Steering Wheel not turning properly
Postby lilpig [OP] » March 13th 2013, 12:57am
Van started doing this about 2 years ago. Not sure why.
My mechanic noticed it one day and it stumped him. He said there was some kind of sensor in the steeling column that is bad but I have not been able to find any info about a sensor in the column.
Anyone know what this is? Please help if you can.
lilpig
Years of Membership: lilpig has been a member for 7 full yearslilpig has been a member for 7 full yearslilpig has been a member for 7 full yearslilpig has been a member for 7 full yearslilpig has been a member for 7 full yearslilpig has been a member for 7 full yearslilpig has been a member for 7 full years
Alias (AKA): lilpig
Extra Info: 4.3 RWD
Re: Steering Wheel not turning properly
Postby ccookie66 » March 13th 2013, 1:42am
Hmm.....thats weird. How is your power steering pump? No noises? Notice issues with your brakes?
1160
The Astro is always a turn key away from adventure.
ccookie66
Firing on 6 Cylinders (L2)
Years of Membership: ccookie66 has been a member for 9 full yearsccookie66 has been a member for 9 full yearsccookie66 has been a member for 9 full yearsccookie66 has been a member for 9 full yearsccookie66 has been a member for 9 full yearsccookie66 has been a member for 9 full yearsccookie66 has been a member for 9 full yearsccookie66 has been a member for 9 full yearsccookie66 has been a member for 9 full years
Topics: 139
Images: 73
Alias (AKA): Cameron
Extra Info: 4.3L V6 TBI Shorty
Postby lilpig [OP] » March 13th 2013, 3:06am
Steering pump seems to be fine. Fluid looks good and is up to level. No noise.
Brakes are fine. I have changed them over the last 2 years several times and it's not had any impact on steering.
lilpig
Alias (AKA): lilpig
Extra Info: 4.3 RWD
Postby Drummernaut » March 13th 2013, 3:58am
How is you front end alignment? That is what should kick your steering back to the center. Have you had your camber and toe-in checked?
1999 Astro LT AWD
MODS: Electric fan, Transmission cooler/fan, AWD engaged LED
Drummernaut
Years of Membership: Drummernaut has been a member for 10 full yearsDrummernaut has been a member for 10 full yearsDrummernaut has been a member for 10 full yearsDrummernaut has been a member for 10 full yearsDrummernaut has been a member for 10 full yearsDrummernaut has been a member for 10 full yearsDrummernaut has been a member for 10 full yearsDrummernaut has been a member for 10 full yearsDrummernaut has been a member for 10 full yearsDrummernaut has been a member for 10 full years
Topics: 9
Alias (AKA): Drummer From Hell
Extra Info: LT V6 AWD
Postby kornphlake » March 13th 2013, 5:05am
I had to watch the video twice, I thought you were stopped, but in gear the first time I watched it, the second time thorugh the moving reflections in the mirror gave it away. I'm going to agree with Drummernaut, get the alignment checked, I'm guessing your camber is way out of whack.
kornphlake
Years of Membership: kornphlake has been a member for 10 full yearskornphlake has been a member for 10 full yearskornphlake has been a member for 10 full yearskornphlake has been a member for 10 full yearskornphlake has been a member for 10 full yearskornphlake has been a member for 10 full yearskornphlake has been a member for 10 full yearskornphlake has been a member for 10 full yearskornphlake has been a member for 10 full yearskornphlake has been a member for 10 full years
Topics: 13
Images: 8
Extra Info: SLT RWD
Postby lilpig [OP] » March 14th 2013, 11:36am
Alignment was just done. Didn't change a thing.
lilpig
Alias (AKA): lilpig
Extra Info: 4.3 RWD
Postby chevymaher » March 14th 2013, 12:59pm
For the wheel to keep turning like that it is the steering box. For what ever the reason it is over assisting.
Postby Spider'sSafari » March 14th 2013, 4:21pm
Metering valve in steering box is bad. There is a Rotary valve inside steering stem/box that directs the pressurized fluid in the diection of the turn and SHOULD Stop the fluid from flowing when the wheel stops turning.
Looks like that what's happening in your video, the rotary valve is just staying open n not shutting off flow from pump.
Here is a Good link to a web site so you can see how it suppose to work.
Link: http://auto.howstuffworks.com/steering4.htm
Also don't try to remove the pivot arm under the van, remove the connecting knuckle at the center link and then remove steering box from under van, then remove the pivot arm.
Spider'sSafari
Years of Membership: Spider'sSafari has been a member for 8 full yearsSpider'sSafari has been a member for 8 full yearsSpider'sSafari has been a member for 8 full yearsSpider'sSafari has been a member for 8 full yearsSpider'sSafari has been a member for 8 full yearsSpider'sSafari has been a member for 8 full yearsSpider'sSafari has been a member for 8 full yearsSpider'sSafari has been a member for 8 full years
Images: 24
Alias (AKA): Spider
Extra Info: Mark III Denali Conv
Postby lilpig [OP] » March 15th 2013, 12:19pm
Ok. Spider do I need to replace the steering box or can I fix the bad part?
lilpig
Alias (AKA): lilpig
Extra Info: 4.3 RWD
Postby Spider'sSafari » March 15th 2013, 4:25pm
The whole box is the best n easiest. I don't think a DIY rebuild kit will include the parts you need and they are probably pressed on the main shaft anyway.
I just replaced mine last monot and got shell shock the Core replacement charge was $6 more then the new replacement. Core $ 185 n part was $ 179, So take your out first then go get a replacement and swap on site.
Spider'sSafari
Images: 24
Alias (AKA): Spider
Postby lilpig [OP] » March 16th 2013, 2:49pm
K. I can do that.
I just had it aligned. Will I have to do it again? Is there a way to avoid that?
lilpig
Alias (AKA): lilpig
Extra Info: 4.3 RWD
Postby Spider'sSafari » March 16th 2013, 3:47pm
No, the main pivot arm has a spline groove gap that can only be put on in one place and the steering wheel knuckle is the same way. Just make sure the steering wheel is straight and the front wheels too.
Spider'sSafari
Images: 24
Alias (AKA): Spider
Postby lilpig [OP] » March 16th 2013, 8:29pm
Tks Spider
lilpig
Alias (AKA): lilpig
Extra Info: 4.3 RWD
Return to Steering
It is currently March 6th 2021, 9:38am
Steering Forum
in Steering
Comments: 29
Date: Feb 20 '21
Time: 12:26am
arian
in Steering
Comments: 29
Date: Feb 11 '21
Time: 6:47am
arian
in Steering
Comments: 29
Date: Jan 28 '21
Time: 6:03am
in Steering
Date: Nov 07 '20
Time: 4:46am
in Steering
Date: Oct 21 '20
Time: 7:55pm
