Steering Wheel and brake pedal shudder / vibration
Postby mmxchamp [OP] » October 12th 2012, 5:18pm
So I'm new to Chevys, but my girlfriends Astro has issues with the steering wheel and brake pedal. When you press the brake pedal hard it will shudder / vibrate. If you let up on the pressure a bit, it ususally keeps the van stopped and the vibration lessens but you can still feel it a little in the pedal. If that makes any sense! lol.
At the same time, the power steering works but when turning the wheel too far while parking the whole engine kinda shudders (or feels like it at least). Does this van have Hydroboost? If so, I'm assuming some diagnosing of the power steering system will be required...I prefer not to throw parts at problems.
Thanks for your help!!
mmxchamp
Years of Membership: mmxchamp has been a member for 8 full yearsmmxchamp has been a member for 8 full yearsmmxchamp has been a member for 8 full yearsmmxchamp has been a member for 8 full yearsmmxchamp has been a member for 8 full yearsmmxchamp has been a member for 8 full yearsmmxchamp has been a member for 8 full yearsmmxchamp has been a member for 8 full years
Van Model Year: 1996
Extra Info: 4.3l V6 RWD
  • Power Steering and Brake loss
    by Mickmon » October 3rd 2020, 6:42pm in Steering
    Last post by Mickmon View the latest post
    October 17th 2020, 10:24pm
  • Steering wheel change after lift
    by swedishian » May 24th 2020, 3:03am in Steering
    Last post by M_a_t_t View the latest post
    September 6th 2020, 6:08am
    7
    28
    October 26th 2020, 5:50pm
Re: Steering Wheel and brake pedal shudder / vibration
Postby Lumpy » October 12th 2012, 7:29pm
Hooray to hear that!
If your power steering fluid reservior is a seperate can mounted on the firewall it's hydroboost. If the fluid goes into the pump instead, it's vacuum boost. Sounds like yours is hydro, to which I'm stupid. But others aren't. May we assume that your PS and brake fluid levels are ok? Does the van idle ok? Any fluid leaks around the brakes or hoses? Leaks around the PS pump or steering gear?
Postby mmxchamp [OP] » October 12th 2012, 7:44pm
Hi Lumpy, thanks for the help!
I'm pretty sure it has the separate reservoir; but I've only looked in there twice. I'll confirm when the van gets home today. Hopefully she brings the girlfriend home with her :-P
I checked the PS and brake levels 2 weeks ago and all seemed fine; its been making the noises "forever" according to the driver. Van idles fine as long as no brake pedal or steering while use is happening. I didn't notice any obvious fluid leaks, but I'm planning on cleaning it all off well tonight and then seeing if I notice any leaks. I too have never seen hydro up close and personal (I've only owned Fords) but from what I understand the hydrobooster does both PS and brakes.
mmxchamp
Postby grandamle91 » October 12th 2012, 9:09pm
Mine has hydro and when you push the pedal the engine will bog down because the pump is pulling hard on the motor. As far as the vibration mine did that when there was air bubbles in the system
-Evan
MONSTRO 97 Chevy Astro 346k
LQ9
4L80E
NP262
Full float 14 bolt 3.73
Tuned for e85
Headers 4in Exhaust
3500 spindles and hubs
285\85-16
98 Pontiac Grand Prix GTP 253k
***Removed Dead Image***
grandamle91
Years of Membership: grandamle91 has been a member for 12 full yearsgrandamle91 has been a member for 12 full yearsgrandamle91 has been a member for 12 full yearsgrandamle91 has been a member for 12 full yearsgrandamle91 has been a member for 12 full yearsgrandamle91 has been a member for 12 full yearsgrandamle91 has been a member for 12 full yearsgrandamle91 has been a member for 12 full yearsgrandamle91 has been a member for 12 full yearsgrandamle91 has been a member for 12 full yearsgrandamle91 has been a member for 12 full yearsgrandamle91 has been a member for 12 full years
Topics: 137
Images: 2
Alias (AKA): Evan
Extra Info: LT 6.0 V8 4L80E NP2
Postby Ragenme » October 12th 2012, 9:18pm
Sounds like a bad set of rotors. If there's not shake till you hit the brakes,I'd go with a new set of rotors. Replace your brakes while your in there. As for your p/s sounds as something is binding. If you go hard over and it kicks back alittle your going to the edge of its limits. It's just letting you know. It could be a good idea to drain your p/s fluid and put in some fresh fluid.
ragenme If you can't fix it with a hammer then its probably a electrical problem!
Ragenme
Years of Membership: Ragenme has been a member for 8 full yearsRagenme has been a member for 8 full yearsRagenme has been a member for 8 full yearsRagenme has been a member for 8 full yearsRagenme has been a member for 8 full yearsRagenme has been a member for 8 full yearsRagenme has been a member for 8 full yearsRagenme has been a member for 8 full years
Topics: 16
Images: 23
Alias (AKA): Ragenme
Extra Info: SLX 4.3 V6 RWD
Postby grandamle91 » October 12th 2012, 9:40pm
But he said it was vibrating while sitting still
-Evan
LQ9
4L80E
NP262
Tuned for e85
Headers 4in Exhaust
285\85-16
grandamle91
Topics: 137
Images: 2
Alias (AKA): Evan
Postby mmxchamp [OP] » October 13th 2012, 3:41am
That's correct, the brake pedal vibrates when you're sitting still. I've had warped rotors on a different vehicle, definitely not that.
