Idler arm - anyone seen this?
Postby Lowcountry [OP] » May 25th 2021, 5:46pm
'03 AWD Astro with 3+1 lift. I've owned this van for nearly a year and it was lifted about 9 months ago but no steering components have been replaced so I don't know their history. This past weekend I lost steering response when cornering a 90-degree blacktop turn (fortunately barely kept in my lane). I limped off to a side road. Popped the hood to make sure extended steering shaft hadn't come lose for some reason. All good there as my daughter turned the wheel some. Crawled underneath and immediately saw a snapped idler arm on the DS. Anyone else experience this? Before this there was never any indication that I could tell that the steering was wonky, even when I mounted the larger tires and had the shop check components. This was a stock family hauler before I got it and despite the lift it's not been offroad yet. As you can see in the pics there appears to be some discoloration through the metal at the break so I don't know if this was one of the cheaper parts. It doesn't say MOOG on the underside of one of the joints, for example.
Anyway, my neighbor brought me a new MOOG problem solver arm and some tools and 15 minutes later we were on our way. I plan to replace the PS, and then get an alignment. Steering wheel is slightly off level now too; rookie mistake maybe during gravel roadside fix that alignment will rectify? Thanks.
Lowcountry
Years of Membership: Lowcountry has been a member for 1 full year
Topics: 10
Extra Info: AWD 3+1 lift
  • Mevotech vs delco idler arms
    by smokinjoe » August 3rd 2021, 9:28pm in Steering
    Yesterday, 2:14am
    28
    August 5th 2021, 2:46am
Re: Idler arm - anyone seen this?
Postby Big_kid » May 25th 2021, 5:55pm
I've never seen that happen before. I replaced mine last week with an AC Delco. Glad nothing horrible happened!
Years of Membership: Big_kid has been a member for 13 full yearsBig_kid has been a member for 13 full yearsBig_kid has been a member for 13 full yearsBig_kid has been a member for 13 full yearsBig_kid has been a member for 13 full yearsBig_kid has been a member for 13 full yearsBig_kid has been a member for 13 full yearsBig_kid has been a member for 13 full yearsBig_kid has been a member for 13 full yearsBig_kid has been a member for 13 full yearsBig_kid has been a member for 13 full yearsBig_kid has been a member for 13 full yearsBig_kid has been a member for 13 full years
Topics: 185
Images: 358
Extra Info: 2WD 5.7 V8
Postby Lowcountry [OP] » May 25th 2021, 6:43pm
Me too! Thanks for the reply.
Lowcountry
Topics: 10
Postby markmitch » May 25th 2021, 6:53pm
scary stuff , never seen that either. Glad your all good after that.
Firing on 1 Cylinder (L7)
Topics: 642
Images: 21
Extra Info: RS V8 AWD
Postby Lowcountry [OP] » May 25th 2021, 7:09pm
Thanks!
Not sure I like the trend that is developing...
I don't mind being unique but not for reasons like this.
Lowcountry
Topics: 10
Postby Mmusicman » May 25th 2021, 7:18pm
Ball joints break, spindles break, and now add idler arms break.
It's rare, but it apparently does happen.
Good for you that things didn't get worse.
Firing on 1 Cylinder (L6)
Years of Membership: Mmusicman has been a member for 8 full yearsMmusicman has been a member for 8 full yearsMmusicman has been a member for 8 full yearsMmusicman has been a member for 8 full yearsMmusicman has been a member for 8 full yearsMmusicman has been a member for 8 full yearsMmusicman has been a member for 8 full yearsMmusicman has been a member for 8 full years
Topics: 75
Images: 61
Postby Lowcountry [OP] » May 25th 2021, 7:27pm
Appreciate it!
Just wish I knew the history of them as well as brand.
Lowcountry
Topics: 10
Postby Rod's Trucks » May 25th 2021, 7:55pm
You are lucky it happened where it did!
It could have been in a MUCH worse place, or much less accessible location.
From the rust spots, it looks like it could have been cracked previously ( maybe as a result of trying to remove it at some previous time). Or is that fresh rust from after the break?
Either way, you survived the failure and fixed it without major incident. :clap: :clap: :wave:
Rod J
Rod's Trucks
Firing on 7 Cylinders (L1)
Topics: 41
Images: 60
Alias (AKA): Rod and/or WE7X
Postby Lowcountry [OP] » May 25th 2021, 8:01pm
Thanks Rod!
