Vibration above 60MPH, knocking when turning
Postby gamefreak [OP] » May 9th 2013, 12:30am
When driving more than 60 mph down the highway I get heavy vibration especially from the back. Also when doing slow speed turns I get some knocking noise fron the front wheel, especially since the wheel bearing was tightened. I also get more play turning the wheel right than I do left.
Idler Arm was replaced (BTW how many Idler Arms are in these vans.)
lower ball joint replaced (Right Side)
wheel bearings retightened and greased up (Right Side)
tires balanced
shocks replaced
My rear brake shoes are going out so am having them replaced. Any idea on whats wrong, I'm leaning towards bad u joints. Any help would be appreicated.
gamefreak
Years of Membership: gamefreak has been a member for 8 full yearsgamefreak has been a member for 8 full yearsgamefreak has been a member for 8 full yearsgamefreak has been a member for 8 full yearsgamefreak has been a member for 8 full yearsgamefreak has been a member for 8 full yearsgamefreak has been a member for 8 full yearsgamefreak has been a member for 8 full years
Topics: 7
Re: Vibration above 60MPH, knocking when turning
Postby SilverBullet1997 » May 9th 2013, 1:04am
idler arms = 2, one each side up front.
I had a loud vibration noise with out any noticeable vibration, and a loud clunk when going to a stop and go. It turned out to be a completely gone bushing on my front u-joint, I had them both replaced.
R.I.P.-1997 Astro AWD SilverBullet I 4-9-1997 to 2-17-2015 - Cause of death: Rear-ended
R.I.P.-1999 Astro AWD SilverBullet II 1-4-1999 - July-2016 - Cause of death: Roadrash passenger side
Current: 1999 Astro AWD GreenBullet I - Purchased 02/2018
SilverBullet1997
Firing on 6 Cylinders (L2)
Years of Membership: SilverBullet1997 has been a member for 7 full yearsSilverBullet1997 has been a member for 7 full yearsSilverBullet1997 has been a member for 7 full yearsSilverBullet1997 has been a member for 7 full yearsSilverBullet1997 has been a member for 7 full yearsSilverBullet1997 has been a member for 7 full yearsSilverBullet1997 has been a member for 7 full years
Topics: 54
Images: 247
Alias (AKA): Silver or Bullet or SB
Extra Info: 7in Lift AWD Z71
Postby gamefreak [OP] » May 9th 2013, 2:28am
Would a bad u joint also cause play in wheel.
gamefreak
Topics: 7
Postby gamefreak [OP] » May 11th 2013, 4:01am
Found out even at 200,000 miles that my U Joints where still good. However my driver side tie rod ends were bad. Also the problem with the rear end vibration was the wheel cover on one of that back wheels was throwing that tire into a slight imbalance. Had it taken off and van is now smooth even at 65 MPH.
Now to just replace driver tie-rod ends and get an alignment.
gamefreak
Topics: 7
Return to Steering
It is currently February 28th 2021, 4:59pm
Steering Forum
in Steering
Comments: 29
Date: Feb 20 '21
Time: 12:26am
arian
in Steering
Comments: 29
Date: Feb 11 '21
Time: 6:47am
arian
in Steering
Comments: 29
Date: Jan 28 '21
Time: 6:03am
in Steering
Date: Nov 07 '20
Time: 4:46am
in Steering
Date: Oct 21 '20
Time: 7:55pm
