Idler arms replacement
Postby ally_g [OP] » June 6th 2009, 9:48pm
Need to replace the idler arms on a GMC Safari van 1988. Have the Haynes manual but some of what the book refers to does not seem correct. Am referencing a photo in the book I have which mentions using a two jaw puller to separate the idler arm from the linkage,only the picture is of a ball joint and not the idler arm.Is there a section on this site that deals with the procedure ? I have read some posts which reference using the Moog Problem solver.Are these worth the extra $ that they cost ? I live in Oshawa, Ontario,Canada.Planned on having a mechanic friend do this,only he has not returned my calls about whether he has ordered the parts and when he would be able to do the work.Am at a point where I am thinking about doing the re and re myself.The tires I had on,one wore down to the steel belt or cord on the inner edge of the front tires, which was what brought my attention to the problem.The mechanic friend also noticed when he replaced the front rotors,grease seals,brake pads and front shocks,that the idler arms needed to to replaced.(too much play).Suggestions or advice would be greatly appreciated.Thank you.
ally_g
Years of Membership: ally_g has been a member for 11 full yearsally_g has been a member for 11 full yearsally_g has been a member for 11 full yearsally_g has been a member for 11 full yearsally_g has been a member for 11 full yearsally_g has been a member for 11 full yearsally_g has been a member for 11 full yearsally_g has been a member for 11 full yearsally_g has been a member for 11 full yearsally_g has been a member for 11 full yearsally_g has been a member for 11 full years
Topics: 7
Alias (AKA): ally(Al)
Extra Info: SLE 4.3L V6 RWD
  • idler arm
    by ptysiek » December 2nd 2020, 10:52am in Steering
    December 6th 2020, 5:59pm
  • Power Steering Pump Replacement
    by WakkoWarner » October 27th 2020, 11:44pm in Steering
    Last post by stent View the latest post
    November 9th 2020, 5:07pm
    55
    February 28th 2021, 1:49pm
Re: Idler arms replacement
Postby astro355 » June 6th 2009, 11:39pm
Hello,
yes the Moog problem solvers are your best bet. Regular ones will wear out again. And you could use a two jaw puller to seperate an idler arm from the centerlink, like a ball joint.
astro355
Firing on 4 Cylinders (L6)
Extra Info: 355 V8 700R4
Postby mikebenghp » June 7th 2009, 12:47am
i replaced mine last week. All i needed was a hammer and pickle fork. 20 minute job with grease job.
92 CL EXT 190k rebuilt motor and trans. Runs like a champ. Quiet, clean and dependable.
mikebenghp
Years of Membership: mikebenghp has been a member for 11 full yearsmikebenghp has been a member for 11 full yearsmikebenghp has been a member for 11 full yearsmikebenghp has been a member for 11 full yearsmikebenghp has been a member for 11 full yearsmikebenghp has been a member for 11 full yearsmikebenghp has been a member for 11 full yearsmikebenghp has been a member for 11 full yearsmikebenghp has been a member for 11 full yearsmikebenghp has been a member for 11 full yearsmikebenghp has been a member for 11 full years
Postby Big_kid » June 7th 2009, 4:23am
mikebenghp wrote:i replaced mine last week. All i needed was a hammer and pickle fork. 20 minute job with grease job.
X2. Did mine about 2 months ago, went with Moog after reading here.
Separate the joint at the drag link before unbolting it from the frame.
:chevy:
Firing on 7 Cylinders (L7)
Topics: 185
Images: 342
Extra Info: 2WD 5.7 V8
Postby gtkane » June 7th 2009, 1:52pm
Smack it with a hammer to seperate. Works everytime.