That is not fresh rust as that was taken shortly after I got home. I'm thinking it was compromised by those stains and just waiting to fail. Fortunately, it was me at the wheel and not my daughter who just got her learner's permit.
Lowcountry
Topics: 10
Postby MI_GhostMI_Ghost is online! » May 29th 2021, 3:43am
One of the side effects of the +1 part of the lift that seldom gets talked about. When you crank the bars up for that extra lift. You effectively also increase the angle of the tie rod. Every bump makes the tie rod pull down as well as out. This normally results in the pivot wearing out faster.
Take that mounting leg section and cut the broken end off. Then place it between the frame and new idler arm using longer bolts. This will help relieve some of the stress caused by the lift.
~Ghost
Ast' Cargo: 2001 Astro Cargo
Beauty: 2009 Impala LT
https://www.astrosafari.com/gallery/sea ... r_id=66010
Firing on 5 Cylinders (L2)
Topics: 10
Images: 124
Alias (AKA): Ghost
Van Model Year: 2001
Extra Info: Big White RWD Box
Postby Leeann_93 » May 31st 2021, 7:41pm
I’ve seen cheap idler arms fail, but I’ve never seen one break.
Good thing your daughter wasn’t at the wheel.
Topics: 45
Postby sixsixsixsix is online! » May 31st 2021, 9:36pm
MI_Ghost wrote:...
Yeah, and I couldn't believe someone could break an 1"+ diam. axle either.
Anyway, seems someone here or on the other site did...
- the "Old Idler Arm Body used as a spacer for lifted Van's Idler Arms" mod.
"1 Nautilus died, BLM spawned, Antifa runs amok
- CRT & unions have taken schools by storm
THEN:
Not a single "Black" "Leader" condemns Black Crime
- White Supremacists get blamed for it all - they sure do get around"
Years of Membership: sixsix has been a member for 7 full yearssixsix has been a member for 7 full yearssixsix has been a member for 7 full yearssixsix has been a member for 7 full yearssixsix has been a member for 7 full yearssixsix has been a member for 7 full yearssixsix has been a member for 7 full years
Topics: 39
Images: 1411
Postby keith92ext » June 1st 2021, 12:36am
yikes!!! never seen that one of those break like that before...
keith92ext
Years of Membership: keith92ext has been a member for 5 full yearskeith92ext has been a member for 5 full yearskeith92ext has been a member for 5 full yearskeith92ext has been a member for 5 full yearskeith92ext has been a member for 5 full years
Topics: 42
Alias (AKA): keith
Extra Info: 4.3 rwd
Postby WoodButcher » June 1st 2021, 6:27pm
Idler arms replacement should not affect the alignment so it was not your doing or a "noob mistake". After it broke when you got on the brakes to stop the uncontrolled (steering) tire probably torqued things around a bit. Be sure to check and replace any loose or worn steering components before your new alignment.
WoodButcher
Firing on 6 Cylinders (L6)
Topics: 30
Images: 514
Alias (AKA): Bruce
Extra Info: 5.7L RWD
Postby Lowcountry [OP] » June 8th 2021, 5:33am
Everyone,
Thanks for the responses. I've been busy with work so I haven't had a chance to respond.
Yep, I hadn't heard this. I need to check how much the t-bars are actually cranked as I don't think they're maxed. I can't remember past breakfast and I don't have it in my notes. I need to order the other arm, and then make the spacers and check other components as suggested while knocking around under there.
Again, thanks everyone and yes I'm thankful the new driver wasn't at the wheel. This will ultimately be her van, we're doing a dad/daughter build to learn life skills like changing a tire, power tools, etc, so I need to have it right.
Lowcountry
Topics: 10
Return to Steering
It is currently August 5th 2021, 2:46am
Steering Forum
in Steering
Date: Jun 30 '21
Time: 9:07pm
in Steering
Date: Jun 29 '21
Time: 11:11pm
in Steering
Comments: 9
Date: Jun 08 '21
Time: 3:05am
Attached by: gavio
gavio
in Steering
Comments: 9
Date: Jun 08 '21
Time: 2:03am
Lowcountry
in Steering
Comments: 14
Date: May 25 '21
Time: 5:43pm