I took a look at the reservoir and the fluid is full. It is definitely a hydro boost; are all Astros hydro boost? I'll try to get the air out of the system tomorrow morning and see if that helps. If not, I guess its replacement pump time?
mmxchamp
Postby grandamle91 » October 13th 2012, 4:28am
No not all were, If you need a pump I have a garage full of them. I would drain and put fresh in there, I run the lacus power steering fluid in mine
-Evan
LQ9
4L80E
NP262
Tuned for e85
Headers 4in Exhaust
285\85-16
grandamle91
Topics: 137
Images: 2
Alias (AKA): Evan
Postby mmxchamp [OP] » October 13th 2012, 4:35am
Ill try the drain, refill, and get the air bubbles out. What's the best way to drain all the fluid out?
mmxchamp
Postby grandamle91 » October 13th 2012, 4:46am
I pull the hose that runs down the pump off and let it drain, You didn't say what year yours was but with that hose off and engine off turn the steering clock to clock couple times and reconnect the hose, refill, start engine turn the wheel couple more times check fluid
-Evan
LQ9
4L80E
NP262
Tuned for e85
Headers 4in Exhaust
285\85-16
grandamle91
Topics: 137
Images: 2
Alias (AKA): Evan
Postby mmxchamp [OP] » October 13th 2012, 5:11am
grandamle91 wrote:I pull the hose that runs down the pump off and let it drain, You didn't say what year yours was but with that hose off and engine off turn the steering clock to clock couple times and reconnect the hose, refill, start engine turn the wheel couple more times check fluid
Thats a nice sophisticated method for draining. :-P
I'll try this in the morning and report back. Thanks for all the help!!!
mmxchamp
Postby grandamle91 » October 13th 2012, 5:15am
Thanks, Always worked for me
-Evan
LQ9
4L80E
NP262
Tuned for e85
Headers 4in Exhaust
285\85-16
grandamle91
Topics: 137
Images: 2
Alias (AKA): Evan
Postby Lumpy » October 13th 2012, 5:35am
If you've got a right angle drill or air ratchet, drain the PS pump by disconnecting that hose, disconnect the serp belt, put a socket on the front of the pulley and power drain the thing. Quickie Wickie.
I keep finding more and more uses for that air ratchet.,, :banana:
Postby mmxchamp [OP] » October 13th 2012, 6:16pm
Well I'm unfortunately without an air ratchet or 90 deg drill. I gravity bled everything, and refilled and tried to get the air out. Still seems like there are air bubbles in it, see the last pic once get them attached.. Also have a video of the noise, I'm uploading it to YouTube now.
Video: http://www.youtube.com/watch?v=ZRUAPeFga5g
Old brake fluid :shock:
Under the Hood:
Reservoir after turning the wheel side to side about 30 times:
mmxchamp
Postby grandamle91 » October 13th 2012, 7:14pm
Sounds like a fan hitting the shout
-Evan
LQ9
4L80E
NP262
Tuned for e85
Headers 4in Exhaust
285\85-16
grandamle91
Topics: 137
Images: 2
Alias (AKA): Evan
Postby mmxchamp [OP] » October 13th 2012, 7:17pm
grandamle91 wrote:Sounds like a fan hitting the shout
Shroud??
I'll go look and see if I notice that, but it doesn't change the fact I can feel the brake pedal vibrating.
mmxchamp
Postby mmxchamp [OP] » October 13th 2012, 7:34pm
The fan blade spins free by hand, so I think its OK. The PS fluid was free of bubbles, but when I started it up and spun the wheel size to side a few times there were bubbles in the reservoir again...seems like the pump is creating air.
mmxchamp
Postby grandamle91 » October 13th 2012, 7:36pm
Sorry autocorrect on my phone, Ok after watching the video on my computer the pump is on it way.
-Evan
LQ9
4L80E
NP262
Tuned for e85
Headers 4in Exhaust
285\85-16
grandamle91
Topics: 137
Images: 2
Alias (AKA): Evan
Postby mmxchamp [OP] » October 13th 2012, 7:39pm
Yea, that's what I feared. Guess I'll go ahead with replacing the pump then. Poop!
mmxchamp
Postby grandamle91 » October 13th 2012, 8:13pm
If you need one ill sell ya one, cheap. I'm not in it for the money. Just in for helping another stro
-Evan
LQ9
4L80E
NP262
Tuned for e85
Headers 4in Exhaust
285\85-16
grandamle91
Topics: 137
Images: 2
Alias (AKA): Evan
Return to Steering
It is currently October 26th 2020, 5:50pm
Steering Forum
in Steering
Date: Oct 21 '20
Time: 7:55pm
Attached by: snailsafari
snailsafari
in Steering
Date: Oct 15 '20
Time: 9:52pm
SainT
in Steering
Date: Oct 14 '20
Time: 7:14am
Rando
in Steering
Date: Oct 03 '20
Time: 12:57am
Ken2.7
in Steering
Comments: 36
Date: Sep 29 '20
Time: 10:33pm