User album #4...check it out!
gtkane
Alias (AKA): Astruck
Extra Info: nasty 4.3
Postby mikebenghp » June 7th 2009, 4:50pm
the hammer method works best if you disconnect the swivel joint first, leaving the two bolts attached to the frame. speaking from experience. hitting it with a hammer AFTER removing bolts from the frame is both comical and completely impossible, at least it was for me.
mikebenghp
Postby gtkane » June 7th 2009, 9:37pm
Quite true!
gtkane
Postby Big_kid » June 7th 2009, 10:37pm
I didn't say how I knew this. :whistle:
:chevy:
Topics: 185
Images: 342
Postby Black89cs » June 20th 2009, 12:13am
astro355 wrote:Hello,
Don't mean to hijack the thread but you wouldn't happen to have a link to the Moog replacement parts would you? My front-end is getting quite scary and I think it's about time to put a little bit of work into it before I turn the wheel but go straight. :mrgreen:
Black89cs
Firing on 8 Cylinders (L1)
Years of Membership: Black89cs has been a member for 12 full yearsBlack89cs has been a member for 12 full yearsBlack89cs has been a member for 12 full yearsBlack89cs has been a member for 12 full yearsBlack89cs has been a member for 12 full yearsBlack89cs has been a member for 12 full yearsBlack89cs has been a member for 12 full yearsBlack89cs has been a member for 12 full yearsBlack89cs has been a member for 12 full yearsBlack89cs has been a member for 12 full yearsBlack89cs has been a member for 12 full yearsBlack89cs has been a member for 12 full years
Topics: 81
Postby astro355 » June 20th 2009, 5:18am
I got mine thru the school I attended. I couldn't find any listing online for them yet. All I could find was this:
http://www.jegs.com/webapp/wcs/stores/servlet/MkMdlYrSearchCmd?storeId=10001&catalogId=10002&langId=-1&N=1544225+4294951570&Ne=1147708&searchType=MkMdlYrSearch
I'm not sure those are the same ones though. :confused:
astro355
Postby ihatemybike » June 22nd 2009, 12:54pm
I get mine from http://www.rockauto.com.
Just created a shopping cart for you. $125.58 for both before shipping.
Aaron
Prev Astros:99,97,00,94,87,86
ihatemybike
Firing on 6 Cylinders (L2)
Topics: 68
Postby guyonearth » June 22nd 2009, 4:36pm
If you hit it with two hammers, i.e. use one as an anvil, you can usually get it to split if you've made the mistake of unbolting it. I've seen people do some crazy things. I just worked on a car where somebody replaced the tie rods by hacksawing the nuts and studs off!
guyonearth
Years of Membership: guyonearth has been a member for 11 full yearsguyonearth has been a member for 11 full yearsguyonearth has been a member for 11 full yearsguyonearth has been a member for 11 full yearsguyonearth has been a member for 11 full yearsguyonearth has been a member for 11 full yearsguyonearth has been a member for 11 full yearsguyonearth has been a member for 11 full yearsguyonearth has been a member for 11 full yearsguyonearth has been a member for 11 full yearsguyonearth has been a member for 11 full years
Topics: 5
Alias (AKA): DeanC
Postby Ericglo » July 10th 2009, 8:23pm
Just wanted to throw in a thumbs up for XRF idler arms. I put them on a couple of months ago and haven't had a problem.
2002 GMC Safari
2004 Chevy Astro
Ericglo
Years of Membership: Ericglo has been a member for 13 full yearsEricglo has been a member for 13 full yearsEricglo has been a member for 13 full yearsEricglo has been a member for 13 full yearsEricglo has been a member for 13 full yearsEricglo has been a member for 13 full yearsEricglo has been a member for 13 full yearsEricglo has been a member for 13 full yearsEricglo has been a member for 13 full yearsEricglo has been a member for 13 full yearsEricglo has been a member for 13 full yearsEricglo has been a member for 13 full yearsEricglo has been a member for 13 full years
Topics: 19
Postby Big_kid » July 11th 2009, 2:49am
guyonearth wrote:...somebody replaced the tie rods by hacksawing the nuts and studs off!
Some people need to have their tools confiscated! :o
Topics: 185
Images: 342
Return to Steering
It is currently February 28th 2021, 1:49pm
Steering Forum
in Steering
Comments: 29
Date: Feb 20 '21
Time: 12:26am
arian
in Steering
Comments: 29
Date: Feb 11 '21
Time: 6:47am
arian
in Steering
Comments: 29
Date: Jan 28 '21
Time: 6:03am
in Steering
Date: Nov 07 '20
Time: 4:46am
in Steering
Date: Oct 21 '20
Time: 7:55pm
cron
