knock sound and vibration when turning in circle .
Postby jgibson2980 [OP] » November 1st 2013, 6:05am
Hey everyone im new here and I just purchased an 1999 awd cargo astro. when I turn the wheell all the way to the left or right and drive in a circle the van start to make knocking noise and vibrates some . feels like some thing may be in a bind but I dont know know . so any help or ideas thing to look for that could be the problem would help
jgibson2980
Years of Membership: jgibson2980 has been a member for 7 full yearsjgibson2980 has been a member for 7 full yearsjgibson2980 has been a member for 7 full yearsjgibson2980 has been a member for 7 full yearsjgibson2980 has been a member for 7 full yearsjgibson2980 has been a member for 7 full yearsjgibson2980 has been a member for 7 full years
Alias (AKA): jason
Re: knock sound and vibration when turning in circle .
Postby Jasen » November 1st 2013, 10:18pm
Welcome to A/S
What condition are the tires in. Even wear on all 4, all the same brand and size, what size.
edit
Oh and check the rubber splash shield in the wheel well's, one could be loose, also check the bumper mask, the metal stay rod could be bent or popped loose
I'm a Journeyman woodworker,
Every projects a journey man.
200k
Ultra gauge
Topics: 260
Images: 101
Postby jgibson2980 [OP] » November 2nd 2013, 3:00am
I researched the forum and it sounded like it may be the transfer case fluid . So i drained and changed it Im going to run it for 100 miles and then change again . IT has mad i ton of difference and I believe that to be the problem .
jgibson2980
Alias (AKA): jason
Postby thegreenmachine » November 2nd 2013, 3:01am
Change your transfer-case fluid with fresh autotrac II.
There was a service bulletin about issue you're describing. The solution is to change the tcase fluid. Drive 100 miles. Change it again.
I had the same prob.
Sent from AutoGuide.com App
"that looks legit"
95 AWD Safari money pit
thegreenmachine
Firing on 6 Cylinders (L2)
Years of Membership: thegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full yearsthegreenmachine has been a member for 11 full years
Topics: 62
Alias (AKA): Shane a lane
Return to Steering
It is currently April 13th 2021, 1:43am
Steering Forum
ASTROMATT0630
in Steering
Comments: 0
Date: Apr 06 '21
Time: 10:53am
in Steering
Comments: 31
Date: Feb 20 '21
Time: 12:26am
arian
in Steering
Comments: 31
Date: Feb 11 '21
Time: 6:47am
arian
in Steering
Comments: 31
Date: Jan 28 '21
Time: 6:03am
in Steering
Date: Nov 07 '20
Time: 4:46am
