by arian [OP] » January 28th 2021, 6:03am
by AstroWill » January 28th 2021, 7:52am
arian wrote:Do I just need to remove the six bolts and hang the compressor with a bungee?
by arian [OP] » January 28th 2021, 10:14am
by arian [OP] » February 10th 2021, 7:31am
AstroWill wrote: Yes, remove the bolts for the AC compressor, but don't disconnect the lines at all. That will allow you to move the bracket and get enough room for the rest.
by AstroWill » February 10th 2021, 8:13pm
by Mmusicman » February 10th 2021, 9:54pm
by arian [OP] » February 10th 2021, 11:07pm
Mmusicman wrote:Yes.. if the PS pulley is not seated correctly, it will likely throw the belt.
Of course, it is assumed the bracket is mounted square on the block.
Last time I did mine.. I used a straight-edge/square to be certain it all lined up.
AstroWill wrote:Hmm, have a picture of how it sits right now? One from top down and one of the front of the pulley would be great.
by AstroWill » February 11th 2021, 3:02am
by arian [OP] » February 11th 2021, 7:03am
AstroWill wrote:Shaft length doesn't matter as long as you can hit the spot where everything is in alignment. It's designed so that there can be some adjustment, can't just put it flush with the shaft and call it good.
by Mmusicman » February 11th 2021, 7:15am
by arian [OP] » February 11th 2021, 7:19am
Mmusicman wrote:You can't just go by visual...
It's needs to be aligned with a straight edge/square or something equivalent and precise.
Of course measuring technique will greatly affect results.
Have you simply tried to drive the pulley further on?
by Mmusicman » February 11th 2021, 7:20am
by arian [OP] » February 11th 2021, 7:22am
Mmusicman wrote:Is that a gap in your last photo?
by CarpeDiem » February 11th 2021, 7:38am
by AstroWill » February 11th 2021, 5:40pm
by WinnieVan » February 11th 2021, 5:56pm
by arian [OP] » February 11th 2021, 11:37pm
WinnieVan wrote:How are you installing the pulley? With an install tool? That PS pulley needs to go WAY further down to get into alignment -- at least based on the picture of the alignment with the crank pulley.
Are you certain you got the right part? Did your new PS pump come with a new pulley?
AstroWill wrote:That pulley is way forward, why will it not go deeper on the shaft?
by AstroWill » February 11th 2021, 11:50pm
by arian [OP] » February 11th 2021, 11:54pm
AstroWill wrote:But is the pulley bottoming out, or are you just putting it on until it's flush with the end of the shaft?
by AstroWill » February 12th 2021, 12:07am
It is currently April 13th 2021, 1:51am
Steering Forum |
Moderator: chevy57bert |
Previous topic Next topic |
Sponsors |
