does anyone know if the Lisle 44180 will fit the hold spread on the Astro water pump pulley (the pulley has four holes in addition to the 4 bolt holes in it)?? Also, is the fan clutch nut/hub 36mm??
I am think about purchasing either this kit from KD or a wrench that is 32mm/36mm, along with the Lisle tool:
https://www.ebay.com/itm/Automotive-Pul ... 1438.l2649
https://www.ebay.com/itm/Lisle-Tools-44 ... SwhC1ffbhR
https://www.ebay.com/itm/32mm-36mm-Fan- ... 1438.l2649
WakkoWarner
Fueling (1/2 tank)
Fueling (1/2 tank)
Years of Membership: WakkoWarner has been a member for 9 full yearsWakkoWarner has been a member for 9 full yearsWakkoWarner has been a member for 9 full yearsWakkoWarner has been a member for 9 full yearsWakkoWarner has been a member for 9 full yearsWakkoWarner has been a member for 9 full yearsWakkoWarner has been a member for 9 full yearsWakkoWarner has been a member for 9 full yearsWakkoWarner has been a member for 9 full years
Topics: 18
Location: 200 miles from water, 2 feet from hell - aka Arizona
Extra Info: LS 4.3L V6 RWD
  • Power steering pump issue?
    by Hillbent » February 9th 2021, 12:04am in Steering
    February 10th 2021, 2:16am
  • New steering gear & steering wheel feedback
    by Safarimeister » January 18th 2021, 4:21am in Steering
    Last post by Safarimeister View the latest post
    56
    April 18th 2021, 3:43am
Re: Power Steering Pump Replacement
Postby CopperFiremistCopperFiremist is online! » October 28th 2020, 12:02am
Pullin The Pass
Firing on 1 Cylinder (L2)
Years of Membership: CopperFiremist has been a member for 6 full yearsCopperFiremist has been a member for 6 full yearsCopperFiremist has been a member for 6 full yearsCopperFiremist has been a member for 6 full yearsCopperFiremist has been a member for 6 full yearsCopperFiremist has been a member for 6 full years
Topics: 25
Images: 6
Alias (AKA): B
Extra Info: LS Swap
Postby Leeann_93 » October 29th 2020, 1:04am
I bought my set at NAPA. 36mm for GM, 40mm for Ford.
They had it on the shelf.
Postby AstroWill » October 29th 2020, 3:18am
If you do it all the time it's probably worth the cost of the tools and that one CopperFiremist listed is the bees knees(though I would buy a quality piece like a Lisle https://amzn.to/34zVhxE that is going to last, lots of el cheapo replicas will start to spread).
If you just want a holder, you can get them for like $10-15 or make one with scrap of this design https://amzn.to/3jAcUS5 Jegs or Summit has it cheap but I forget which one it was, if you aren't in a rush you can add it to your next order that qualifies for free shipping.
I just use my largest adjustable wrench and wack it with a mini sledge. If it's ever really hard and you are replacing the water pump, a quick tap on the edge with an air hammer takes care of that.
Topics: 109
Images: 473
Postby stent » November 7th 2020, 4:58am
here's some pics of the Kent-Moore version of the holder tool and an OTC 36mm nut wrench.
Kent-Moore holder No. J-46406-01.
OTC wrench No. 7204E2.
they show up on Ebay.
Images: 188
Extra Info: rwd cargo
Postby dcsleeperdcsleeper is online! » November 7th 2020, 5:10pm
Profile | Edit signature
RandomInternetUser wrote:I blame stupidly-written 1970s and 1980s TV shows.
Years of Membership: dcsleeper has been a member for 1 full year
Topics: 21
Images: 79
Alias (AKA): DC
Postby stent » November 9th 2020, 5:07pm
SDS-MAX !!!!!!!!
i no longer have a BFH but i still have a BFS
Images: 188
Return to Steering
It is currently April 18th 2021, 3:43am
Steering Forum
Attached by: icebrrg3rd
icebrrg3rd
in Steering
Date: Apr 13 '21
Time: 3:42pm
ASTROMATT0630
in Steering
Date: Apr 06 '21
Time: 10:53am
in Steering
Comments: 31
Date: Feb 20 '21
Time: 12:26am
arian
in Steering
Comments: 31
Date: Feb 11 '21
Time: 6:47am
arian
in Steering
Comments: 31
Date: Jan 28 '21
Time: 6:03am
